dydey90 |
dydey90 World Chat Champion
arry |
arry Super Spammer
dydey90 |
Rogerborg |
Rogerborg nimbA
chris-red |
Posted: 16:46 - 15 Mar 2017 Post subject: |
Same way you do everything else. Find it in a shop then buy it on ebay.
Just had mine done. Got a plumber to do it because my time is worth more than my money and my plumbing sucks.
Towel rail. Not cheap but fucking awesome!
If it's to do up for selling. Wickes do cheap and basic plain white bathroom stuff. Which is what people want to see in a house they buy.
I'm staying in my house so I've splurged on genuine linoleum flooring with underfloor heating and a totally kick-arse walk-in shower instead of the bath. People like to buy a house with a bath but seldom use it.
Be prepared for all sorts of nightmares/bodges and bullshit when doing up a bathroom. The plumber took 16 feet of redundant copper pipe out of mine where past refits had just added to the last one. There was downstairs wiring coming up then back down, wall voids behind tiles and six different types of plaster. The wastes were all above floor level and had to be re-drilled to avoid putting the shower on a plinth. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
dydey90 |
Posted: 19:48 - 15 Mar 2017 Post subject: |
Fuck tiles. Showerboard is where it's at. You even get showerboard that looks like tiles.
No more mouldy grout.
I was about three grand to have mine fitted. I supplied almost all of the materials at easily another grand. So yes. Expensive. That wasn't a plumber though, it was a bathroom fitter. Plumbers do the pipework, tilers do the tiling, sparkies do the wiring. This guy was certified in everything he had to be and did the lot.
That was a total strip down to bare walls and floor, replaster, new sub-floor and new ceiling. Underfloor heating. New cludgie, shower, basin, towel rail. Shower board in the shower, new tiles, wood cladding halfway up.
He's done a cracking job. It's a genuine pleasure to go in there and take a dump and, more importantly, happy wife.
Has probably de-valued the house because no bath now. Form my point of view, wont need doing again for my residency in this house. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
garth |
garth World Chat Champion
Posted: 20:50 - 15 Mar 2017 Post subject: |
Showerboard is bollocks IME.
If you're tiling yourself and they're stud walls, it's unlikely the old tiles will come off nicely. Make your life easier by just reboarding the walls with moisture resistant boards first - that way you are going to a nice flat surface. Batten the walls, then cut to the floor afterwards. Work out the spacing before you start so there are no tiny cuts to the ceiling or floor, mark out on a wall the top of window, bottom of window, top of door and try to get a nice balance. Spread the adhesive on the wall, not the tiles.
Speedfit push fittings are a blessing. Fit isolators to the basin and shitter. Hot left, cold right...
When removing said shitter, isolate the feed, flush the toilet a few times, remove the feed, remove the cistern, pour the remaining water down the pan. Undo the pan fixings, if on a flexi hose tilt it back to remove some of the water. Carry it downstairs and out the door at an angle, so not to spill water. Stuff the hole in the waste with some plasic bags to stop the smell.
It's nice not to have a big step into the shower but you need a decent fall on the waste, it depends on the room.
Find out the rad pipe spacing before you start, make up the towel rail and take a measure for how far it will stand off the wall, so you can get the holes in the floor half right. I hope for your sake it;s not microbore pipe because that can be a pain in the arse, although alot of the time it's on the tails done like that. Draining the system is probably the safest method.
Bit of LSX and some PTFE around the threads to avoid leaks.
Maybe get some pictures up if you want some ideas?
Are you tiling the floor? ____________________ You ain't a has been if you never was
garth |
garth |
Posted: 20:56 - 15 Mar 2017 Post subject: |
With regards to bits, City Plumbing sell good stuff, part of the Travis Perkins group like everyone.
I like Zamori trays.
Don't eat with your fingers. ____________________ You ain't a has been if you never was |
dydey90 |
Posted: 22:35 - 15 Mar 2017 Post subject: |
I should have probably given some idea of the sizings here.
En suite (main priority) I'm just doing shower and towel heater, maybe tiles behind sink to match up too. Alcove shower, as in three walls and bifold door. Entire room is shower, sink, toilet all facing each other, probably only about 8' by 2' 6"
Main bathroom is bath, sink, toilet around 5' 6" by 6"
So not a lot of space to play with. Getting a bit worried about taking the tiles out of this shower too without caving the wall in from what's been said! If I replace the shower basin then the tiles have to come out, as it looks like there's a 760mm basin in an alcove that is not 760mm wide, even taking the tile depth into account so there must be a bit of wall chiselled out to have got that in, then tiled over on top. ____________________ This post is probably not serious and shouldn't be taken literally.
Past: CBR125,ER6f NINJA 650, ZZR600 Current: VFR750 |
garth |
arry |
arry Super Spammer
grr666 |
grr666 Super Spammer
Posted: 09:24 - 16 Mar 2017 Post subject: |
Cuprofit copper push fits are better. Buy a release tool though. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Ebbs73 |
Ebbs73 Nova Slayer
Posted: 09:25 - 16 Mar 2017 Post subject: |
You could have a nose at https://bathcoeu.com .
They do some good stuff for the price , I get all my stuff from here .
They have a couple of shops and do deliver , not sure on there range .
They have wet wall for a good price , I'm fitting some tomorrow .
I do get a good discount as I've an account but you can push it and see what they'd do.
From my experience you'll budget £2000 and it'll be far more .
Buy cheap , endless hassle fitting it , problems later and it's still a cheap suite .
Good luck . |
arry |
arry Super Spammer
Posted: 09:27 - 16 Mar 2017 Post subject: |
They're closely followed by by the way.
Elbonians and push fittings together = murderdeathkill MDK. |
dydey90 |
garth |
dydey90 |
almostthere |
almostthere Traffic Copper
Posted: 20:03 - 16 Mar 2017 Post subject: |
toolstation are good for cheap gear, basic sanitaryware cheap as chips they also do towel rails and shower valves ____________________ Beer, It's the reason I get up every afternoon
www.mfairco.uk |
331X2 |
331X2 Crazy Courier
BTTD |
BTTD World Chat Champion
Fowlersrs |
Fowlersrs World Chat Champion
The last post was made 7 years, 35 days ago. Instead of replying here, would creating a new thread be more useful? |
