Meshuggah |
Meshuggah Scooby Slapper
Posted: 18:21 - 03 Jan 2017 Post subject: Heat grips not working |
hello everyone.
I bought a Tiger 800 and it came from the previous owner with the original triumph heated grips installed... but they didn't work.
So today I decided to look into it. the fuse has been replaced, it was fine but I replaced it anyway.
The relay also was replaced but nothing. They still don't work.
No light on the button and no sign of life.
Any ideas why? thank you.
Also while I'm at it, could someone tell me what is this? I found it attached to the battery. Looks like some sort of a charger...
https://postimg.org/image/p1o0lhtrr/
https://postimg.org/image/4dje0l51j/ ____________________ Triumph Tiger 800 2012 |
CaNsA |
CaNsA Super Spammer
Meshuggah |
chris-red |
Meshuggah |
Billynomates |
Billynomates L Plate Warrior
andys675 |
andys675 World Chat Champion
MotorcycleMD |
MotorcycleMD L Plate Warrior
Posted: 07:06 - 17 Jan 2017 Post subject: |
I have made a couple of repairs on heated grip systems. Most of them on Honda bikes, but this check may apply to yours!
If the grips use a two wire harness leaving each left and right grip you can check resistance through each grip to make sure the grip's winding hasn't broken.
Simply unplug that grips harness and back test the "grip-side" harness. Your looking for any kind of Ohm's reading. Test both to see if they are either giving the same reading or different readings.
If one gives you no reading and the other does than that may be the problem child. Some heated systems require the entire system to be working properly to function at all.
Example being: On the GL1800 wing that is equipped with heated seats and grips, If the seat goes bad, the grips won't work either. Doesn't mean the grips are bad, you just need to find the failed part.
Hope this helps! ____________________ Red level certified Pro Honda Technician. Founder of https://www.MotorcycleMD.com
A site designed to teach riders more about their bike and gain confidence to fix, diagnose, and make repairs on their own. |
The last post was made 7 years, 98 days ago. Instead of replying here, would creating a new thread be more useful? |
