2-stroke ped + smoke
Claud 14.7 to 1
PostPosted: 13:22 - 29 Aug 2004    Post subject: 2-stroke ped + smoke Reply with quote
Hi, I have a ped which needs to be sold.
It has 7,200 miles, but the problem is it smokes alot. Manly on start up, and after about 5 mins riding the smoking becomes significantly less.
Now is there anyway i can stop it smoking in the short term, ie just for the buyer "check over". After that i dont mind. It doesnt have to be long term thing. The rings are probably worn, but there is no way im going to change them...
It runs perfectly, just smokes.
Any addivtes or such like??? Whatever you recon. Thumbs Up
Suzuki Ap50 X reg (2001)
Thank you! Smile
swampy
PostPosted: 13:32 - 29 Aug 2004    Post subject: Reply with quote
You could try the old chestnut of warming the bike up before any prospective buyer comes round, but to be fair you should let them know of any problems they might encounter if they buy the bike. Or you could just leave it and try an baffle them with science " two strokes always smoke when starting up" etc Wink
Claud 14.7 to 1
PostPosted: 13:37 - 29 Aug 2004    Post subject: Reply with quote
Hehe yeah ive thought of both of those already... Just though there may be something more "stone clad" I could use... Shifty
It runs perfectly and all, it just makes it look bad...
Smoto Bob
PostPosted: 13:48 - 29 Aug 2004    Post subject: bike Reply with quote
its a 2smoke, thats what they do, mate, its fine Rolling Eyes
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
tatters
Exxon Valdez
PostPosted: 13:49 - 29 Aug 2004    Post subject: Reply with quote
the smoke is a good sign, if there was no smoke at start up it would mean there was no oil beening burnt and that would be a problem Razz
PostPosted: 13:52 - 29 Aug 2004    Post subject: Reply with quote
It is a 2 stroke. The rings are going to do nothing to stop oil getting burnt and smoking as the oil is coming in with the air and petrol.
Possibly the air filter is dirty (will richen the mixture). Possibly the carb is leaking an dripping fuel into the engine when parked. Possibly the oil pump is set up too rich.
Claud 14.7 to 1
Hehe, it smokes alot. I think i'll take a picture to show you when i can be bothered.
Its a thick whitey/slightly bluey smoke. I know thats what they do, but i dont think this is normal. Plus it got noticeably worse after the winter months...
I told my bro to let it warm up... Confused
PostPosted: 13:53 - 29 Aug 2004    Post subject: Reply with quote
Two strokes smoke, it's when they are not making any smoke at all then it's time to worry. Don't start the bike up before they get there, most people are wise to "I warmed it up for you" as the only reason people do that is to hide a problem starting or warming up.
Claud 14.7 to 1
PostPosted: 13:55 - 29 Aug 2004    Post subject: Reply with quote
Ok well i'll try Kickstart's suggestions. It did smoke before but this is just silly/embarrassingly smokey.
Thanks people.
badlydamaged
PostPosted: 14:41 - 29 Aug 2004    Post subject: Reply with quote
Im probably completly wrong, but I was told that white smoke could just be condensation in the exhaust coming out as the bike warms up. My old Ped does this quite badly, especially in damp wheather (could be the crap weather which has made it seem worse). My two stroke bike also does this when it's started, left idling to warm up, and then the throttle is opened after a minute or two, resulting in loads of whitey bluey smoke being chucked out. Doesn't really do it so much if I just start riding as soon as it starts, or if I start it once it's already warm.
Just a thought, whatever it turns out to be, loads of peds do it so I don't think you have anything to worry about Thumbs Up .
My bike: 1988 Kawasaki KH100 Status: Polluting Devon with two stroke smog and noise pollution!
"Its not your engine size that matters!, It's what you do with it that counts" Very Happy
Add me to MSN if you want! [email protected].
Claud 14.7 to 1
PostPosted: 16:34 - 29 Aug 2004    Post subject: Reply with quote
Well yes a little white smoke would not be so bad, even an ammout of any colour snoke smoke would be ok, but there is something amiss on my ped, i think...
Im just doing cosmetics at the mo, ill test the bike a bit later on. Thumbs Up
PostPosted: 17:53 - 29 Aug 2004    Post subject: Reply with quote
Two strokes Smoke... simple.
They have what is called a 'total loss' lubrication system whereby the oil is burned in the fuel. There is no 'engine oil' behind the rings that might escape into the cylinder... its all going to be burned anyway.
Blue smoke appears on four strokes where engine oil is being burned when it should not be. This can happen when the rings are worn etc. I can't see that blue smoke would ever be a bad thing on a two stroke however, because as I said above you /want/ it to burn the oil.
Also may I suggest trying to use a 'low smoke' scooter type two stroke oil? It definitely won't do the bike any good, because I hear the low smoke stuff is rubbish, however it might help you to reduce the amount of smoke that is emitted.
It seems that this would be a wasted effort if the buyer comes /expecting/ the bike to smoke! Smile
Claud 14.7 to 1
PostPosted: 18:40 - 29 Aug 2004    Post subject: Reply with quote
Put redex in bike, cleaned air filter, and cleaned up the carb up a bit. It runs a bit better.
Still starts with loads of smoke when from cold. Not how it used to be. Confused But runs nice when its warmed up.
Should be ok. May get some of that low smoke oil, thanks Marjay, or get some decent synthetic oil. It needs more oil anyway...
Smoto Bob
PostPosted: 19:07 - 29 Aug 2004    Post subject: bike Reply with quote
don't know about peds, but my dt125 and other Auto-lube 2 smokes have an oil pump that is adjustable ( runs off the same cable as the throttle), perhaps the cable has worn or it has become mis-adjusted. The manual should tell you how the check it/re-set it.
badlydamaged
PostPosted: 20:20 - 29 Aug 2004    Post subject: Reply with quote
This is the most I could get my ped to muster today when warming up, how much worse is it to this and is the smoke the same colour? That blue smoke is just two stroke, it has in the past chucked out loads of white smoke (which I just took to be condensation). If you want a pic of really bad two stroke smoke pollution, just wait until I get the KH back! That really puts everrything to shame! Twisted Evil
binge
Emo Kiddy
PostPosted: 20:46 - 29 Aug 2004    Post subject: Reply with quote
is the bike a gillera or a Piaggio?
if it is, they are prone for getting damp in the exhaust, underneath by where the exhaust attaches to the barrel there is a bolt in the exhaust its self, i think its a 13 mm.
take it out and start her up, block off the end of the pipe so the fumes are comming out of this hole and it will sputter any water out through here...
also my friend has a stalker and it does smoke more in the cold weather. its normal, (and his smoke is white too) what oil do you use?
ben
binge
Emo Kiddy
PostPosted: 20:52 - 29 Aug 2004    Post subject: Reply with quote
Correction, i didnt see that u stated its an AP 50...
but still have a check for the little sump bung at the bottom of the exhaust just incase...
i wouldnt worry about it. just blag it off to the buyer saying its a two stroke and the oil mixture is high because that way it is safer as the engine wont seize!
Good Luck
Ben
Claud 14.7 to 1
PostPosted: 21:30 - 29 Aug 2004    Post subject: Reply with quote
Lol, its a whiter/thicker colour than that, and it'll fill up half the road, no joke Shocked Laughing .
No, since we started tinkering around with it its got better. More testing tomorrow, but it looks good.
Have been using veggie oil, but i think we will treat it to some decent stuff, as a farewell present. Middle Finger Mr. Green Middle Finger
divuk83
PostPosted: 22:06 - 29 Aug 2004    Post subject: Reply with quote
Its probably even smokier now you put redex in! It doesn't help as it doesn't benefit a fairly modern engine.
As everyone else has said, 2 strokes smoke a lot, more so with an auto choke, hence it smokes more when you start it. As long as it doesn't smoke heavily once its been running a bit then its not a problem.
Dave
Claud 14.7 to 1
PostPosted: 22:16 - 29 Aug 2004    Post subject: Reply with quote
Less smoke after redex, i will continue to test tomorrow.
Its just it will look a bit wank if someone comes to look at it, turns it on and the whole premisis gets fogged out. Laughing
No joke Shocked
divuk83
PostPosted: 22:17 - 29 Aug 2004    Post subject: Reply with quote
That all redex does is make smoke, much to the disgust of my garage I put some in and I absolutely smoked the whole place out when it was on the dyno Very Happy
Dave
Claud 14.7 to 1
PostPosted: 22:20 - 29 Aug 2004    Post subject: Reply with quote
Na, i put redex in the Honda all the time and it loves it, perfect.
Ped likes it also.
I like it too, tastes like cranberrys.
ts50x0
PostPosted: 22:33 - 30 Aug 2004    Post subject: Reply with quote
are you having a girraffe. that is not a lot of smoke for a 2 stroke. in fact its probably not enough. if i went to see a bike and it didnt smoke then i wouldnt buy it. the more smoke the better.
Smoto Bob
PostPosted: 02:21 - 31 Aug 2004    Post subject: bikes Reply with quote
spot the bike
https://www.bikechatforums.com/download.php?id=6724
that was the better of the 2 Shocked
Wave2k
G's Stalker
PostPosted: 03:26 - 31 Aug 2004    Post subject: Reply with quote
my RS125 smokes like a good'un untill it reaches about 35c
seems pretty normal for 2T
Ducati 1299 Panigale
2009 Corvette C6 z51
The last post was made 22 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 128.79 Kb
