smallfrowne |
smallfrowne Scooby Slapper
Posted: 17:54 - 03 Jan 2017 Post subject: Solder for nipples |
As per title I want to warm up my nipples and dip them in molten solder. But what type to use?! Can I get away with using leaded plumbers solder from screwfix/toolstation/somewhere like that?
I've read around the internets a bit and it sounds like something I want to do, but the more you read the internet the more confusing, clear, then confusing things get. Plus nowhere seems to list the make-up of "plumbers solder", it's either unleaded, or tin/lead but no mention of whether it's 60/40, 50/50 etc (not on screwfix/toolstation anyway). Does it matter too much? The key seems to be making the cable knotted enough that it won't pull through easily without the solder anyway.
Options:
1. Fluxed electrical solder i've got kicking around somewhere.
2. "Plumbers" Solder:
i. Leaded 4 star.
ii. Unleaded.
3. A "bar" of plumbers lead off ebay, which may be 60/40, unlisted, or god knows.
4. A solder of your choosing.
5. A 2 part epoxy avec metal shaving dust a lá JB Weld.
Any help appreciated, I'm sure someone on here will have done this act before.
Oh and also, I'll probably get some "Bakers fluid" as it seems to be the go to flux - unless I go the epoxy route - but it's £10+, any alternative?
Cheers ____________________ '90 VFR750; '89 NC30; '95 DR650; '89 CD250U; ~'82 CG125; ~C90 |
jaffa90 |
jaffa90 World Chat Champion
neptune8 |
neptune8 Nova Slayer
ThatDippyTwat |
Kickstart |
Kickstart The Oracle
Posted: 10:42 - 04 Jan 2017 Post subject: |
Get the solid lumps/thick coils of lead tin solder.
Melt it in a pot/crucible.
Setthe nipple and cable up. Heat the nipple with a microblowlamp, dip in flux then dip in solder, it should suck it up if you got the temperature right.
lead based solder can be "shaped" somewhat afterwards with a soldering iron as it does have a kind of plastic phase. Although I usually use a fine file to remove any excess solder
The trick is in getting the end of the cable unravelled correctly in the nipple and not tinning the cable too far below the nipple creating a stress point.
Bakers fluid is best, especially if you're putting a nipple on old cable but I use normal flux for making new ones.
Remember to wash the flux off after. It's corrosive.
Also remember someone on this forum lost the sight in one eye soldering so goggles. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
smallfrowne |
bikenut |
bikenut World Chat Champion
Islander |
Islander World Chat Champion
smallfrowne |
bikenut |
Posted: 13:17 - 06 Jan 2017 Post subject: |
tinmans, as mentioned bakers fluid, also fluxite, don't forget to "mushroom" the cable end, as that and the solder stops the cable from "pulling thru", and "tin" the cable and nipple. a large copper soldering iron and camping gas stove or similar is best, when the flame turns green, the copper iron is ready.
note, you ate supposed to clean the cable etc, where its tinned and/or soldered. Get a good wire cable cutter like a felco or similar and prepare the cable out also.
re read.
The bigger the copper iron the better, more heat transfer, don't forget about the damp clean rag and be careful about the fumes.
Note, the oe jap "braided" cables of the 60/70/80/90's etc was a real bugger to clean, it tended to trap any lube that was there, or wasn't, as the cables where usually broken right by the handle bar lever nipple end.
New cable however is a joy, a regular weekend job from the weekend bikers with broken cables 150 miles from home at the time, regular a clockwork with out fail, usually just before finishing time on a sunday!!
The jap alloy "nipples" are cast onto a prepared mushroomed cable. ____________________ nuts about bikes |
SixFeetOfMan |
SixFeetOfMan L Plate Warrior
Posted: 00:17 - 11 Jan 2017 Post subject: |
Plumber solder is lead free, lead is a poison soluble in water...
60/40 is still used for repair of non ROHS products, aviation and military use, probably medical too.
60/40 is illegal only when used to repair/produce ROHS marked product.
60/40 is best for your purpose as it melts lower and flows better than any other solder wire.
Use of flux paste makes life much easier when soldering difficult materials.
Just dip cable before heating, wash with alcohol after cooling down to prevent corrosion.
Unsuitable for use with open flame. |
NutsyUk |
NutsyUk Nearly there...
Posted: 13:25 - 11 Jan 2017 Post subject: |
I think it was Owdamer lost sight in one eye soldering?
A forum search reveals TheShaggyDA once had a soldering injury very close to an eye. And I quote:
"I also had an accident whilst soldering, wearing just a bathrobe that wasn't quite done up" ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
NutsyUk |
smallfrowne |
The last post was made 7 years, 106 days ago. Instead of replying here, would creating a new thread be more useful? |
