New Pi Zero W released
Pjay
PostPosted: 10:23 - 28 Feb 2017    Post subject: New Pi Zero W released Reply with quote
https://www.engadget.com/2017/02/28/raspberry-pi-zero-w-is-a-10-computer-with-wifi-and-bluetooth/
Pi Hut and Pimoroni both have limited stocks, if you want to grab one, do it quick. Limited to one per customer.
You can make ££ selling it on Ebay if it turns out not to be needed.
PostPosted: 10:50 - 28 Feb 2017    Post subject: Reply with quote
I feel I need one, even though I've not really played with my Pi 3 yet Smile
M.C
PostPosted: 11:30 - 28 Feb 2017    Post subject: Reply with quote
Still not played with my original Pi zero Embarassed
DrSnoosnoo
PostPosted: 12:04 - 28 Feb 2017    Post subject: Reply with quote
I'm considering getting a Pi at some point to make a games box thingy. Wouldn't mind a bit of doofing around to get some classic games playing. I might even learn a bit about how computers kind of work, too.
M.C
PostPosted: 12:14 - 28 Feb 2017    Post subject: Reply with quote
This is interesting (guessing that's what you meant): https://www.raspberrypi.org/magpi/diy-nes-classic/ Good use for all those blown cartridges Smile
DrSnoosnoo
PostPosted: 12:33 - 28 Feb 2017    Post subject: Reply with quote
Pretty much that yeah, RetroPie is the OS I think. And you can sync PS3 /PS4 controllers to it too. I'd enjoy it just to play golden axe once and then put it in a drawer.
There's also an emulator for dreamcast, with the Pi3 performing ok for most of the games I'd be interested in having.
kgm
PostPosted: 12:43 - 28 Feb 2017    Post subject: Reply with quote
I'd like a new Pi. Still running the original model B.
Shinigami
PostPosted: 14:20 - 28 Feb 2017    Post subject: Reply with quote
i have an original model B sat in a box at home presently unused as not sure what to use it for now, used to be a mini media centre but i've a micro ATX PC doing that job now
Pjay
PostPosted: 11:10 - 01 Mar 2017    Post subject: Reply with quote
I made a rather nifty little Ethernet to Wifi adapter for my Youview box (that will turn any Ethernet port to Wifi).
The new Pi Zero W will streamline the device down a nice amount, just leaving me with a zero and Ethernet port.
If I could work out how WPS works, I could sell them and become rich beyond my wildest dreams. I may look into this more and try to get it working.
M.C
PostPosted: 16:20 - 01 Mar 2017    Post subject: Reply with quote
Is that real millions or Adam Aarons millions?
Pjay
PostPosted: 16:49 - 01 Mar 2017    Post subject: Reply with quote
More than likely AA monies to be fair. They would cost me £15 to make, so not many people are likely to pay £30 or so retail just to solve a problem that isn't that common. It's only really handy for older hardware too as most stuff is wifi now anyhow.
M.C
PostPosted: 17:05 - 01 Mar 2017    Post subject: Reply with quote
I could use one for my Xbox 360. When does the crowdfunding start?
Pjay
PostPosted: 17:53 - 01 Mar 2017    Post subject: Reply with quote
It's already pretty much done and I've looked into the WPS thing and it seems workable with a little button on the case.
I coded everything myself to make the ethernet port a DHCP server and issue out an IP to the device as if it was plugged into a router and then I routed its traffic through the wifi, which connects to the router.
I looked everywhere on the interwebs and nobody else had ever done this, so I assumed it wasn't something that's much needed.
Oh I also soldered in an ethernet port to the pi zero, as it doesn't have one.
£30 is cheap, you can have one for £29.95 once I have the WPS sorted.
goto10
PostPosted: 13:48 - 14 Mar 2017    Post subject: Reply with quote
I want to see a working prototype in your kitchen sink first.
lihp
PostPosted: 15:14 - 14 Mar 2017    Post subject: Reply with quote
Got a link to this?
Pjay
PostPosted: 15:54 - 14 Mar 2017    Post subject: Reply with quote
lihp wrote:
Got a link to this?
I made it, I think it's the only one in existence.
I wired in an ethernet port and set it as the DHCP servers port and used the wifi to connect to the home network, then routed all external traffic though the wifi port.
duhawkz
PostPosted: 15:05 - 15 Mar 2017    Post subject: Reply with quote
lihp wrote:
Got a link to this?
You can buy them ready made
Pjay
PostPosted: 16:18 - 15 Mar 2017    Post subject: Reply with quote
How do they connect to your router?
I dont see any wps.
CaNsA
PostPosted: 16:37 - 15 Mar 2017    Post subject: Reply with quote
https://www.youtube.com/watch?v=onumVq27f5o
Pjay
PostPosted: 17:09 - 15 Mar 2017    Post subject: Reply with quote
Ah fuck that, I've managed to get WPS to seek on boot, so you just boot it up, press the wps button on your router and they connect.
lihp
PostPosted: 19:56 - 15 Mar 2017    Post subject: Reply with quote
I was hoping for a solution that required me to do nothing on the router.
Just a case of plug it in and go. My wifi signal is terrible in my workshop at work, but I do have spare Ethernet, and spare a spare pi
owl
PostPosted: 20:44 - 15 Mar 2017    Post subject: Reply with quote
How would it help? You'd still be connecting to the same terrible wifi unless I'm misunderstanding something ...
lihp
PostPosted: 01:09 - 16 Mar 2017    Post subject: Reply with quote
Because I have Ethernet ports available. So instead of connecting to an access point 80ft away through several walls. I can plug an rpi into available cable Ethernet socket, and then connect with wifi via the rpi
CaNsA
PostPosted: 02:14 - 16 Mar 2017    Post subject: Reply with quote
https://www.ebay.co.uk/itm/272590149215
owl
PostPosted: 07:12 - 16 Mar 2017    Post subject: Reply with quote
You're sticking it in the wrong hole
The last post was made 9 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 126.67 Kb
