Arcane1729 |
Arcane1729 Banned
Posted: 20:22 - 16 Feb 2017 Post subject: Sparks flying when I tried to power something from battery |
I was trying to use this :
https://www.halfords.com/technology/mobile-phone-accessories/multisockets/halfords-universal-in-car-charger-12-24v
to charge my phone
The guy at halfords gave me a fuse for free.
A few weeks ago I put on Oxford heated grips without a fuse and have had no issues at all. Was this a mistake- Am I going to be trouble soon?
I thought because the grips were ok I'd just ignore the free fuse for this in car charger- When I connected terminals without fixing just touching them on the battery plates (connected positive first then negative just after) there was a spark as soon as I connected -ve I released quick then touched again and another spark. Did this twice till there wasn't a spark the final time I touched. Connecting the phone on the other end of the car charger- nothing happened- wouldn't charge.
If you're foolish enough can you totally kill battery beyond functioning repair by miswiring or something like connecting negative first and THEN positive?
the grip heat controller shows green blue then red when I pressed the button so the battery must be alright- I hope it's not the car charger I've killed. ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
Teflon Mike: "A man can dream... but most of them are probably best not voiced.... Folk will likely think you are just mad, sad or simply a pervert." |
iooi |
iooi Super Spammer
Posted: 20:26 - 16 Feb 2017 Post subject: |
One word..... "Workshop" ____________________ Just because my bike was A DIVVY, does not mean i am...... |
ThatDippyTwat |
MarJay |
MarJay But it's British!
Arcane1729 |
Arcane1729 Banned
mudcow007 |
mudcow007 World Chat Champion
Arcane1729 |
Arcane1729 Banned
Posted: 21:34 - 16 Feb 2017 Post subject: |
Ah I see thanks: looks like I have some studying to do... if the fuse inside the charger is blown that does that mean time to throw it away?
It's only £8 but can it be fixed with a new fuse and connecting it the right way?
And also: why do the heated grips work fine when connected to the battery terminal directly?- is this relay thing integrated inside the grips setup which comes in the box to make it idiot proof from people like me? ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
iooi |
iooi Super Spammer
Posted: 21:42 - 16 Feb 2017 Post subject: |
davethekwak |
davethekwak Nitrous Nuisance
Arcane1729 |
Arcane1729 Banned
andyscooter |
arry |
arry Super Spammer
Arcane1729 |
Arcane1729 Banned
Arcane1729 |
Arcane1729 Banned
redeem ouzzer |
andyscooter |
Posted: 21:51 - 17 Feb 2017 Post subject: |
OK where and how are you fitting it as even though the socket me be waterproof the wording doesn't look like it is
Also there is an inline fuse in that
Has it blown and has it been replaced ____________________ gilera runner vxr200 (chavped)
if its spelt wrong its my fat fingers and daft auto correct on my tablet |
ScottT |
ScottT Scooby Slapper
Posted: 22:40 - 17 Feb 2017 Post subject: |
Arcane1729 |
Arcane1729 Banned
Billy Balthorpe |
Billy Balthorpe Trackday Trickster
Posted: 00:51 - 18 Feb 2017 Post subject: |
Arcane, please don't think I'm being arsey, I'm not, I apologise in advance if you have already done any of this stuff but here goes.
Make sure you have connected the red wire to the tang on the bottom marked with a +, then connect the black wire to the tang on the bottom marked -. Now connect the black wire to the battery terminal marked -. Then carefully connect the red wire to the terminal marked +. That's the socket connected. Now plug in your phone charger. If it doesn't work, plug it into a socket in a car with the ignition on, if it still doesn't work, the fuse has probably blown in the charger. Remove the charger and unscrew the plastic bit where the little springy nipple sticks out on the bit you stick into the socket. Be careful because theres a spring in there and it may ping off when you undo it. Inside there you will find a fuse, usually clear glass so you can see if the wire inside has broken due to a surge of power, if the wire is not there or broken the fuse has blown and you need another one, I usually just buy another charger at this point because I can never find a fuse with the correct dimensions. If you just want to replace the fuse, measure its length then look carefully at the metal ends on the fuse, it should have something engraved on it saying what amp/voltage the fuse is rated at, go onto ebay and search for this fuse e.g. 5A/12V 30mm fuse. Get the fuses (usually in packs of 10) fit it carefully in exactly the way it was when you took it apart including the spring and little nipple thing. Plug it back into your socket on your bike, it should now work, if it doesn't, you have probably knackered the charger, buy another one.
Hope this helps. ____________________ M.O.B. Successfully taking the piss since 2014. |
Arcane1729 |
Arcane1729 Banned
bamt |
bamt World Chat Champion
Posted: 01:33 - 18 Feb 2017 Post subject: |
On the 12V socket, the -ve should be to the outer, red to the centre (the centre pin is +V in a cigarette lighter).
https://i.ebayimg.com/images/g/G7oAAOSwB09YCGsJ/s-l1600.jpg
If you've connected them the other way around then you've probably fried the charger. |
Arcane1729 |
Arcane1729 Banned
Posted: 01:52 - 18 Feb 2017 Post subject: |
Fuck. ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
Arcane1729 |
Arcane1729 Banned
Posted: 01:53 - 18 Feb 2017 Post subject: |
But how was I to know- my logic seemed sound...
The outer is the longer one and that is what I connected red to. ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
andyscooter |
Posted: 09:35 - 18 Feb 2017 Post subject: |
the inline fuse in in the black plastic bit halfway down the cable
should be a glass fuse in it which will look black and possible have a broken wire in it if its fubar
https://i.ebayimg.com/images/g/G7oAAOSwB09YCGsJ/s-l1600.jpg ____________________ gilera runner vxr200 (chavped)
Evil Hans |
Evil Hans World Chat Champion
The last post was made 7 years, 40 days ago. Instead of replying here, would creating a new thread be more useful? |
