Radiomax10 |
Radiomax10 L Plate Warrior
davebike |
davebike World Chat Champion
Posted: 12:08 - 13 Feb 2017 Post subject: |
Done a fair bit on silver wings Sadly the transmission /clutch is the weak point
I suspect worn or damaged transmission rollers or pull away clutch
It is transmission strip down time be careful silver wing belt rollers and clutches are very expensive ! ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
cb1rocket |
cb1rocket World Chat Champion
Posted: 18:27 - 14 Feb 2017 Post subject: |
I belive he is referring to the S wing 125. Not the 600 silver wing.
The bearings on the rear clutch assembly is probably shot. I have dealt with 5 s-wings and they all make a racket from the transmission. Is fixable and like you says go away after speeding up as the axle and bearings run at the same speed so no bearing movement. ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
Radiomax10 |
cb1rocket |
Posted: 16:49 - 20 Feb 2017 Post subject: |
you would hear it if you spun the clutch once the bell housing is off.
Vibrations is possible but usually from a slack/worn belt ____________________ Honda H100S2 Rebuild - https://www.bikechatforums.com/viewtopic.php?t=253852 |
The last post was made 7 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
