Fazer Tom |
Fazer Tom Spanner Monkey
Posted: 23:26 - 28 Feb 2017 Post subject: Damp problem |
Hi all, got a problem with some damp ive come across in the house, its at the back of the chimney breast, we had logs there originally but the wofe wanted to remove them for the kid to have toys there, as shes removed the ligs shes come across a large unpainted section, shes painted it but is all immediatley boubled up and started peeling off. Im not afraid of any diy, being an auto electrician but i dont have a clue on how to go about sorting it.
I suspect its rising damp. Its a midterrace too if that helps.
https://s11.postimg.org/vwgd9882b/20170228_220605.jpg ____________________ (CBT 01/07/11. Theory, 21/05/12. MOD 1, 01/06/12. MOD 2, 3/08/12)
Past: (1981 CG125) (1992 ZZR250 x2) (1976 KZ400) (1993 400 Superfour) (2002 Triumph TT600) (1998 Fazer) (2001 CCM 636) (2000 CCM 604) (2007 Kawasaki Z750) (2005 Husqvarna SM450R) Current: (1989 Bandit 400) |
grr666 |
grr666 Super Spammer
Fazer Tom |
grr666 |
pompousporcup... |
Posted: 09:28 - 01 Mar 2017 Post subject: |
doggone |
doggone World Chat Champion
grr666 |
Posted: 14:21 - 01 Mar 2017 Post subject: |
There is no such thing as "rising damp".
It's a scam invented by companies to charge people a fortune to inject chemicals into their bricks.
There is such a thing as "damp". It happens when moisture gets directly onto your brickwork.
So in a chimney breast, the most likely way for this to happen is by it coming down the chimney.
If you've had logs stacked in there, it's likely that a little moisture has got in and has been prevented from evaporating properly by the stack of logs.
Which brings us neatly to the other common cause of "damp" in houses which is condensation. This is caused by high humidity, a low surface temperature of the affected area and a lack of ventilation. Such as you might find behind a stack of logs.
If the wall itself is colder than the surrounding room, it could even be below the dew point at which point condensation will form (like you see on the inside of your windows, they aren't leaking and the water isn't magically "rising" from elsewhere, they are colder than the surroundings, water vapour condenses on them) .
Worth noting that disused chimneys are usually either blanked off or have a ventilation grille left at the base to allow them to breathe (thereby increasing venmtilation and reducing condensation).
TL;DR It's probably a bit of damp that's been trapped behind your stack of logs. Leave it a while to dry out, I'd stick a dehumidifier in there for a couple of days. Next most likely is simply condensation. Next would be water coming down the chimney. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Feasty |
Feasty World Chat Champion
Posted: 16:56 - 01 Mar 2017 Post subject: |
Can you only use that on the missus if she's painting?
It's just, that's the time when she's quietest and concentrating... I'd prefer to use it when I'm watching my fave program and she won't shut it! ____________________ Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
Current: Yamaha TDM 900 (Comfy, light but big, power when needed). |
grr666 |
Posted: 16:58 - 01 Mar 2017 Post subject: |
Yeah, if you want to restrain a woman good old gaffer tape works best. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
arry |
arry Super Spammer
grr666 |
Moo. |
Moo. World Chat Champion
The last post was made 7 years, 55 days ago. Instead of replying here, would creating a new thread be more useful? |
