Fred3606 |
Fred3606 Two Stroke Sniffer
Itchy |
Itchy Super Spammer
Posted: 17:33 - 06 Mar 2017 Post subject: |
Dirt got into the pistol seals and therefore prevent the smooth in and out movement of the brake pistons. Therefore the brake pressure pushes the pistons and the pads out squeezing the disc.
But when the pressure is removed they can't move back in to allow free movement of the brake disc and wheel attached to it.
You need to clean your brake pistons.
This means taking the brake calliper off the forks.
Then either:
Pumping the brake lever so the pistons pop out.
Or pumping the brake lever so the pistons come out enough so you can clean the pistons where dirt is preventing pistons from retracting.
The job isn't difficult but increases with difficulty the more brake pistons there are per calliper.
A sliding brake system with two pistons per brake disc is easy and you need no special tools as you can simply use the brake pressure to push out the pistons.
Piston removal tools make the job much much easier.
It will leak brake fluid which is corrosive once you pop the pistons so wear eye protection.
Once the pistons are out you need to clean them and replace the seals (YMMV as I've put them back in more than a few times). You need to remove any burrs which may tear the seals (I used a plastic ruler and finger nails as it's softer than the steel the pistons are made from).
Then push the pistons back in. Others like to fill the calliper with brake fluid then push the piston back in with thumbs.
Then you need to bleed the system to get the air out. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
natefz6 |
natefz6 Brolly Dolly
Posted: 17:44 - 06 Mar 2017 Post subject: |
My pads seemed to be jammed the other day but I think that it was just the result of some slight rust binding the pad to the disc after a particularly salty shitty ride.
It took a good yank to get it free but once released they have been fine and the wheel spins freely.
Maybe totally unrealated to your problem ____________________ "no I didn't steal it that's just the way I ride" |
AndyCF |
AndyCF Two Stroke Sniffer
Fisty |
Fisty Super Spammer
kgm |
kgm World Chat Champion
Fred3606 |
Pete. |
Pete. Super Spammer
Posted: 21:08 - 06 Mar 2017 Post subject: |
Blocked return port in the master cylinder. It's a tiny drilling you can see in the floor of the reservoir sometimes covered by a little metal clip to stop the oil squirting out. When you let go of the lever it allows excess oil to flow back to prevent heat from using the brakes building up pressure. If this port is blocked you go for a ride then the brakes start dragging until suddenly they are on solid.
Can also be a sticky lever or master cylinder piston causing the plunger to not fully retract, especially if it's been ridden through winter. ____________________ a.k.a 'Geri'
wots |
wots World Chat Champion
Posted: 21:20 - 06 Mar 2017 Post subject: |
I had this happen to me, but it was not the brake system at all, it was in fact my cheap chinese lever jamming. Have you got anything like this? Most likely one of the above suggestions, but worth checking. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Fred3606 |
Pete. |
Pete. Super Spammer
Fred3606 |
Fred3606 |
Itchy |
Itchy Super Spammer
Posted: 22:17 - 13 Mar 2017 Post subject: |
Try clean them up using a piece of plastic or anything softer than the steel of the piston. You want to get it looking similar to the closed end of the piston. Do not use sand paper, do not use a screw driver as you may scratch the piston or cause burrs. Use something soft to clean it and use brake fluid to clean it. The worst that stuff will be is rust but most likely it's road salt.
If you got one piston out then to get the other one you can do one of two things.
1 Clean up the piston that is currently out and change the seals. Then pop it back in so it is flush with the calliper body. Make sure you also clean the grooves the seals sit in too.
You then need to bleed the system completely and HOLD in the cleaned piston so the brake fluid pressure can only act on the other piston.
When you hold it in the pressure will be applied at the point of least resistance the piston you're not holding in and it will pop.
Then clean that one out the same as before then pop it back in and re-bleed the system.
2 Buy a brake piston remover kit. #1 is obviously cheaper but more time consuming as you have to bleed the system twice. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
Rogerborg |
Rogerborg nimbA
Posted: 22:27 - 13 Mar 2017 Post subject: |
Definitely do not just just wrap a load of rag around the stuck piston, clamp some grips on the very top edge of it, get it turning to unstick it and then have it out in seconds. Even though if you do slightly mark it, it'll be in the area above the fluid seal even with the piston pushed fully in.
I've certainly never done that rather than fanny about for ages, and if I had, I would have died three times and not been able to tell the tale. ____________________ Biking is 1/20th as dangerous as horse riding.
Kickstart |
Kickstart The Oracle
Posted: 23:24 - 13 Mar 2017 Post subject: |
Not 100% looking at the pics, but that looks like pretty severe corrosion on the piston you have out.
Air line is the easiest way to get the piston out, but watch out for high speed flying pistons.
Failing that carefully use pliers wrapped in something to pull the piston out (rubber cut from a old inner tube for example). But get it wrong you will trash the pistons (quite easily).
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
pompousporcup... |
Posted: 23:40 - 13 Mar 2017 Post subject: |
Commuter_Tim |
Commuter_Tim World Chat Champion
Posted: 23:54 - 13 Mar 2017 Post subject: |
Same, I tried Rog's Bodge and it worked, but I haven't looked back since buying piston pliers. ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
wots |
Posted: 09:11 - 14 Mar 2017 Post subject: |
I use the Draper Expert version and until this week it had never failed, some particularly knackered VFR calipers it failed on. However, it has been used a lot and it looks like the knurling has started to smooth, so not as much bite.
The sealey one linked, is easier to operate, I will be replacing mine for the one above shortly.
However, as I had a couple of pairs of calipers and therefore some spare pistons, I went to extract the brute force way ..... microfibre cloth in the piston and over the edge. Then nice big adjustable jaw plier things (don't know the name), was surprised to get them out no problem and without damage. Remember twisting is important as much as pulling. ____________________ Currently: Yamaha DT 125 LC2,Repsol Fireblade, and Bumblebee MSX 125 |
Fred3606 |
Posted: 22:30 - 24 Mar 2017 Post subject: Conclusion |
Sorry this is a bit late, forgot
Thanks to everyone for your assistance
In the end I bought some red grease and brake fluid on the interbob, popped out Pistons (used pliers for the second one).
For those who guessed it was just gritty salty stuff so I scratched it off with a credit card and cleaned it out. Works brilliantly now ____________________ ... |
The last post was made 7 years, 27 days ago. Instead of replying here, would creating a new thread be more useful? |
