1996 gsx600f regulator change.
Glover
PostPosted: 09:53 - 20 Dec 2016    Post subject: 1996 gsx600f regulator change. Reply with quote
Seems like its the regulator thats been causing my problems so a new one is on order.
Question is, any of you had experience changing one of these on the gsxf and if so can it be done without taking the air box and carbs off? i know to change the alternator it all needs to be stripped down but can you get the regulator cover off and change the reg just by taking the left side fairing off?
davebike
PostPosted: 10:29 - 20 Dec 2016    Post subject: Reply with quote
If it is as I think the "CAR STYLE" unit
Don't piss about! remove it from the bike to work on it reg could be the problem but I bet on brushes
be careful there are many small parts!
Dave
NC750Xdct + others at work !
[email protected]
RhynoCZ
PostPosted: 11:44 - 20 Dec 2016    Post subject: Reply with quote
Not on your motorcycle, but yes in general, it's a easy job. You are only changing the part no. 10 (32500-27A00). Take the cover off and you should be able to see it. There's no need to remove the alternator from the engine.
BEFORE YOU DO
Tell us the symptoms, you're having. So you won't be changing all the bits to find out the problem was elsewhere.
https://partsdepot.cz/picdily/93741.jpg
Glover
PostPosted: 14:28 - 20 Dec 2016    Post subject: Reply with quote
Thanks for the replies. I've had a problem where the revs would drop to the point it cuts out when I turn the lights on. I disconnected the regulator plug on the weekend and it ran without fault.
Do you know if I can get to it without taking the airbox and carbs off though?
redeem ouzzer
PostPosted: 15:32 - 20 Dec 2016    Post subject: Reply with quote
You do realise the revs dropping with the lights on is normal? My GSXR1100 is a cunt for it. Just wind the Idle up until it just holds with the lights on. Job jobbed. The reason it stopped doing it when you unplugged the regulator is cause there was no load across the alternator.
Be a REAL MAN!
Glover
PostPosted: 16:25 - 20 Dec 2016    Post subject: Reply with quote
It shouldn't drop that much that it cuts out. If I up the revs to keep idling with the lights on it revs at 1000rpm but then 1700 with lights off. It's also putting out 15.2v with the lights on which is 14.7v with lights off.
temeluchus
PostPosted: 16:32 - 20 Dec 2016    Post subject: Reply with quote
This points to you have a poorly adjusted weak idle, rather than needing to fuck with one of the most reliable alternators in The history of motorcycling.
Id be looking for slight air leaks and checking the adjustment of idle mixture screws.
The last post was made 9 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.42 - MySQL Queries: 14 - Page Size: 51.85 Kb
