sutty86 |
sutty86 Trackday Trickster
Posted: 12:24 - 08 Jan 2017 Post subject: Help - Scooter Will not idle down |
Reasembled carburettor after stripping and cleaning
Now I get this symptom
I've tried adjusting idle screw, and fuel mix screw on side of carburettor
Cvek305
The bike just keeps the power, never idles down, it sometimes gains more power also
Video will explain better.
Vacuum leak?
https://youtu.be/OeJHf1Xdo4M
Also checked throttle cable is snapping back to normal position (not stuck) |
..... Quote Me Happy
bypass2 |
bypass2 Spanner Monkey
Posted: 20:05 - 08 Jan 2017 Post subject: |
Did you take the diaphragm, throttle slide and needle out?
If you did, I'd suspect these not being put back in correctly first. In particular, it's not unusual for the needle to become dislodged or pushed up as you put it back in if it didn't drop bang-on down the middle of the main jet tube first go.
It's also surprisingly easy on many bikes to put it in backwards.
Next suspect would be an air leak. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
sutty86 |
sutty86 |
Posted: 22:06 - 08 Jan 2017 Post subject: |
sutty86 |
The last post was made 7 years, 108 days ago. Instead of replying here, would creating a new thread be more useful? |
