johnsmith222 |
johnsmith222 World Chat Champion
BTTD |
BTTD World Chat Champion
RhynoCZ |
RhynoCZ Super Spammer
jowettdriver |
jowettdriver Borekit Bruiser
johnsmith222 |
johnsmith222 |
Posted: 20:14 - 15 Feb 2017 Post subject: |
RhynoCZ wrote: | You can get pretty close with the basic method (being offset should not change the result), but I'd still just bring the wheels to my local tyre shop and ask them to check the balance.
I don't quite understand the urge to change your own car tyres. Although it is nice to save some £££ doing as much as you can yourself, the car tyres last much longer than motorcycle tyres, meaing you don't have to change them that often. Unless you're doing track days in your car, of course. |
Thanks Rhyno, That's good to hear that they can be balanced close with the static balancer, although taking them to be checked at a tyre shop each time would defeat the purpose of balancing them myself.
That's fair enough if you don't understand changing car tyres. I guess part of it is I enjoy the hobby side of working on my own vehicles, and tyres is one of those jobs which is always going to need done. Part of it is being a cheapskate, as it lets me buy brand new tyres online and fit them myself, rather than being restricted by whatever tyres are in stock at local places).
I've heard to expect to pay roughly £60 a tyre including fitting, compared to £40 from oponeo for some reasonable budget ones, so for my first set, it would save me £80. I'd rather put that £80 towards new tools, than pay for fitting .
Part of it is the convenience side of things. Working 6 to 7 days, it's more convinient for me to fit a tyre in the evening myself, rather than booking in.
I've also got friends with similar hobbies, such as breaking cars etc, and we always share tools between us, so it would get more use than just for my own car. |
johnsmith222 |
Posted: 20:20 - 15 Feb 2017 Post subject: |
jowettdriver wrote: | I have the Clarke version of the tyre changer you have linked to and have changed loads of car tyres on it. I even changed the van tyres on my campervan using it. I have always used nylon rim protectors with the supplied steel bar but am now looking to buy a bar like you have linked to as the alloys on my new car are perfect and I want them to stay that way!
As for balancing I have a motorcycle tyre balancer and I turned up some suitable adapters to fit car wheels and have balanced all of my car tyres using it with excellent results. After balancing all of my wheels have run without wobble or vibration to in excess of 100 mph (private road of course).
Downsides are that it takes some effort for some tyres. The supplied bar is a little short and sometimes requires two people to work it. For a long time I used mine without fixing it down and then about 3 months ago I got so fed up that I drilled and epoxyed 4 threaded inserts into a concrete pad to fix the changer down. This has made it so much easier to use.
Cheers Tim. |
Hi Tim, can i double check which tyre changer is is that you have, as I linked two? I know these changers get sold under various names, but I'm convinced they're all made at the same place, so your experience with your clarke one is really useful
I have quite a few rim protectors that I use on the bike, but I think I'd end up just going for the bar meant for alloys if I was doing my car. That way less worry about damage
That's interesting to hear about your experience balancing with the car wheels. I also have a motorcycle balancer, so I could attempt something similar, although I don't have access to a lathe, so would likely end up just getting one of the bubble balancers.
Wow, I'm surprised you even got it to work without fixing it down! I did see some people fixing it to a wooden pallet, so was considering doing that as a temporary measure, until I could do exactly what you said, and use threaded inserts. I'd need to do that so I could move it out the way when I'm not using it, as I understand I'd need space to work. |
iooi |
iooi Super Spammer
RhynoCZ |
Posted: 21:37 - 15 Feb 2017 Post subject: |
I'm not sure about UK, but here the tyre shops charge per procedure.
Tyre off = £££
Tyre on = £££
Balancing = £££
Each individual weight = £££ per 1g
Valves and air = free of charge
So if you did the tyre off and on, then balanced it, then brought it in to check the balancing job you've done, and if alright, you'd only pay one charge £££, per wheel of course. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
BTTD |
jowettdriver |
Posted: 09:36 - 16 Feb 2017 Post subject: |
bluezedd wrote: |
Sorry chap turns out the one I have is made by Sealey, because its bright red I tend to think Clarke!
Its this one https://tinyurl.com/zocfwyh although I'm fairly sure I didn't pay that much for mine. Its built fairly well and I've not managed to bend it other than the supplied bar which did get a little bent doing van tyres!!
One thing I would recommend with balancing is that I bought a couple of kilos of the self adhesive weights that stick on normally intended for alloy wheels. I use these on steelys as well and its really easy to stick them on with a bit of masking tape to play around with getting the balance right before you peel off the back and stick them for good.
Other advice I can give is that tyre soap is invaluable, washing up liquid etc does not work the same. Also I bought a box of new valves and the thread on tool to pull them through for a few pounds as its always a good idea to change the valves out when changing tyres as they do deteriorate in the sun.
I tried the pallet idea for securing the changer and have to say it didn't help that much for me. For the sake of about £20 for the inserts and epoxy I wish I had sorted my fixings sooner! Yes you will need room to walk all the way around it.
With regard to low profile tyres, I have just put a pair of 225 45 17's on my Z3 and have to say they were some of the easiest I have changed. The hardest were a pair of new Metzlers on my CG - go figure! In my experience it doesn't seem to be the profile but more how stiff the tyre carcass seems to be.
Hope this helps.
Cheers Tim. ____________________ Bikes: 1980 Honda CX500, 2003 Honda CB250, 1980 Honda CG125 |
The last post was made 7 years, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
