Project Roxy
PostPosted: 18:32 - 15 Feb 2017    Post subject: Reply with quote
pepperami wrote:
Err Hello! it`s been five days since we heard anything about this bike and I am starting to get withdrawal symptoms Sad
Was gonna work on it at the weekend, I got all ready to drag it out but it was snowing. Decided to stay in in the warm. Laughing I might had another look Saturday, weather and enthusiasm dependent.
PostPosted: 19:31 - 18 Feb 2017    Post subject: Reply with quote
Bulbs finally arrived!
My idea worked the Indicators are great now.
https://youtu.be/bF9lMf8RTvQ
Annoyingly the flasher has a warning noise. I can't see a way to mod the existing flasher so I'll have see about getting a new one. The horn appears to have died. I have ordered a new one. No great loss it was pretty rough looking.
I kicked the bike over and gave it a bit of a rev and noticed a pretty sizable dump of oil out of the exhaust drain.
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG_20170218_114441_zps0ekulsuo.jpg
As I have to remove the exhaust anyway to get to stand I thought I might as well de sludge it, a trip to the chemists for some caustic soda later...
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG_20170218_151155_zpscsyy4ieh.jpg
Exhaust is filled with a mix of water and caustic soda and the bin just with water. I left this for a few hours, then rinsed it. A decent amount of sludge and lumps of carbon came out.
Next I stripped the main stand, you can see how bad the slack is here!
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG_20170218_150957_zpsdqxb33uf.jpg
Bodgetastic.
https://img.photobucket.com/albums/v295/chris-red/Mobile%20Uploads/IMG_20170218_151010_zpsamsmruwy.jpg
https://youtu.be/TEZN1EwmKgk
Much better as you can see.
Also cleaned up the stand/brake/arm/rod as they were fairly tatty. They'll get a few coats of Hammerite later.
pepperami
PostPosted: 11:58 - 20 Feb 2017    Post subject: Reply with quote
Just looked at the video of the indicators.
They seemed a bit quick?, just a thought.
PostPosted: 12:27 - 20 Feb 2017    Post subject: Reply with quote
Slightly maybe, however 10 times better than how they were before.
I reckon they flashed once every 2-3 seconds before.
PostPosted: 12:42 - 20 Feb 2017    Post subject: Reply with quote
I watched it too. 102 flashes/min. Should be between 60 and 120fpm for the MOT so all gravy.
I really like that plumbing olive bodge. Thumbs Up
Now. Next thing to do is find a way to prevent the pin rotating in the lugs and wearing your olives, you really want it so the stand has to pivot on the (greased) pin.
Not sure how the pin's retained. If it's a split pin, use a bit of stiff wire (bicycle spoke is great) instead and twist/hook the long end round something. The lugs the stand return spring hooks over are usually good. If it's circlips, might even be worth drilling the pin and lockwiring it.
Did it on my enfield, they're really prone to the same problem. I did the spoke trick on mine and while I've just had to replace the stand, it's because it started to buckle, the holes in the frame are still nicely circular.
https://i48.photobucket.com/albums/f216/stinkwheel/distributor/Image001.jpg
PostPosted: 13:08 - 20 Feb 2017    Post subject: Reply with quote
Good should cheers Thumbs Up
pepperami
PostPosted: 16:04 - 20 Feb 2017    Post subject: Reply with quote
You sir are a smart cookie Thumbs Up
PostPosted: 16:52 - 20 Feb 2017    Post subject: Reply with quote
I'm not sure I have enough room to drill a hole as the circlip is in the way. I might see about drilling the shaft the other end and using a small pin to lock it.
PostPosted: 22:49 - 25 Feb 2017    Post subject: Reply with quote
I came to start working on this today and was greeted buy FUCK loads of oil.
This is after a clean up.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_094518_zps2xqfm9kb.jpg
After a bike of investigation it seemed to be coming from the alternator casing. I was confused by this as there shouldn't be any oil in there!
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_094539_zpspuitjehv.jpg
I started removing the casing and was briefly stopped by a striped bolt. However using my never fail method it was removed in seconds.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_095131_zps7hntjrq4.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_095159_zpsn63wdcsh.jpg
It looked a bit sludgey behind the casing.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_101409_zpspcv1cmuy.jpg
I noticed the sprocket was a bit worn, as I wanted to remove it to check the output shaft seal and I had a a spare brand new chain from when I bought the bike (12 years ago!) I decided to replaced the set JT Front and Rear Sprocket £15 delivered! Probably the cheapest C&S I've ever done.
My impact driver wouldn't touch it So I got to use my BFB for the first time Very Happy
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_113632_zps56zzwoqd.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_113656_zpsrq8kxerz.jpg
Pissed it Laughing
I cleaned up the area and couldn't see anywhere the oil was leaking from I checked the oil and it was bang on Confused the sheer volume it dropped it should be low.
When I filled it up I just lobbed in 700ml which is what the manual said. I didn't actually check the level, I am assuming it was some kind of overflow.
I'll leave the cover off for a while and try to track it.
On a plus note my new horn arrived and it unintentionally matches the bike!
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_105849_zpsmx1rkw0k.jpg
Pu the freshly painted stand and brake lever on too.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170225_113600_zpsu4rfwpcf.jpg
Also I didn't mention or photograph. After the last stint the join in the exhaust was wobbly, without any real effort I managed to pull the front section off. I need to remove the castle nut from the back section, but it is seized solid. I took to my dad's to use the vice but long short should I haven't done it yet.I hope to do it during the week.
pepperami
PostPosted: 15:39 - 26 Feb 2017    Post subject: Reply with quote
Are you running it on pre-mix or separate via the oil pump?
Could there be a leak to do with this?
Still a cool thread Thumbs Up
redeem ouzzer
PostPosted: 15:50 - 26 Feb 2017    Post subject: Reply with quote
Wrong side for 2T leak. It's probably an oil seal or cracked neutral sender.
Be a REAL MAN!
PostPosted: 11:45 - 27 Feb 2017    Post subject: Reply with quote
Plus the 2t oil is red this is golden.
ride_to_die
PostPosted: 12:46 - 28 Feb 2017    Post subject: Reply with quote
Project coming along nicely Thumbs Up
I'm not here for a long time, I'm here for a good time.
PostPosted: 19:18 - 09 Apr 2017    Post subject: Reply with quote
Had a bit more time to fiddle Yesterday I'm adjusting to working on a patio, I bought this for £30 on eBay and I'm chuffed with it it does make things easier.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_094546_zpsa5skfr4d.jpg
I was hoping to get the thing finished but was thwarted by a sprocket carrier bearing that was knackered.
I need the rear wheel in to put the new chain on to tighten the front sprocket to put the side engine casing together. I could get round it but I couldn't be arsed buggering about I'm not in a rush so I'll wait new bearing has been ordered anyway.
The rear brake was pretty dirty and had some corrosion on the drum so that might be why it was a bit grabby it got a thorough clean.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_094554_zpsbkjwkmkb.jpg
The sprocket carrier was equally as filthy.
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_094602_zpsu5t2pmqr.jpg
I also got to use my house warning present from my dad for the first time...
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_095405_zpsd8kghx4n.jpg
Not the spindle, it was fucker to get out, it wasn't far off seizing it was bone dry.
The rim cleaned up well, and you can see several marks of a quality tyre Laughing
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_101107_zpshgcpilub.jpg
https://img.photobucket.com/albums/v295/chris-red/IMG_20170408_100335_zps2el1ooqg.jpg
I got to use my* new very expensive professional caliper for the first time to measure the bearing.
*I found it when we moved, I asked my missus about it she said I "My dad got it from work for me to borrow when I was doing my dissertation(on teeth)" Do you want it? I asked, "Nah you can have it" I looked it up they are like £120 new. Laughing
I always wondered now my dad ended up with so money high end tools considering he is tight as a ducks arse, I guess you just acquire them, I got this and I was given a Fluke meter That is about £300 worth recently!
I have some more photos and a video but I'm using my phone to watch the GP ATM I'll upload them later
PostPosted: 22:46 - 09 Apr 2017    Post subject: Reply with quote
Lots of heat directly on the castle nut. If it doesn't loosen it, you might get some flame-organ action anyway.
PostPosted: 23:20 - 09 Apr 2017    Post subject: Reply with quote
I forgot to mention i had a good go at this a week or 2 back, plenty of plusgas and heat it didn't budge the best thing i could find to turn it was a file it is about 18" long and about 1/4 thick. I put it between the crenallations of the nut and put a decent amount of force through it. It didn't budge and I could feel the file starting to flex so I gave up. The plan was to cut the nut off i had a replacement from the job lot of spares I bought. I think I paid £20 for the lot and the nut is £20 new so it paid for itself! I ordered so 1mm cutting discs for the grinder to do the job but hadn't had a chance to get back to it untill Tuesday.
Long story short, my mate had to drop a ladder he borrowed from my dad (it was actually his blow torch i borrowed too) I said I was going anyway so he came with. I told him what I was gonna do and he asked if I was sure it wouldn't undo. Smugly I said "Be my guest", he is half the size of me so no chance it would budge. He put it in the vice picked up the same file as I had and tried to undo it... With minimal effort it slid off! It's a weird feeling being simultaneously annoyed and happy! I can only assume the plus gas had had more time to work. It's all back together now with fresh gaskets and plenty of copper grease.
I have a spare exhaust that is ratty I'm going to practice on it with my welder to see if I can use it to sort some of the holes. The one on the bike isn't bad but it has 5-6 holes that will need to be addressed. Exhausts for these in reasonable nick are rare. Unless you go for a spanny, but they cost about what it is worth, also the bike is for my missus who has never ridden before the last thing she needs is a sharp power band.
PostPosted: 15:51 - 10 Apr 2017    Post subject: Reply with quote
https://www.youtube.com/watch?v=E5M0_xtHVHA
I R TUNING MASTA
The audio quality makes it sound ropey but it is smooth as silk.
The idle is back to a sensible 1200 now. Thumbs Up
The last post was made 7 years, 16 days ago. Instead of replying here, would creating a new thread be more useful?
Page 2 of 2
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.2 - MySQL Queries: 17 - Page Size: 114.04 Kb
