Can't drill into stud
Bike Chat Forums Index -> The Workshop Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Arcane1729 This post is not being displayed because the poster is banned. Unhide this post / all posts.
redeem ouzzer
PostPosted: 21:30 - 20 Mar 2017    Post subject: Reply with quote
What engine is it?
Be a REAL MAN!
BTTD
PostPosted: 21:31 - 20 Mar 2017    Post subject: Reply with quote
Arcane1729 wrote:
kramdra wrote:
I've been told by the guys who know their stuff at the specialist that Rocol is the best cutting fluid- I bought the paste kind cos that was the only thing in stock. Is that as equally good like the oil kind?
The Rocol cutting compound is definitely good enough. I'd go so far as to say it's better than you need. My understanding of Rocol stuff is that it's industrial quality, as in expected to prolong the life of expensive tooling that is in constant use, which is bit overkill for diy grade tooling occasionally used. It's also considerably more expensive.
tl:dr
Yeah it'll do.
Hong Kong Phooey
PostPosted: 21:45 - 20 Mar 2017    Post subject: Reply with quote
Normally some sort of guide jig is made for car engines so the drill bit can be accurately centred and driven steadily - especially if doing it in situ with a 90 degree drill.
You have the engine out, but I would still knock up a jig if you don't have a drill press and insist on doing it with a cordless drill.
I'd post the photo so we can help. Remember what happened last time you went all freestyle jazz mechanic?
Pete.
PostPosted: 22:10 - 20 Mar 2017    Post subject: Reply with quote
Arcane1729 wrote:
No they dont. It's a stud. Made of hardened steel.
Is it bollocks, they never are. Just because YOU can't drill it doesn't mean it's hardened.
a.k.a 'Geri'
PostPosted: 22:44 - 20 Mar 2017    Post subject: Reply with quote
To be fair, some previous owner of Mystery Engine could have replaced the studs with stainless, because harderer is betterer, right?
owl
PostPosted: 22:58 - 20 Mar 2017    Post subject: Reply with quote
your bits are not hard enough for that stud
PostPosted: 23:02 - 20 Mar 2017    Post subject: Reply with quote
Quite so..
Incidentally I once bought a couple of De Walt extreme bits for stud drilling purpose and they worked well. Lovely curls of continuous swarf - Are you sure you've got your drill running clockwise OP?
Ragging the chaps on here, whilst most entertaining, isn't helping you much is it? Strongly suggest you comply with requests and work with them.
Pip pip.
331X2
PostPosted: 23:30 - 20 Mar 2017    Post subject: Reply with quote
You really need to put a picture up of what you're trying to do here, there are so many more factors than you realise that will affect the outcome of this job.
Also for entertainment value take a picture of the tips of the drill bits you've been using...
kramdra
PostPosted: 23:31 - 20 Mar 2017    Post subject: Reply with quote
No. You do not need cutting fluid, if the drill is sharp and correct pressure, it will make decent sized chips which will keep the heat out of the drill. Drills only get too hot if they are rubbing. A light oil/wd40 is enough.
This is relevant when you are using the 5mm+ bits to get final size in your stud, watch 4 to 6minutes
www.youtube.com/watch?v=QhpOg186fks&t=240
BTTD
PostPosted: 00:00 - 21 Mar 2017    Post subject: Reply with quote
OP is a total novice and is almost certainly applying as much pressure as possible. A cheap can of cutting fluid can only help. The fact that he bought the most expensive cutting paste available is somewhat wasteful, but it will at least help him drill the hole.
To be clear, I am in total agreement with you, but OP is a special case.
Kawasaki Jimbo
PostPosted: 00:08 - 21 Mar 2017    Post subject: Reply with quote
GT200Fan79 wrote:
What engine is it?
I think we are meant to assume it is a revolutionary, top secret R&D project... or a 125. Side valve, probably.
Baggyman
PostPosted: 00:26 - 21 Mar 2017    Post subject: Reply with quote
Kawasaki Jimbo wrote:
GT200Fan79 wrote:
What engine is it?
looks like the engine out of a kymco super 8 - I saw it through his window cos i know where he lives
Old fart
Baghira, modded GS1000 and the T150 I bought in 1978 when I was 21
Teflon-Mike
tl;dr
PostPosted: 00:32 - 21 Mar 2017    Post subject: Reply with quote
That is probably the least contentious. most undisputable statement in this entire thread.
Robby
Dirty Old Man
PostPosted: 00:59 - 21 Mar 2017    Post subject: Reply with quote
Just post a picture of this mystery engine and stud.
If they're normal mild steel, then a normal HSS drill bit will do it. If they're stainless, then you'll probably need cobalt bits. Cutting fluid helps.
I'm quite concerned that you're trying to dig yourself out of your credit card black hole by fixing other people's bikes in exchange for money. You have neither the skills nor the attitude to do this. When the owner of the bike ends up killed or seriously injured, you get to spend some time reflecting on your mistakes in prison - where you will get abused in creative ways.
A lot of people on this forum know a lot about fixing bikes, and will fix their friends bikes, but will only accept beer as payment. This is because they know enough about their skills to also understand their limitations. You need to start recognising your limitations. You've spent enough on tools in the last month to pay for a few years of servicing by a shop.
Fazer Tom
PostPosted: 01:42 - 21 Mar 2017    Post subject: Reply with quote
This thread has given me aids
(CBT 01/07/11. Theory, 21/05/12. MOD 1, 01/06/12. MOD 2, 3/08/12)
Past: (1981 CG125) (1992 ZZR250 x2) (1976 KZ400) (1993 400 Superfour) (2002 Triumph TT600) (1998 Fazer) (2001 CCM 636) (2000 CCM 604) (2007 Kawasaki Z750) (2005 Husqvarna SM450R) Current: (1989 Bandit 400)
kramdra
PostPosted: 01:53 - 21 Mar 2017    Post subject: Reply with quote
Arcane1729 wrote:
I've wondered why does an m8 broken bolt need a specific larger size screw extractor- why can't you just make a small 3mm drillbit hole and then use the smaller extractor which matches the 3mm drill- is it because there is too much metal to displace with only a small 3mm bit- so you cant make a deep 3mm hole in a large diameter bolt?
Extractors are generally rubbish and a small one wont have enough torques to shift a stuck 8mm bolt, consider there was enough force to break an 8mm stud, so a weak 3mm wont have a chance.
However once you have a full depth pilot, which is on centre and within 2 degrees, enlargening it is piss, assuming one does not eat through the stud into the parent metal, which is softer. When this happens you will never get it back on centre.
Practise on scrap first.
PostPosted: 02:03 - 21 Mar 2017    Post subject: Reply with quote
I really cant understand why someone would be so reluctant to
show the engine they're working on.
I've found that forum advice, whatever the subject tends to have a
golden rule:
'The more/better info given, the better the advice received'
Withholding info makes folk lose interest at best
Baggyman
PostPosted: 06:13 - 21 Mar 2017    Post subject: Reply with quote
Arcane1729 wrote:
Because you'll laugh at me. And it's ok, the thread can die now.
Exact opposite. Nobody will laugh. Learning on something cheap/free/scrap is the smartest thing to do. Take it apart. Understand it. Put it back together. Think. Ask. Learn.
Old fart
The last post was made 7 years, 39 days ago. Instead of replying here, would creating a new thread be more useful?
Page 5 of 9
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.53 - MySQL Queries: 17 - Page Size: 145.33 Kb
