pepperami |
pepperami Super Spammer
Posted: 21:24 - 01 Jan 2017 Post subject: getting a seat covered. |
OK this one is more for the folks in the East of the country.
I have done some research on "teh net" and most companies doing seat covering stuff seem to be in the Midlands or north.
I am trying to get one of my seat`s foam changed and made a bit higher because the seat is to low and to hard.
So my question is , does anyone know of a company/people around the East Anglia region who specialise in motorcycle seat repairs/one offs?
Thank you for any help given
The alternative is to do it myself ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
Nobby the Bastard |
andym |
andym World Chat Champion
jaffa90 |
jaffa90 World Chat Champion
Posted: 01:10 - 02 Jan 2017 Post subject: |
Have a chat with a local motorcycle dealer who use such like for a deal,
also a caravan / boat / barge upholsterer,
also this guy using postage & instructions,
https://www.motorcycleseatworks.co.uk/
he did my X11 to my satisfaction. |
kramdra |
kramdra World Chat Champion
Posted: 01:24 - 02 Jan 2017 Post subject: |
This is relevant to me. 80,000 miles of arse has ripped the seat in the middle. Has also got wet, will foam be ruined?
I could buy raw vinyl. Cheapest, 5 quids. I would probably cock up the first attempt but its cheap enough. Option of sewing suturing a patch over the existing cover so no need to piss around with staples.
Pre-made vinyl cover. www.ebay.co.uk/itm/302165123019 Or real leather cover www.ebay.co.uk/itm/351005788071 Something else from germany www.ebay.co.uk/itm/142209798034 This does look far better than OE. Or collected, modified and fitted. £125 www.ebay.co.uk/itm/142209789715 |
UncleFester |
ScaredyCat |
ScaredyCat World Chat Champion
Posted: 11:39 - 02 Jan 2017 Post subject: |
Try https://www.elsemade.com/
Else Made
Nathan Lodge
High Road
Wisbech St Mary
Cambs
PE13 4RH
Comes highly recommended on many Triumph forums. Basic recover is from £20... ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
Suntan Sid |
Posted: 13:17 - 02 Jan 2017 Post subject: |
Sorry, don't know what your bike is OP!
I've done a couple of seat covers myself, one was very easy to do the other one was not as easy.
The first one I did was for a DRZ, this was very easy, the original cover was simply one piece of vinyl stretched over the foam and seat.
As Andy says, you need a good staple gun with a strong spring to get through the vinyl and into plastic part of the seat. I used a toffee hammer to finish off a few staples that didn't go in fully.
This is what it looked like when finished:-
https://www.bikechatforums.com/viewtopic.php?p=2803385
The second one I did was for my XL, this was difficult because the original seat cover was not a single piece of vinyl, it was made up of three pieces. Fortunately Mrs Suntan has a sewing machine and knows how to use it. I took the old cover off, unpicked the stitching and Mrs Suntan used the pieces as a pattern to make the new cover. Once the new cover's made it's the same procedure to staple it on.
Here's how I did it, (on first page of this thread):-
https://www.bikechatforums.com/viewtopic.php?t=278824
If you know someone who can sew, it shouldn't be a problem to do yourself, however if you want to add more foam you'll have to allow more vinyl for that. I guess the difficult part for you will be finding out how much foam you need to add and how much bigger the piece of vinyl needs to be! ____________________ "Everybody needs money, that's why they call it money!" |
pepperami |
Posted: 19:20 - 02 Jan 2017 Post subject: |
Thanks everyone for your help ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
kramdra |
Suntan Sid |
Posted: 21:38 - 03 Jan 2017 Post subject: |
kramdra wrote: | Suntan Sid wrote: | As Andy says, you need a good staple gun with a strong spring to get through the vinyl and into plastic part of the seat. I used a toffee hammer to finish off a few staples that didn't go in fully. |
Had a go with a staplegun test on the old cover, wouldnt go in, not even close. However it also does nails, they went ok, but they are sharper. Took a pack of staples to the bench grinder and made pointy. Now easy. Not the best tool for the job, some staples need to be at an angle that it cant get to, but will do for this. |
My tools are all packed away at the moment, (moving house, fingers crossed), so I can't check but I'm sure the one I used is an old one I bought from B&Q, years and years ago.
It's got two settings, when using the stronger of the two, it requires a lot of force to get it to fire!
It's never failed me yet, although I did notice when I was doing the Honda seat I had to use 6mm staples rather than 8mm, the 8mm's were not going in completely, hence the toffee hammer! ____________________ "Everybody needs money, that's why they call it money!" |
andym |
owl |
owl World Chat Champion
kramdra |
Posted: 23:48 - 16 Jan 2017 Post subject: |
stevo as b4 |
kramdra |
Posted: 01:05 - 17 Jan 2017 Post subject: |
Recommend this www.ebay.co.uk/itm/371772643802
Most important thing if DIY and without an air gun, staples really need to be sharpened, much less force required, then most go in perfectly. The alternative is hitting them with a hammer - they will bend over or crumple, and would be fail. |
Azoth |
Azoth Brolly Dolly
Posted: 01:48 - 17 Jan 2017 Post subject: |
Re-covering your seat with a strip of vinyl is the old-school way. If you use a heat gun instead of a hairdryer, you need to be very careful to keep it a good distance from the vinyl and keep it moving. If you let it get too hot, or touch the vinyl, you'll regret it.
The technique I used with mine involved stapling the front and back ends first, then stretching it over and doing the next staples diagonally (e.g. front right then rear left, then front left then rear right), always pulling taut and keeping the vinyl warm. I watched a couple of Youtube vids on how to do it beforehand, and this helped. The trickiest bits to staple and stretch over are in the middle, between the pillion and the rider portions of the seat.
Alternatively, you can get specialised, high quality, better-looking seats for most bikes, some of which state the model of the bike, and have elaborate piping and stitching for about £40-£50 on Ebay. These will just slip on and staple in place. ____________________ Safety in numbers |
The last post was made 7 years, 101 days ago. Instead of replying here, would creating a new thread be more useful? |
