Tappet checking on the Lexmoto XTRS
NutsyUk
PostPosted: 14:04 - 11 Jan 2017    Post subject: Reply with quote
Tbh kinda hard to tell with the noise my lid makes... but i think it starts off with just reving down and then it kills out...
BTW it killed out twice in the same short journey... The first time I got it started back up pretty quick but it struggled to hold revs then killed out again...
Lexmoto XTR S 125 Sold!
PostPosted: 14:28 - 11 Jan 2017    Post subject: Reply with quote
NutsyUk wrote:
Can tappets tighten on there own that quickly?
They can if you don't do the locknuts up tight.
I wouldn't assume it's that though. Could be fuelling, electrics, overheating (leading to fuelling or electrical problems), pretty much anything.
Sorry, I know that's not much help, but I've not had one of those engines and don't know their foibles. I'd just suggest not getting too focussed on one possible cause.
NutsyUk
PostPosted: 14:31 - 11 Jan 2017    Post subject: Reply with quote
Yeah, annoying...
Well I certainly wouldnt trust it going down the a47 for 20 miles then...
i guess bring on direct access and new bike and flog this onto some poor unsuspecting sod :p
PostPosted: 15:26 - 11 Jan 2017    Post subject: Reply with quote
Some other poor unsuspecting sod... Wink
I didn't want to be too Buzz Killington prematurely, but the XTR variants seem to have more than their fair share of problems and I've seen a lot of really neglected ones come up on Gumtree.
NutsyUk
PostPosted: 15:42 - 11 Jan 2017    Post subject: Reply with quote
Heh yeah I should have said other poor sod :p
For the most part this bikes in pretty good nick... but clearly there is something not right.
Heck it could even be the ECU...
Actually thats a thought, the ECU controls the timing for the sparkplug, adjusts it on a curve from the throttle... if thats damaged in anyway, the timings could get out of sync on higher revs... or are the spark timings tied in mechanically?
I could be talking utter tosh there btw :p
smallfrowne
PostPosted: 17:23 - 11 Jan 2017    Post subject: Reply with quote
I'm confused. I meant, is the bike producing a spark the moment after the plopplopplopplopplopplop... death incident, ie you just stopped and are now pressing the starter button but it isn't starting. Is it sparking then? You can only tell by either:
1. Removing spark plug or using another spare plug in the end of the HT lead and resting it on the engine. Press starter. Is there a _good_ spark?
2. Removing the plug cap and putting your finger in the end of the plug cap to get a tasty shock. Press starter. Does it feel nice or not?
If it is sparking then you can probably rule it out and go chasing the fuel from tank to inlet. Using a spare plug would be quicker than taking the old one out so you get a pretty instant check. You may have understood this already, but your comment has confused me Cool
And I reckon ECU's aren't death immune but they tend to either work fully or not work at all.. but there's always a chance Very Happy
'90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90
NutsyUk
PostPosted: 17:27 - 11 Jan 2017    Post subject: Reply with quote
Oh right, umm i think it was sparking yeah...
Just wouldnt start for a minute normaly after it died...
But glad to know a ECU is either dead or not dead... no middle ground Very Happy
NutsyUk
PostPosted: 16:38 - 12 Jan 2017    Post subject: Reply with quote
Ohhh some updates on whats going on...
I went to a bike mechanics today, dad was getting my brothers bike rebalanced... I picked the mechanics brains about what could be wrong with my bike.
He thought right away that the stator coil pickup could be over heating.
As the engine dies about the same place while running the throttle high for the same amount of time.
And that if possible I should replace the stator coil, if i can replace that (5 quid) or the whole stator 30 quid...
Though he mentioned it could also be the float inside the carb... This is one thing i didnt know about so going to be doing some research.
Any thoughts?
PostPosted: 16:55 - 12 Jan 2017    Post subject: Reply with quote
I think he's just saying that it could be either electrics or fuel, i.e. he has absolutely no idea.
The symptoms are vague, there's no obvious cause. What I would urge you to do is to try and diagnose it first rather than throwing any money at it, since you'll never see a penny of it back. I know it's a sod when you can't predict it's going to happen, but you could leave the side fairings off to give better access.
Free check: fuel starvation. The instant it dies, open the drain screw on the carb (aiming the drain hose away from the exhaust!) and see if it's dry. It looks like you have a vacuum tap, so it shouldn't keep gushing, but some fuel should come out.
Electrics are trickier, since it's not on/off problem. When it does, see if the coil is approximately ouchy-hot to touch - that's a bad sign. But unless you have a multimeter to hand and know what the resistances on the coil are meant to be it'll be hard to definitively diagnose.
Sorry, I know this isn't much help, but we could propose loads of things, all of which are guesses without being on-scene when it acts up. Sad
NutsyUk
PostPosted: 17:14 - 12 Jan 2017    Post subject: Reply with quote
I think the reason he thought the stator coil pickup might be over heating is because it seems to die around the same spot on the road... IE been running at high rev for around the same amount of time when I go into town form here...
Thats about the only predictability going.
Ive also just had a look at where the stator and the pickup is housed. and Sad im not sure I could fix that. Given last time I tried to get in there when i was doing the tappets to get access to teh fly wheel. I couldnt take the side of the engine off... Took all the bolts out but the housing over the stator and flywheel just wouldnt move.
PostPosted: 17:49 - 12 Jan 2017    Post subject: Reply with quote
He's just guessing. The same logic could apply to the coil overheating, or the float bowl running dry, or the hedgehog hibernating in your airbox rolling over and blocking the flow.
NutsyUk
PostPosted: 17:52 - 12 Jan 2017    Post subject: Reply with quote
Oh god not hedgehogs... poor thing... D:
PostPosted: 17:55 - 12 Jan 2017    Post subject: Reply with quote
Nah, they're all pricks.
NutsyUk
PostPosted: 17:56 - 12 Jan 2017    Post subject: Reply with quote
I feel i must inform you.... I just died a little inside reading your post :p
smallfrowne
PostPosted: 01:15 - 13 Jan 2017    Post subject: Reply with quote
Well aye don't panic just yet, you've got to just use a bit of logical reasoning when it plays up to narrow it down, as said, one thing at a time. Do the tests above on the carb and ignition coil but also I'm not convinced you can tell it's sparking by pressing the starter and simply 'sensing' that it's sparking - how did you know/think it was sparking? You want to see sparks galore coming off the electrode, don't just imagine it Very Happy
Bike needs air, fuel and a spark. Just whittle it down to find out which one is lacking.
I'm kind of leaning towards fuel starvation just because if it starts up after just a minute of cooling then the stator or ignition coil probably hasn't cooled loads in order to magically start working again, but that depends how marginal the fault is if indeed it is one of them, maybe it is enough. Clear as owt, sorry, sometimes coils are just 'iffy' but at least sparking = ruled that out.
This could be a betting sport.
NutsyUk
PostPosted: 01:18 - 13 Jan 2017    Post subject: Reply with quote
Place your bets, but remember the house always wins. And the house needs at least a grand to get the A lcense out the way. And start putting money towards a real bike. :p
The last post was made 7 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.4 - MySQL Queries: 16 - Page Size: 96.94 Kb
