(Car) BMW 330d E39 Valve seal replacement.
PostPosted: 18:42 - 10 Jan 2017    Post subject: (Car) BMW 330d E39 Valve seal replacement. Reply with quote
Anyone have experience with this? A good friend thinks he needs these doing as the car is billowing blue smoke. I'd like to help him out if I can as I owe him, I think it's a scrapper if we can do it cheap.
stickybackbob
PostPosted: 21:15 - 10 Jan 2017    Post subject: Reply with quote
Constant billowing blue smoke is usually knackered rings/bores. Valve seals on the way out usually blow smoke after a reasonable time not running (e.g. overnight), when lifting off the throttle for a gearchange or after coasting downhill for a while. Never come across stem oil seals that far gone that oil is constantly getting into the cylinders but could be wrong.
V2
PostPosted: 21:25 - 10 Jan 2017    Post subject: Reply with quote
Not sure if that model has one (it probably does) but a cheaper thing to check out first is the CCV valve, make sure the membrane is not damaged allowing oil to seep into your intake, if I remember rightly on my e39 you can check it by taking off the oil filler when the engine is running, the engine should stutter and struggle to run if the vent is damaged or not, cant remember which way it was! mine was a 6 cyl petrol though! also when revved it would have an induction noise almost like when you have one of those cheapo cone filters fitted! Good luck!
Fizzoid
PostPosted: 11:31 - 11 Jan 2017    Post subject: Reply with quote
So it doesn't really clear?
Is it worse if it's left idling?
Sure it's not the turbo that's on its way out?
Rogerborg wrote: It'd certainly make it easier to ego-find my own posts on pages, given the number of fags (gay like traps) who insist on putting my name in their .sig
PostPosted: 11:45 - 11 Jan 2017    Post subject: Reply with quote
I haven't seen it yet, he said its really bad he isn't driving it because of the amount of smoke.
How can I confirm if it is the turbo?
Fizzoid
PostPosted: 11:55 - 11 Jan 2017    Post subject: Reply with quote
Well, a common symptom is when left idling for a while, then when revved, it will produce blue smoke in the exhaust which should eventually clear. Same at start up.
Problem is, that's also a similar symptom to if it is valve seals. If you can access the turbo, check for play in the shaft. Does it make a whining/whizzing sound when the turbo spools up?
PostPosted: 12:55 - 11 Jan 2017    Post subject: Reply with quote
He's having a play now the EGR looks absolutly caked in shit, Problem or Symptom?
Fizzoid
PostPosted: 13:04 - 11 Jan 2017    Post subject: Reply with quote
Both! Smile
It's probably a symptom of the oily smoke it's producing, and probably causing a separate issue
Can he/you check it for any fault codes?
PostPosted: 13:09 - 11 Jan 2017    Post subject: Reply with quote
Fizzoid wrote:
Both! Smile
I have a BT odb2 so can if they work for BMW I'm guessing a light would come on on the dash though
Fizzoid
PostPosted: 13:11 - 11 Jan 2017    Post subject: Reply with quote
Should do, unless the EML has been 'doctored' to pass the MOT?
onlyJaz
PostPosted: 15:04 - 11 Jan 2017    Post subject: Reply with quote
E39 is a 5-series, so I'm guessing he has a 530d. But anyways that doesn't make much of a difference with this advice:
After changing the valve seals (sorry I don't know much about this), get the EGR removed, remap and replace turbo seals if the turbo is causing any leaks. Problem diminished and power increased
"JazHands emoji"
Yamaha YBR 125
Nb
PostPosted: 19:52 - 11 Jan 2017    Post subject: Reply with quote
Blue smoke will be oil being burnt, got a video of smoke? If its a shit load of blue coming out then its normally the turbo.
You can look for codes but i doubt you will find much.
And EML has fuck all to with the mot Fizzoid.
Egr sticking normally produces thick black smoke and lack of power. Thumbs Up
Fizzoid
PostPosted: 13:07 - 12 Jan 2017    Post subject: Reply with quote
Should have been more clear...
It'll be flagged as an advisory, or at least should be. May have been doctored to not be flagged as having an issue.
Mate bought an Audi A3 and it'd had the EML light coloured in with a Sharpie or something similar
PostPosted: 14:55 - 12 Jan 2017    Post subject: Reply with quote
He started stripping it and sent me a load of pictures.
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170111-WA0000_zpsazpje0st.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170111-WA0002_zpsmnutibny.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170111-WA0001_zpsiglc9me5.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170111-WA0003_zpsskzgqudi.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170111-WA0007_zpsv7mx846m.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170112-WA0001_zpslmsmldnb.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170112-WA0002_zpsgdmak5bf.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170111-WA0006_zpsawq0putd.jpg
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG-20170111-WA0005_zpszicpbc1t.jpg
Monkeywrenche...
PostPosted: 15:02 - 12 Jan 2017    Post subject: Reply with quote
Theres a lot of oil on the inlets side there, tell him to stop stripping the head and look at the turbo/ intercooler, the latter will probably have lots of oil in it from the turbo oil seals that are gone
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
mas101
PostPosted: 18:11 - 13 Jan 2017    Post subject: Reply with quote
Has he already replaced the crankcase breather filter (ccv) with the vortex version? If not then check that.
Any play in the turbo spindle?
The last post was made 7 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 16 - Page Size: 95.42 Kb
