RickTaff |
RickTaff Nitrous Nuisance
P. |
P. Red Rocket
zark |
zark Trackday Trickster
Matt B |
Matt B World Chat Champion
Rogerborg |
Rogerborg nimbA
Posted: 10:49 - 21 Mar 2017 Post subject: |
Tell your husband to just keep the engine running. ____________________ Biking is 1/20th as dangerous as horse riding.
bugeye_bob |
bugeye_bob World Chat Champion
Matt B |
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 17:40 - 21 Mar 2017 Post subject: |
bugeye_bob wrote: | Matt B wrote: | I took a set of bearings out of the ZX6 rear wheel yesterday. It literally takes minutes. Warmed the hub with a hot air gun then hit it with a hammer an a long drift.
You are sure there isn't a circlip holding it in there? |
Wouldnt heating it all up actually make it harder to remove ?
heat makes things expand, I put bearings in the freezer before fitting them. |
Differential expansion. Works like the bi-metallic strip in a thermostat switch. One metal expands ore than another for same amount of heat.
Alluminium expands more per degree than steel, so if you have a steel brearing race in alloy hub, heat will make both expand, but the hub, on the outside will expand more than the bearing, so the interferance between the two will get smaller, and bearing more likely to drop out.
The bead weld takes this a bit further; adding a ring of hot molten metal to the bearing, will heat the assembly, both race and hub, and you will get differential expansion... but the locally applied weld will be much hotter still, and when the weld cools, will contract even more, and shrink the race a little more with it
Even if hardened race was in a steel hub, with little or no differential expansion to be had, the very high temperature, locally applied heat, could still cause the same effect from getting the inner race that much hotter, and so shrunk more when cooling, than outer hub.
It's using the cooling distortion you usually try and avoid in welding to positive effect. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Matt B |
sickpup |
sickpup Old Timer
Matt B |
sickpup |
sickpup Old Timer
dydey90 |
dydey90 World Chat Champion
Matt B |
V2 |
V2 Nearly there...
Posted: 14:44 - 24 Mar 2017 Post subject: |
Commuter_Tim |
Commuter_Tim World Chat Champion
Posted: 23:08 - 24 Mar 2017 Post subject: |
Good old Stinky, fisting Bovine anus and putting an end to bickering for the good of mankind.
Neither are pretty jobs, but someone has to do them. ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
neptune8 |
neptune8 Nova Slayer
The last post was made 7 years, 33 days ago. Instead of replying here, would creating a new thread be more useful? |
