Rear axle plate upside down - wut do?
NJD
PostPosted: 11:17 - 24 Mar 2017    Post subject: Rear axle plate upside down - wut do? Reply with quote
Took the bike to get the tyres fitted yesterday and noticed this morning they've fitted the plate on the left side axle upside down, pictures below.
Do I ring them up and go back over the weekend or buy the tools from Halfords and do it myself in a few hundred miles by taking the wheel out next time the chain needs adjusting?
I ask because I'm obviously unaware and if it's anything more than simply hiding the adjusters, ie: could work loose or w/e, then I'll be popping back.
Right (correctly fitted):
https://s23.postimg.org/qusrlff3f/4_right_1.jpg
Left (fitted upside down):
https://s13.postimg.org/qk682xwg7/5_left.jpg
bamt
PostPosted: 11:30 - 24 Mar 2017    Post subject: Reply with quote
That should be fine, it's purely a cosmetic issue.
But to sort it doesn't need the wheel coming out - just remove the pin from the castellated nut, undo the nut, flip the plate, tighten the nut, put in new pin. Two minutes of a job as long as you have the pin and a socket that fits the nut - which hopefully you do have so you can tension your chain.
PostPosted: 11:31 - 24 Mar 2017    Post subject: Reply with quote
Every bike I have had would have the tools to do that job in the included toolkit.
How do you adjust the chain without them?
It's fine to leave IMO. I wouldn't visit the garage again, while it's not remotely dangerous is displays a lack or interest/professional pride I wouldn't trust them to do a decent job.
Arcane1729 This post is not being displayed because the poster is banned. Unhide this post / all posts.
NJD
PostPosted: 11:40 - 24 Mar 2017    Post subject: Reply with quote
So what one of these would I buy?
Here's what left of the original toolkit:
https://s27.postimg.org/nbop80clv/toolkit.jpg
I've not had the bike long and have only covered a few hundred miles since I got it.
Was on the to do list but wasn't urgent.
26mm/27mm socket + split pins, once I now what one, is on the shopping list then.
iansoady
PostPosted: 12:11 - 24 Mar 2017    Post subject: Reply with quote
Arcane1729 wrote:
Ah I see your setup too is also where the axle comes in from the left and you have to painfully try for ages to align the caliper with the right spacer while you try to get through- such a weird design fault...
Actually, you can put it in the other way round (at least on all the ones I've come across) making it much easier.....
Ian
1986 Honda XBR500
1952 Norton ES2
bamt
PostPosted: 12:12 - 24 Mar 2017    Post subject: Reply with quote
That ring spanner, with the odd squashed tube pushed onto the end to extend it, should undo the nut. It's far easier with a decent socket and breaker bar though.
At a push I'd reuse a split pin, as long as it looks in reasonable order, all it is doing is stopping the nut rotating. But best thing to do is buy a kit of them for a few quid off the net so you have whatever you need to hand (like the pins on the rear brake torque arm, or footpegs). I think this is the pack I have - https://www.ebay.co.uk/itm/like/361483492034
For the halfords ones, I'd just take yours in to compare it, or measure it with a ruler. They really aren't that critical (so putting a 2.5mm one in instead of a 3mm is OK).
PostPosted: 12:16 - 24 Mar 2017    Post subject: Reply with quote
Split pins irritate me, I'd consider replacing it with an R Clip if you can get one to fit.
PostPosted: 12:21 - 24 Mar 2017    Post subject: Reply with quote
Are people still using split pins for shit like that?
I went over to spring pins years ago. Reusable, no hammering, no contest.
https://www.ebay.co.uk/itm/150Pc-HAIR-PIN-HITCH-RETAINING-R-CLIP-CLIPS-LYNCH-COTTER-SPRING-BRIGHT-ASSORTED-/122377802136?hash=item1c7e491198:g:WdQAAOSwWxNYt2PO
Edit, beaten to it by Chris Crying or Very sad
Triumph Trophy Launch Edition
davethekwak
PostPosted: 12:27 - 24 Mar 2017    Post subject: Reply with quote
And a hell of a lot easier to remove next time. Very Happy
ZX6R G2 (1999) & ZX6R F2 (1996). I like ZX6!
NJD
PostPosted: 12:40 - 24 Mar 2017    Post subject: Reply with quote
Probably just get the right tools for future use and keep the knowledge that I've got what I need tucked away for roadside use if ever I get stuck.
Halfords do a 27mm deep socket that looks six sided and combined with a 1/2 breaker bar works out at £23.48 so probably pick them up latter on me commute.
What about tightening it back up, just go bloody tight with the breaker bar or order a beam type torque wrench (borg recommended) from eBay?
Torque setting is something like 100-108nm.
Was only put in yesterday so if ever one's going to be re-used, providing I pull it out right, it's this one.
Yeah I figured getting the axle tight is more the focus. Counter hold the nut on the other side with a spanner while tightening?
It's what come with the bike, or what the come with the bike and then got a like for replacement yesterday.
Consider me edumacated.
davethekwak
PostPosted: 12:53 - 24 Mar 2017    Post subject: Reply with quote
Arcane1729 wrote:
Really- I feared it might fall apart if I didn't religiously stick to the workshop/original manual Confused ? Does that mean you have to switch the left and right spacer around then?
Are you serious?
The spacers are there to keep the wheel central so have to be in correct place. If you swap spacers around the wheel will be in wrong position. The axle is just a bar that tightens on the swing arm and can be reversed without issue provided it is constant section.
rpsmith79
PostPosted: 13:03 - 24 Mar 2017    Post subject: Reply with quote
davethekwak wrote:
Are you serious?
Sadly, yes he is................... very very serious
PostPosted: 13:06 - 24 Mar 2017    Post subject: Reply with quote
The do the job but they are just fiddly I've had to drill them out before because they can seize/fall apart. An R clip or Spring Pin or whatever you want to call it is a lot more user friendly you can reuse it for pretty much ever and it is simpler to install and remove..
NJD
PostPosted: 13:08 - 24 Mar 2017    Post subject: Reply with quote
Halfords do a 10, something an something breaker at what one do I go for?
Is the bigger mm just more leverage because longer handle?
talkToTheHat
PostPosted: 13:17 - 24 Mar 2017    Post subject: Reply with quote
Ebay some 6-sided sockets and a *pair* of 18" breaker bars. Otherwise you might find the axle just turns when you try to undo the nut. If on your own, you can hold both breaker bars and apply differential torque (ie push one down and the other up) or wedge one against the ground.
At a push, a ratchet can be extended by hooking a big ring spanner over the end, but it's not awfully good for your spanners.
For reference, 100nm of torque is approximately 25kg at 40cm, so you might need to lean on an 18" breaker bar or stand on your underseat tool if it's been done up 'FT', but doing it back up with suggested 18" breaker bar should feel like lifting a full (of water) 5 gallon / 25litre bucket.
Bandit. does. everything.
PostPosted: 13:23 - 24 Mar 2017    Post subject: Reply with quote
You don't need 2 breaker bars for this. If the nut is lose enough that the axle spins it will come off with a normal spanner & ratchet.
One BB is good for the initial undo.
I would also say extending a ratchet with a spanner is is worse for the ratchet. You shouldn't extend it anyway (I use a fork tube when I do Shifty )
NJD
PostPosted: 14:00 - 24 Mar 2017    Post subject: Reply with quote
I was just going to use the breaker bar on the axle side an hold the other with a spanner.
Rather use halfords than eBay.
So one breaker bar of what size from halfords?
Edit:
Split pins / r clip
Breaker bar
27mm socket
Good enough to tighten with breaker bar?
bamt
PostPosted: 14:05 - 24 Mar 2017    Post subject: Reply with quote
As above, 1 breaker bar should be enough. If the other side is spinning, then the tool that came with the bike will be enough to hold it until it's tight enough that that side doesn't spin. A breaker bar is a very useful tool to have, 18" is a good size.
I'm really not sure what Arcane1729 is saying about your axle coming in from the wrong side - it is coming in from the right (not the left as he claims), which is pretty normal.
grr666
PostPosted: 14:06 - 24 Mar 2017    Post subject: Reply with quote
Couple of chunky adjustable spanners would do the job tbh.
NJD
PostPosted: 15:07 - 24 Mar 2017    Post subject: Reply with quote
Purchased a 27mm spanner and an assortment of R clips so see how I get on tomorrow.
Probably should have got the socket to tighten it with the 1/2 ratchet I've got. Will the spanner do the job to tighten it?
Edit: server cocked up and posted short response.
Can I get away with leaving the chain adjuster locknut in place and simply loosen axle spin the plate around Andre-tighten?
Evil Hans
PostPosted: 16:14 - 24 Mar 2017    Post subject: Reply with quote
DROP YOUR TOOLS AND STEP AWAY FROM THE MOTORCYCLE.
grr666
PostPosted: 16:15 - 24 Mar 2017    Post subject: Reply with quote
Waaaay too late for that.
Evil Hans
PostPosted: 16:18 - 24 Mar 2017    Post subject: Reply with quote
Should be OK.
The last post was made 7 years, 35 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 17 - Page Size: 143.29 Kb
