Hahadumball |
Hahadumball World Chat Champion
jaffa90 |
jaffa90 World Chat Champion
Hahadumball |
jaffa90 |
Hong Kong Phooey |
Hahadumball |
jaffa90 |
Hahadumball |
jaffa90 |
Hahadumball |
jaffa90 |
Fizzer Thou |
Posted: 11:10 - 16 Feb 2017 Post subject: |
Does the VTR1000 run with coils in the plug caps?
Or separate coils and plug caps?
It sounds very similar to the symptoms that I had on the Exup1000 where the original plug caps were discharging the coil energy to the cylinder head instead of to the spark plug.
Inside of a typical plug cap is a resistive element.These can go open circuit and when this occurs the coil energy builds up to such an extent that it bypasses the resistor and passes on to the spark plug.My Exup would be okay above about 3500 rpm but below that it would only run on three cylinders.
If you have a multimeter,the plug caps should measure between 5,000 to 10,000 ohms.On some plug caps the resistor can be removed,as I did, and replaced with a similar length of brazing rod ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
Hahadumball |
Hong Kong Phooey |
jaffa90 |
The last post was made 7 years, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
