Honda H100A 6V lighting cirucit resistor
caprilaser198...
PostPosted: 22:39 - 27 Mar 2017    Post subject: Honda H100A 6V lighting cirucit resistor Reply with quote
Hi All,
I require a new 6v lighting circuit resistor for a Honda H100A.
Does anyone know where I can get one from?
If I am unable to get a 6v item, will a 12v resistor be suitable?
Any help would be greatly appreciated.
PostPosted: 00:17 - 28 Mar 2017    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Motorcycle-Bulb-Light-Resistor-Universal-6v-12v-/401150062609
neptune8
PostPosted: 17:01 - 28 Mar 2017    Post subject: Reply with quote
I do not have a Haines manual for this bike, but suspect it is similar to the CG125. A resistor was used on 6 volt [early] CGs. It was used as a crude regulator in the lighting circuit. It is only in circuit when the bike is ridden on sidelight, and its purpose was to burn the power that would otherwise feed the headlight. Its value is 2 Ohms, and should be rated at 18 watts or higher. Symptoms of a failed resister = pilot lamp bulb constantly blowing. Actually, if you always ride with headlight switched on, you could probably manage without the resistor.
Enjoy yourself, its later than you think
caprilaser198...
PostPosted: 17:33 - 28 Mar 2017    Post subject: Reply with quote
Thank you all for your help.
The problems is exactly as neptune8 states.
The last post was made 8 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.57 - MySQL Queries: 14 - Page Size: 39.35 Kb
