How to remove stuck baffle? - Removed.
Hong Kong Phooey
PostPosted: 00:03 - 15 Feb 2017    Post subject: Re: How to remove stuck baffle? Reply with quote
Fazer. wrote:
As title how to remove a stuck exhaust baffle?
I've had it out before but refitted it for the winter. Today I have been riding hard enjoying a hint of spring and yearned for the snap crackle and pop.
Had a go at it tonight the same way I removed it originally with a set of needle nose pliers but it is stuck solid.
Solutions?
Just revisit this post in about an hour. Someone will say something to make you angry. The baffle won't like it when you're angry.
Either that or your bike is so caked in shit that you can't see the retaining screw.
owl
PostPosted: 00:04 - 15 Feb 2017    Post subject: Reply with quote
Take the pipe off and knock it out from the other side
andym
PostPosted: 00:19 - 15 Feb 2017    Post subject: Re: How to remove stuck baffle? Reply with quote
Solutions?
Pay it 5 ponds
weasley
PostPosted: 09:11 - 15 Feb 2017    Post subject: Reply with quote
Don't remove the circlip/screw and then start the engine. Oh no, don't do that.
UncleFester
PostPosted: 09:14 - 15 Feb 2017    Post subject: Reply with quote
Buy a new engine now for when you screw it up to the point of snapping the exhaust studs when you have to fit a new exhaust because everything from the can back was rusted to feck.
Preventative maintenance. Sure, ACF50 will help but if you wanted it out, you'll learn to keep stuff in good order under it.
Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800.
grr666
PostPosted: 09:40 - 15 Feb 2017    Post subject: Reply with quote
Blowtorch it.
kgm
PostPosted: 09:42 - 15 Feb 2017    Post subject: Reply with quote
Heat the exhaust (not the baffle) a little with a heat gun and clean any crap away. Mine gets stiff if there is residual heat in the baffle itself.
You could run the engine with the retainer out but they can pop out with force so I wouldn't recommend it.
owl
PostPosted: 20:40 - 15 Feb 2017    Post subject: Reply with quote
amazing Rolling Eyes
The last post was made 7 years, 65 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 17 - Page Size: 66.66 Kb
