No lights or dash besides headlights - Please Help!
FuzzyBallz
PostPosted: 10:47 - 29 Jan 2017    Post subject: No lights or dash besides headlights - Please Help! Reply with quote
I've just fitted an aftermarket headlight on my CBR600FY, completely removing the original front end.
The headlight doesn't have turn signals so I fitted a pair of handguards with LEDs in and I wired those up to my indicators.
I had a small problem at first were the right turn indicator would only work with the headlight on. This morning I was switching wires and managed to get it all working properly. Indicators worked with the headlight on or off. Voila, I was a happy chappy.
Then seeming as I didn't have any low beem lights I thought about using the side LEDs on the light for my low beem, so I put an old indicator bulb between the 2 wires on the loom to see if it would light up and nothing happened, probably because the other end at the light is just taped at the moment. DUH
I also flicked my high beam switch a couple of times to see if that would do anything but didn't.
After I done all that only my headlights will work. When I turn the ignition key I've got no neutral light, no oil light, my indicators don't work, my tail light doesn't work, neither does my brake light.
The bike will start and tick over fine, it's just the lights that won't work.
I've checked the 10A fuses under the seat and they are all fine. What could have blown / happened to make all these lights just stop working at once? Have I missed any fuses?
Cheers! I'm desperate to get it up and running again as I haven't been out on it for a while - Please Help!!
The whole dash isn't working, speedo or rev counter isn't moving either.
FuzzyBallz
PostPosted: 14:45 - 29 Jan 2017    Post subject: Reply with quote
Turned out to be tail light fuse (>.<)
The last post was made 9 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.87 - MySQL Queries: 14 - Page Size: 32.5 Kb
