Fuse size ?
Ebbs73
PostPosted: 14:32 - 15 Jan 2017    Post subject: Fuse size ? Reply with quote
Hello peeps
I've gained some heated gloves and a heated jacket for my elephant rally trip , I'm going to connect them up with a in line fuse so
The jacket states it's 150watt and the gloves are 30 watts each .
I've had a look at the ohms law , I=P/v , I've got 17.5 amp ?
I'm hoping I've missed something or that's a massive draw .
If so would my ER5 handle this plus a sat nav and phone charger ?
Thank you
Chris
ZebraDriver
PostPosted: 15:07 - 15 Jan 2017    Post subject: Reply with quote
Your calculations are correct current draw will be 17.5 amps. Don't know the alternator output for an ER5 but have you considered a trailer holding a generator for your trip.
Ebbs73
PostPosted: 16:21 - 15 Jan 2017    Post subject: Reply with quote
I was hoping I was wrong , seems a lot current on an older bike .
I'll have a nose for the alternator rating .
Trailer would look cool full of batteries .
Thank you
jaffa90
PostPosted: 18:27 - 15 Jan 2017    Post subject: Reply with quote
Heated jacket! Wrap a full newspaper around your midriff like i did in the early 70`s.
PostPosted: 00:16 - 16 Jan 2017    Post subject: Reply with quote
WTF?
210 watts for heated jacket and gloves?
Not sure your alternator will even put that out, if it does
I seriously doubt the charging system will have anything near that as spare capacity.
Broadly speaking you're probably ok up to say 50W/4A on most bikes,
after that you're chancing it.
Tip:
Insulate first, heat after
the better you insulate/protect the less you have to/need to heat.
bugeye_bob
PostPosted: 00:25 - 16 Jan 2017    Post subject: Reply with quote
if its a high load, what about fitting a couple of these so you can switch between jacket power and gloves power,
https://www.ebay.co.uk/itm/Universal-Motorcycle-Kill-ON-OFF-Switch-Button-Handlebar-Mount-Bullet-Connector/351195138428?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D8ae8ee57e3e3420c9a14c17b52d4867e%26pid%3D100338%26rk%3D2%26rkt%3D20%26sd%3D331639821919
The last post was made 7 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.16 - MySQL Queries: 17 - Page Size: 48.37 Kb
