K1 Bandit dropping a cylinder at 3 to 4k?
Kaya75
PostPosted: 12:55 - 08 Mar 2017    Post subject: K1 Bandit dropping a cylinder at 3 to 4k? Reply with quote
Hi All,
my trusted bandit has started dropping a cylinder and missing at about 3 to 4k rpm.
This gets slightly better when warmed up.
Once I get though the 6k barrier its fine.
So it seems like fuelling or ignition.
anyone suggest common issue - fixes (in b4 "get another bike") Smile
Bike is K1 600 GSF - 25K miles on the clock, pretty well looked after but ridden everyday on the daily grind.
Thanks all.
ybr125 Sold, GSF600 K1 Bandit (For Sale), FJR13000 gen2.
nowhere.elysium
The Pork Lord
PostPosted: 13:09 - 08 Mar 2017    Post subject: Reply with quote
Is it throttle-dependent? I'd assume a blocked jet, if it's only the one cylinder. Personally, (were it another bike, at least) I'd suggest having the airbox off and cleaning the offending carb out with something volatile. However, since it's a Gen 2 Bandit 6, the airbox is a total arsehole to remove.
Try an Italian tune-up: warm it up and thrash the everloving fuck out of it. May well clear the jet.
Kaya75
PostPosted: 15:11 - 08 Mar 2017    Post subject: Reply with quote
Yep - I hear that, I've changed the air filter and that was a mission - I wanted to drop the carbs last summer and give them a clean - I though sod that. Having said that i'll wait until easter and get the box off and throw some carb cleaner down there - I may check for cracked jets.
Ive just read about the spark plug access bore filling with water, but the carbs could do with a clean anyway.
thanks
jaffa90
PostPosted: 17:42 - 08 Mar 2017    Post subject: Reply with quote
It could be a weak mixture on the pilot feed, did you fit a freer flowing air filter?
Or it could be air going in, inbetween the carbs and engine.
The last post was made 9 years, 72 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.44 - MySQL Queries: 14 - Page Size: 40.45 Kb
