HTTP Auth over SSL
t121anf
PostPosted: 01:08 - 04 Mar 2017    Post subject: HTTP Auth over SSL Reply with quote
I'm trying to setup a test webserver which I need to run webdav on, the OS being used is Debian as I'm told by the internet it's the closest to Raspbian which I plan to us when I have tested it out.
So far, I've installed the OS, Apache and webdav using basic http authentication.
So far so good, I can update the files on in webdav folder via various methods.
However I need SSL for an app I want to use, i've created a self signed cert* and applied it to apache. Browsers moan it's insecure but traffic is going over SSL.
The problem is once I add SSL, web auth stops working. If I go to my server via http returns an error about expecting https (400 bad request). Going via https I see my site/file but no authentication.
Can anyone advise on how to setup apache to use SSL and then authentication?
*for the live server I plan to use LetsEncrypt
t121anf
PostPosted: 01:44 - 04 Mar 2017    Post subject: Reply with quote
I think I've solved the issue.
This line in the conf
<VirtualHost *:80>
needed to be updated to
<VirtualHost *:443>
initial tests show datestamps matching my edits, i.e. edit at 00:40 in web app, file on the server changes to 00:40 and so on.
Slight issue that my desktop app has now stopped talking to the files on the web server but I'll look at that tomorrow*
*or today, it's late, time for bed.
undefined
PostPosted: 00:15 - 11 Mar 2017    Post subject: Reply with quote
I know you've already solved the problem but for the sake of completeness, you can always add in a permanent redirect to catch the times you/users forget to use the right protocol:
Code:
<VirtualHost *:80>
  ServerName addy.com
  redirect / https://addy.com
</VirtualHost>
<VirtualHost *:443>
</VirtualHost>
Alternatively, mod_rewrite and rewrite rules.
'89 Honda MT50 > '97 Yamaha Thundercat
t121anf
PostPosted: 00:27 - 11 Mar 2017    Post subject: Reply with quote
Thanks for that, I'd need it anyway when I put this into a live environment (can't at present wife is running a campaign this month)
The last post was made 7 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.04 - MySQL Queries: 17 - Page Size: 46.64 Kb
