Waaarrrggghhh |
Waaarrrggghhh Nitrous Nuisance
jaffa90 |
jaffa90 World Chat Champion
Waaarrrggghhh |
Jewlio Rides Again LLB |
Jewlio Rides Again LLB World Chat Champion
Posted: 15:51 - 25 Dec 2016 Post subject: |
Spring is probably stretched. ____________________ Mpd72: I can categorically say i’m Brighter than that, no matter how I come across on here.
HAHAHA HAHAHA Blew Chilly MyCrowSystems |
jaffa90 |
Rogerborg |
Rogerborg nimbA
ThatDippyTwat |
ZRX61 |
ZRX61 Victor Meldrew
ThatDippyTwat |
Pete. |
Pete. Super Spammer
Posted: 09:53 - 26 Dec 2016 Post subject: |
Do as Rogers says. Remove the adjuster nut, spring and trunnion and see where it's sticking. Most likely the pivot is seized in the drum backplate. Give it a blast of penetrating oil to loosen it up, remove it from the backplate, clean, grease, re-assemble. Check the steel wear pads on the ends of the brake shoes don't have grooves worn in them. ____________________ a.k.a 'Geri'
Rogerborg |
Rogerborg nimbA
ThatDippyTwat |
Posted: 14:50 - 26 Dec 2016 Post subject: |
Rogerborg wrote: | ThatDippyTwat wrote: | Brake clutch Cleaner. |
One of my top purchases has been 5 litres of isopropyl alcohol for degunking and cleaning. Try not to get it on anything rubber, and wash it off with water if you do. |
Not sure if you can buy it as a consumer, but Action Can do a shit-hot Solvent that rips through, well, anything I've tried it on. Years of Road crud, grease off the chain, you name it. Also, the easiest way ever to clean your wheels. Just chuck water over them afterwards, I'm not sure if it affects rubber, but just in case.
https://www.actioncan.com/product/bc-90/
(CT-90 is a great lubricant by the same company, I chuck it on corrosion prone spots.)
I don't work for them etc, etc, but we did replace several other products in work with the action can equivalents. Cheaper *and* better. |
Rogerborg |
Rogerborg nimbA
Posted: 14:38 - 28 Dec 2016 Post subject: |
It could also be that the brake shoes are at their wear limit and the cam is starting to go over-centre. Especially if a previous owner had tried to eek out the shoes for a bit longer and moved the brake arm round a notch. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
ZRX61 |
The last post was made 7 years, 115 days ago. Instead of replying here, would creating a new thread be more useful? |
