BillyJ |
BillyJ Nearly there...
Posted: 13:22 - 12 Jan 2017 Post subject: Cush drive rubbers removal Ducati 900SS |
These are how they look (not mine, photo from ducati forum)
https://www.ducati.ms/forums/attachments/supersport/106887d1331488112-cush-bush-removal-easy-cheap-cush-drive-002.jpg
So I need to remove mine, I got 3 out by heating up hub using a mapp torch and getting grips on the centre metal bit and with a little convincing the whole thing freed up and just slid out with ease.
The other 3 have most of the rubber removed and the centres are out so are basically metal sleeves in very tight holes.
How can I get them out....?
Seems only way is either weld a bolt(or random bit of metal) to the inside and heat and pull like the rest
or
cut a slit down the inside without going into the wheel and fold the sleeve in. (I have done this before with a tiny clutch pushrod bearing.) ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser" |
garth |
garth World Chat Champion
jaffa90 |
jaffa90 World Chat Champion
mattsprattuk |
mattsprattuk Super Spammer
Posted: 23:55 - 12 Jan 2017 Post subject: |
They're a bitch. Enjoy.
Slitting them is almost the only way. Another is to chisel from the outside inwards to buckle them so they fall out. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
scotto75 |
scotto75 Renault 5 Driver
BillyJ |
Posted: 20:47 - 14 Jan 2017 Post subject: |
Done...
Thank f*ck for that...
Those last three were a real bitch.
Tried cutting a small slit in the outer shell and folding it in to get a set of grips on them and then heat and slide out like the rest.
Unfortunately being a bit of the casing that was being pulled on meant it was impossible to pull straight up and and they just wouldn't budge. Ended up cutting all the way down and folding them in, the one on the right was the real hard one to get out.
https://s28.postimg.org/9ys2t5ij1/IMG_20170114_WA0004.jpg ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
The last post was made 7 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
