BillyJ |
BillyJ Nearly there...
jaffa90 |
jaffa90 World Chat Champion
sickpup |
sickpup Old Timer
BTTD |
BTTD World Chat Champion
BillyJ |
Posted: 12:15 - 08 Feb 2017 Post subject: |
sickpup wrote: | Does it have the carb warming kit? |
I only found out about these while researching this problem and as far as I can tell no it doesn't (what is the tell tale giveaway?)
sickpup wrote: | How recently were the plugs changed? |
About 18 months ago but they look in good condition and haven't had a lot of miles on them
sickpup wrote: | Does it have a modified air box? |
Nope
sickpup wrote: | Might even be the coils. |
Haven't checked coil resistances but will do
sickpup wrote: | Fuel is easy to check, take the pipe off the bottom of the tank and see if fuel runs out. |
I'll get a chance to properly look at it all on the weekend so I'm going to test the fuel pump is pumping out enough then.
jnw010 wrote: | Have you shone a torch in the tank to see if there is any crap floating about, or if the inside of the tank has a thick layer of dried fuel varnish? |
I haven't, I will.
The tank is a bit rusty on the inside but not too bad as I did electrolysis clean it about 2 years ago. ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
Have: '13 GSXR-1000 + '01 CB500S
"The aryan confuser" |
sickpup |
sickpup Old Timer
BillyJ |
Posted: 14:27 - 11 Feb 2017 Post subject: |
Yes it has the carb warming kit.
I got a pair of the DR8ES-L to fit
Air box is 100% standard with the standard holes in the top of the box, only non standard thing is the air filter, it's a K&N as the original washable one wasn't there when I got the bike.
Will change the HT leads, the leads look ok from the outside but I don't know how old they are.
I have a feeling that the tap on the bottom of the tank wasn't fully undone.... maybe that caused the issue...
Since I have the new gaskets though, carbs will be off today and cleaned etc another day. ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
sickpup |
sickpup Old Timer
BillyJ |
sickpup |
sickpup Old Timer
jjdugen |
jjdugen World Chat Champion
sickpup |
sickpup Old Timer
BillyJ |
BillyJ |
Posted: 18:22 - 21 Mar 2017 Post subject: |
jaffa90 |
BillyJ |
Matt B |
Matt B World Chat Champion
P. |
P. Red Rocket
BillyJ |
jaffa90 |
Matt B |
P. |
P. Red Rocket
redeem ouzzer |
Posted: 18:50 - 22 Mar 2017 Post subject: |
I have stuff to learn about setting up and tuning engines?
Really?
____________________ Be a REAL MAN! |
jaffa90 |
BillyJ |
Posted: 19:07 - 22 Mar 2017 Post subject: |
jaffa90 wrote: | Sounds like your bikes need sorting.
Fazer 1000 detuned R1. Ivans jet kit sorted it from 1,000rpm upwards.
Bandit 1200 last of the carb models fitted a denser air filter but also needed jets sorting.
KLV 1000, fuel injection bag of crap up to 3,000rpm, power commander fitted by Hobbsport racing sorted this one from 1,000rpm upwards
CBF 1000, ok would pull from 2,000rpm in top gear after slowing down, nothing needed, as many of my other bikes. |
We get it, you're are an idle pro
EDIT: and about your new bikes emissions bollox, I have a 1980 CB250RS which will not idle properly if its less than 1300RPM and this Ducati is 1993.
And the agency responsible for monitoring emissions wasn't formed until 1995...
https://en.wikipedia.org/wiki/Vehicle_emissions_control#United_Kingdom
https://en.wikipedia.org/wiki/Environment_Agency ____________________ Had: '06 CBR125R + '01 GSF600 + '07 SPRINT ST 1050 + '80 CB250 RSA + '93 Ducati 900SS
The last post was made 7 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
