GraemeD |
GraemeD L Plate Warrior
Posted: 21:06 - 23 Dec 2016 Post subject: Honda nsr 125 r electric problems |
How's it going everyone I'm new to the forum and I'm afraid I need a bit of help straight away. I'm new to biking also and chose the nsr as my first bike and have been on her for a little less than a year. She was a fixer upper and has had her problems but nothing I couldn't figure out or find on forums like this one. I had her perfect. Until.
She had a couple of smacks a while back when I was in a cocky learner stage and all the fairings on one side got wrecked along with the crank seal and exhaust. I was driving along a week or 2 later and the engine gave up.
I ended up buying a spare bike for parts and replaced the engine with all extras still attached, clocks, indicators, headlights. She was hard on the eye but electronically and mechanically perfect again other than being very smokey when first started (still a small bit too smokey) and the power valve didn't seem to open up around 8000 like it used to, was more like it opened low 3 or 4000rpm
My current issue is a proper head scratcher. After weeks of happy riding I noticed my indicators weren't working when I had the throttle open with the revs over 5000rpm. They work fine when bike is idling. Then I noticed that the neutral light comes on every time I pull the clutch in half way. The indicators got worse to the point where I wasn't comfortable driving in traffic etc so here's what I've tried.
-Brand new battery and flasher relay (under the seat)
-Every other relay I could find under the tank
-The lights/indicators/ horn switch on the handlebars
-Clutch lever/switch
-Installed ignition (was joining wires until I got key cut)
-Inspected every wire I could find, cleaned every connection and found found a few breaks in wires etc including 2 indicator wires melted together. Sorted them all out but from the whole loom I could only find 1 earth grounded to the body, the one on the coil, which was filthy so I cleaned it up and bolted it back on.
The indicators now work better but still far from perfect, the neutral light still comes on when I pull the clutch in and now the power valve isn't working at and the bike is struggling at around 8000rpm when she used to go all the way to red no problem. When I switch on the ignition, there is power to the servo where the little round reel with the 2 cables turns slightly, but when I rev her up, the round reel does nothing.
WHAT HAVE I DONE?? I'm starting to get a bit worried I have tried everything I can think of and info I found online. I hope I'm not the first to have these problems all at once. If anyone can shed any sort of light on this I'd be very grateful. Sorry for the long post. It's been a bumpy road |
Fin |
Fin World Chat Champion
GraemeD |
piazza |
piazza Brolly Dolly
Posted: 00:01 - 24 Dec 2016 Post subject: |
GraemeD |
alains |
alains World Chat Champion
GraemeD |
GraemeD |
alains |
Robby |
Robby Dirty Old Man
GraemeD |
The last post was made 7 years, 116 days ago. Instead of replying here, would creating a new thread be more useful? |
