Conker92 |
Conker92 Two Stroke Sniffer
Rogerborg |
Rogerborg nimbA
Posted: 17:31 - 12 Jan 2017 Post subject: Re: Yamaha ybr125 high performance ignition coil? |
Do you think a YBR coil will fix this?
Conker92 wrote: | So i got my Honda cg125 back from the garage and it turns out it needs a replacemnt crankshaft or new engine all together. |
It's red, it will automatically add 10mph. Which in your case should get you up to... 10mph.
The semi-serious answer is that it's marketing blurb. I fitted one to my copybike for a laugh (and on the tenuous reason that a random intardtuber reckoned the stock ones were rubbish), it achieved nothing. It may even have contributed to bad running after sustained high revs. Probably because it was every bit as rubbish as the stock one.
Mine was orange though, so would only have added 5mph, tops. ____________________ Biking is 1/20th as dangerous as horse riding.
Conker92 |
Rogerborg |
Rogerborg nimbA
Posted: 17:39 - 12 Jan 2017 Post subject: |
Did you replace it with a YBR engine?
Oh, I've just remembered! Mine was actually red and orange.
https://2.bp.blogspot.com/__DYtEEjm5wE/SgSLvptpfMI/AAAAAAAAAE4/0Rvl7yQc-mM/s1600/coil.jpg
I fitted it because the plug caps on the stock ones were actually claimed to cause problems with arcing and RF interference. Not that I had any basis for believing that the replacement was any better. But... red and orange.
tl;dr version - don't replace it if it ain't broke. ____________________ Biking is 1/20th as dangerous as horse riding.
Conker92 |
Rogerborg |
Rogerborg nimbA
Posted: 17:46 - 12 Jan 2017 Post subject: |
Come now, I've trolled a lot more than your 25 posts. ____________________ Biking is 1/20th as dangerous as horse riding.
pompousporcup... |
Posted: 17:59 - 12 Jan 2017 Post subject: |
Thats not trolling. I knew what he meant |
Andy_Pagin |
Andy_Pagin World Chat Champion
Evil Hans |
Evil Hans World Chat Champion
onlyJaz |
onlyJaz Scooby Slapper
ThatDippyTwat |
notbike |
notbike Formerly known as notabikeranymore
BillyJ |
BillyJ Nearly there...
Posted: 01:53 - 14 Jan 2017 Post subject: |
One of the reasons they are used is when running compression so high that a spark can't form in the cylinder or using a plug with a bigger gap you can't get a spark at the stock coil voltages.
The super high performance coils generally makes the voltage higher.
So the point I'm making is that you need to add a high flow pod air filter and a high performance coil to really feel the difference. Sometimes with all the added air flow and big sparks your cylinder pressure will be too high so you need to loosen the spark plug by about 2 turns.
HTH ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser" |
Rogerborg |
Rogerborg nimbA
BillyJ |
Rogerborg |
Rogerborg nimbA
Posted: 13:10 - 15 Jan 2017 Post subject: |
That seems... reasonable. I did some physics, so my gut instinct is to consider everything to be spherical and in a vacuum. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 7 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
