Arcane1729 |
Arcane1729 Banned
redeem ouzzer |
stevo as b4 |
Posted: 09:34 - 26 Dec 2016 Post subject: |
Are you in a one make race series, or is it for road use? Does it need to be legal, fast or reliable?
Seeing as your post comes across as bhp and weight reduction are equally important I'm assuming it's for track use?
Weight loss will not matter for shit on the road, there's a good argument too for ''keep it heavy: keep it reliable''
In terms of Pure power output, any pipe will have no noticeable effect on performance on its own. Your looking at barely measurable gains at best.
If you have race class rules on modifications, what are they?
If there's no rules or its a road bike, then budget allowing, fit a 170cc big bore kit to a fresh or low mileage bottom end , with a flowed head with bigger valves and a performance cam too. You'll need a way to tune the EFI fuel delivery to suit then too.
You'll spend a relative fortune doing the above including dyno set up, but will make alot more bhp and a big percentage gain, maybe 40-50% more. 40% reduction in engine life. Would be a fair trade off for that too. |
Wafer_Thin_Ham |
Wafer_Thin_Ham Super Spammer
Posted: 09:38 - 26 Dec 2016 Post subject: |
Probably something like Akrapovic system which gives you a dizzying 0.8 bhp. ____________________ My Flickr |
secretagentmo... |
secretagentmo... Scooby Slapper
Beehive Bedlam |
P. |
P. Red Rocket
dydey90 |
dydey90 World Chat Champion
andyscooter |
RhynoCZ |
RhynoCZ Super Spammer
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 12:38 - 26 Dec 2016 Post subject: |
CBR125's been around a while & gone through at least one major re-design. I'm trying to remember whether the very first had carbs or if they have all had fuel injection, these sort of things do rather influence matters. All model's though are down almost 2bhp on what A1 Learner Licences 'may' permit, as they are one of the lighter bikes in class to start with.
In their early days, there was a 'Factory' HRC race-kit for them, for Mini-Stocks 125 racing. Comprised a pair of hi-lift cams, a lighter, but 'race legal' (103dB, ISTR) pipe and revised fuel map. There may have been other goodies in the box, like lightweight 'replica' plastics and possibly a different back shock & brake pads. 'Kit' gave the motor about 16/17bhp ISTR, and REALLY is about the best you can hope to do with one.
The HRC kit cams hint at the 'problem' trying to tune a CBR125 motor; those HRC cams, liberated an extra 15% more power from the thing without any extra displacement. So, you can muck about to your hearts content, but if the cams don't open valves far enough or long enough to let in enough 'charge' to make more than 13bhp, it don't matter much how bigger the hole beneath them is, or how big the holes in front of them are, those valves still wont flow any more charge, so you wont get any more power.
Tiddler Tuning is a general exercise in futility, where at best, you'll likely get no real measurable gain for whatever you try do, however much you spend. And most likely, you will actually loose both performance and reliability in equal measure to your efforts.
Meanwhile 'Power to Weight'... weight has no influence on top speed; that's purely a function of power vs drag. Does make a difference to acceleration, but, PTW is rather misleading on bikes, where the 'weight' the power has to shift is the 'all up' weight of bike + rider, where even on a 200Kg heavyweight, the 80Kg or so of rider, is quite a significant factor, it isn't to cars where the driver is likely less than 1/1oth the vehicle weight. On a 125Kg lightweight? The rider can almost halve the PTW ratio!
You can save a few grams from ditching the indicators or using titanium clutch cover screws I suppose.... B-U-T in the scale of thing, taking loose change and unused keys out your pocket would probably make as much difference! Heck, leaving your Smart-Phone at home, probably save as much mass as a 'race' exhaust!
As has been said, for the road, it's all rather pointless; if you actually achieve anything, then it will almost certainly breach L-Plate/A1 licence regs, and if you have a licence to ride the thing legally you could have got an awful lot more, an awful lot more cheaply ad easily, just by buying something else!! Heck, even the fastest of the fast illegal on L's/A1 125's, the Aprilia RS or Cagva Mito two-strokes, that might just scare 30bhp, and 100MPH, are only just about as powerful and quick as an old 250cc commuter bike!
For the track? Old Padock Lore: Want a faster bike? Fit a Better Rider!
A better rider, will go quicker, without necessarily going any faster; they'll be 'smooth', they'll not 'waste' speed slowing down so much to have to speed up again so often; they'll not load the tyres with violent action, so save grip to react higher corner speeds; so it will 'look' all rather un-dramatic, but they'll get the absolute most the bike can deliver, whatever that happens to be.... and time and time and time again, in the heat of real competition where points mean prizes not penalties and the stop watch never lies; them 'better riders' get far more impressive 'results' from that pure talent than thier mechanics can ever find them from a bit of tinkering or even a heck of a lot of 'cheating'!!!!
To wit.. most will be found improving your riding, NOT your bike...
Better rider? Makes the bike go faster, and further, between services and doesn't crash. So, its all win; bike holds its value; whilst not costing any more to run or insure. AND better rider fits any bike it's fitted to.. 'no cost'.. It's ALL win.
So... my advice, forget trying to tune a tiddler; work on that 'better rider'.. go get trained, go get that licence you suggest you plan in your profile. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
stevo as b4 |
redeem ouzzer |
Rogerborg |
Rogerborg nimbA
Posted: 13:52 - 26 Dec 2016 Post subject: |
OP was just on about getting an FZ6 (on A2?) but only if he can find the right flyscreen to make it be bitchin'.
So I'd suggest the ideal bike is an R6. Imaginary ones can be as light as you like. ____________________ Biking is 1/20th as dangerous as horse riding.
notbike |
notbike Formerly known as notabikeranymore
stevo as b4 |
definitelyinc... |
definitelyinc... Trackday Trickster
arry |
arry Super Spammer
Ste |
Ste Not Work Safe
Posted: 15:03 - 26 Dec 2016 Post subject: |
If you want a fast 125 then you should get a two stroke. |
Rogerborg |
Rogerborg nimbA
Posted: 16:04 - 26 Dec 2016 Post subject: |
Oh, lordy, yes.
Crashed his scootay on his first ride, totes not his fault.
Had 3 days of A2 lessons, ragequit.
Is possible restrict KTM Superduke 1290 for A2 tho?
Want FZ6 S2 naow (still no licence, hasn't spotted that the FZ6 isn't legal for A2 anyway).
Rather than investing in a licence, is thinking about pouring money down the 4-stroke 125 racebike hole.
Serial fantasist manchild. ____________________ Biking is 1/20th as dangerous as horse riding.
definitelyinc... |
Posted: 18:44 - 26 Dec 2016 Post subject: |
I think there was one year when the fzs6 was a2 legal, I may be wrong though.
Investing in the 4 stroke 125 racebike thing is beyond silly when you're of age to get the er6n, mt07, sv650s, or any other similar bike, especially when you're after performance. |
Hong Kong Phooey |
Posted: 20:11 - 26 Dec 2016 Post subject: |
Shame it got a bit burnt in the fire ____________________
definitelyinc... |
Posted: 20:15 - 26 Dec 2016 Post subject: |
Hong Kong Phooey wrote: |
Shame it got a bit burnt in the fire |
Any videos of this grom? I'd love to see it in action. |
Arcane1729 |
Arcane1729 Banned
Posted: 03:19 - 27 Dec 2016 Post subject: |
hahahahaha- you know my lifestory!-you've been stalking me that's so creepy
Why isn't the FZ6 A2 legal anyway? It's 90bhp...
https://www.motorcyclenews.com/bike-reviews/yamaha/fz6-fazer/2004/
Also can't a man dream about two bikes?
I've already paid for my lessons- it only took a week of work during the christmas holidays- the guy said to just tell him a month to two in advance when I'm ready to do it (but I have to do it within a year of booking it or I lose my money but that's plenty of time)
I'm gonna buy a CBR first and sell it after a few months when I'm ready- I was just curious was all- Honda had 15bhp limit and for some reason they've made it so weak... Of course it'd be silly to invest any money into it.
On the plus side I passed my car test at the start of this month- 3 minors (I had to save up for that as well you know... six weeks of almost daily lessons set me back over a grand)
My motoring exploits havent been totally hopeless!
Even if the FZ6 (if you could kindly explain) is not available then all is not lost good sir! we have these two beauties still available: ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
Teflon Mike: "A man can dream... but most of them are probably best not voiced.... Folk will likely think you are just mad, sad or simply a pervert." |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 06:12 - 27 Dec 2016 Post subject: |
Arcane1729 wrote: | Why isn't the FZ6 A2 legal anyway? It's 90bhp... |
The law doesn't take 'random' internet power claims, it takes what's on the maker's plate; other sources suggest it's claimed at 72Kw (98bhp).... MCN probably took an independent 'Rear Wheel' figure.
Point of symantics, though even if it were 70Kw/90bhp, it still wouldn't be A2 'complaint'.... 'as standard'.
Licence restrictions state 35Kw 'max', so it is over licence limits, and would have to be 'modified' to be 'made' A2 complaint.. then other regs kick in; notably that a bike cannot e 'restricted' by more than 1/2 original claimed power, and must remain within the 0.1Kw/Kg? I think PTW limit, as well as the 35Kw A2 max licence limit.
Arcane1729 wrote: | Also can't a man dream about two bikes? |
Arcane1729 wrote: | On the plus side I passed my car test at the start of this month- 3 minors (I had to save up for that as well you know... six weeks of almost daily lessons set me back over a grand) |
Do you have a car?
Given your comments in other thread about being "So" passionate about bikes you make up new words.... I have to say my eye-brows are doing a good job of keeping my bald-spot warm, and tend to agree with the Jockish Hobit about being a serial fantasist, TBH.
IF you had the passion you claim for 'bikes', then you wouldn't be spending a grand to get a car licence, to drive a car you, I presume don't own or have regular access to. You would have put that cash to nailing down your A2 tests, or getting up to scratch going it alone on a 125 for A1 as a 'Dry Run' (Which ISTR even Roger, usually aghast at offering my common advice, suggested to you, some while ago).
Arcane1729 wrote: | I've already paid for my lessons- it only took a week of work during the christmas holiday |
Was that delivering pizzas on a push-bike still? As said, putting the cart before the horse, you could have been doing that on a 125, without L-Plates, or even a 'big-bike'. Better late than never I suppose, except that pizza isn't so nice cold.
Arcane1729 wrote: | I'm gonna buy a CBR first and sell it after a few months when I'm ready- I was just curious was all- Honda had 15bhp limit and for some reason they've made it so weak... Of course it'd be silly to invest any money into it. |
I retract comment about agreeing with the Borg on your serial fantasys.... 'serial' implies some sort of logical order.... 'random fantasist'... I think is more apt.
You are an ADHD gold-fish, aren't you? You leap down a train of fantastical inspiration, based on whatever you have bumped into most recently to inspire you! THEN try and find 'reason' to support the 'notion'... rational 'planning' is just NOT involved is it?
Arcane1729 wrote: | My motoring exploits haven't been totally hopeless! |
Hopeless or Hapless? I'll go with the latter.
Arcane1729 wrote: | Even if the FZ6 (if you could kindly explain) is not available then all is not lost good sir! we have these two beauties still available: |
Eh? What two beauties?!?! No! Dont bother, I don't care!!
STOP THINKING....... I would add the rest of the mantra "Start Riding" but in your case, that's optional!!!
Get a grip kid. Sparks is firing, flames are occasionally occurring, but the pistons ENT going up and down, or if they are, they aint making motion!
Turn the ignition 'off', stop making brum brum noises in your hat; and take a good long look at the matter!!! Get your ideas in order... and then stick them on a high shelf WELL out of the way, THEN go learn how to ride a motorbike! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
The last post was made 7 years, 121 days ago. Instead of replying here, would creating a new thread be more useful? |
