rubyhorse2 |
rubyhorse2 Traffic Copper
Posted: 13:26 - 24 Mar 2017 Post subject: starting bike with a hair dryer - rant |
so fed up, glorious day so thought i'd ride into work on the KTM Adventure. opened the garage and its 5deg...immediately think the worst, tried to start her, refused. hair dryer out and heater, warm the garage up for 30 mins and boom she starts
so who else started their bike with a hair dryer this morning
Love KTM but fitting a shite starter motor and refusing to accept its not up to the job really pisses me off. |
Matt B |
Matt B World Chat Champion
Monkeypony |
Monkeypony World Chat Champion
Posted: 13:45 - 24 Mar 2017 Post subject: |
What sort of an 'adventure' are you going to have on a bike that needs to be started with a damn hairdryer every time it's a bit cool!
For the record, my fragile Italian superbike started just fine ____________________ Current bike - 2018 H2-SX, 2004 SV1000s, 2016 Aprilia RSV4 RF, 2017 Sherco SERF 300, 2003 Suzuki DRZ400 (stolen - AY53 JUU) |
davethekwak |
davethekwak Nitrous Nuisance
rubyhorse2 |
Rogerborg |
Rogerborg nimbA
Posted: 14:15 - 24 Mar 2017 Post subject: |
So cost up an upgrade and invoice them. ____________________ Biking is 1/20th as dangerous as horse riding.
rubyhorse2 |
andyscooter |
Matt B |
Rogerborg |
Rogerborg nimbA
Posted: 19:13 - 24 Mar 2017 Post subject: |
Is it not spinning fast enough, or not turning at all?
My Nazi Tractor sometimes hesitates when starting, just when hitting the first compression stroke. The electrics go a bit spazzy, first world problem.
I can ameliorate it by knocking it into 1st, rolling it forward and giving it a hard push against the compression, then back to neutral. It then tends to start up freely.
Worth trying? ____________________ Biking is 1/20th as dangerous as horse riding.
arry |
arry Super Spammer
Posted: 19:21 - 24 Mar 2017 Post subject: |
Mine has the same engine, so presumably starter, and starts just fine in all weathers |
Posted: 19:51 - 24 Mar 2017 Post subject: |
Why would temperature have a significant effect on your starter motors ability to turn your engine over?
Yes, if it is EPIC cold (like double minus figures), the oil will tend to thicken to treacle and make it harder to turn over. But not at temperatures we're getting in March in the UK while using a good multigrade oil. Definately not at 5 degrees celcius.
So. On the assumption what you're on about is that the engine wont spin over in cool conditions, you don't have enough cranking amps from the battery. The starter motor will produce the same power and torque regardless of temperature (within reason) but only if it has enough amps coming from the battery. Low cranking amps may be because the battery is fucked, badly connected, not big enough or not being charged properly. I'd take it to someone with a battery load tester to see if it's up to spec. and if it's not, replace it (take the battery to a battery factors rather than a KTM dealer).
If what you mean is the engine will turn over but the bike will only start in warm conditions, that's a cold starting issue and is to do with fuelling. In a modern bike probably a sensor issue or a problem with the FI control unit. Admittedly cold starting can be an issue with big singles but 5 degrees is not what I'd consider cold. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 22:58 - 24 Mar 2017 Post subject: |
I'd second stink; it's ore likely they have fitted a more marginal battery, than a more marginal starter.
Starter may still be marginal, but, if warming the garage up a few degrees makes that much difference, its most likely increasing the rate of reaction in the battery electrolyte and getting a couple of extra cranking amps from it, than lowerig the resistance of the pound of copper wire in the starter windings to drop the current draw, or thinning the oil and grease enough to make much odds.
But it is an KTM......
I wouldn't assume just because the factory fitted an 'alternative' starter at some point that it was necessarily an 'upgrade'. Switch would more likely t have been made for cost-cutting as anything. I WOULD take pretty good guess that the battery was under-sized to fit in space left by the stylists, and or loose a few grams off the dry-weight, and or, more likely and, for cost cutting! Meanwhile if cold cranking was an issue, it would be perverse to fit a lower powered starter... solution would be a more powerful one, that would beg a beefier battery
If starter will spin engine up... I wold
1/ Try use it more! Keep battery better topped up & parts from gumming
2/ Stick battery on charge for ten minutes before trying to start (Rather than a hair-dryer/heater!)
3/ Check battery terminals, starter cables, relay and earths.
4/ Check battery electrolyte levels / drop test charge capacity
5/ Replace battery.... Seven-Fifty's has just managed 3-years, which is probably a record; most are knackered after about 18months!
6/ If I cant use it more, & a ten minute charge isn't enough, with new battery and clean contacts.... MIGHT capitulate to the 'occasional biker' recourse of a trickle-charger/optimizer.
But if THIS is all I had to grumble about from a Viennese Wurlitzer? I think I'd probably just count my blessings! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
Arcane1729 |
Arcane1729 Banned
Posted: 01:04 - 25 Mar 2017 Post subject: |
my bike started cold at a push after 3 weeks of solid abuse ____________________ Kymco Super 8 (125) Honda CBR 125
A2 2017
Teflon Mike: "A man can dream... but most of them are probably best not voiced.... Folk will likely think you are just mad, sad or simply a pervert." |
M.C |
M.C Super Spammer
Arcane1729 |
Arcane1729 Banned
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 03:27 - 25 Mar 2017 Post subject: |
Arcane1729 wrote: | my bike started cold at a push after 3 weeks of solid abuse |
Curiously, for all I deride chinky bikes, Snowie's old 125 cruiserette, left outside unused, untouched for two months over the Christmas period 'stunned', starting 1st time on the button... making me wonder why I'd bothered flaking out the extension leads and digging out the charger.
Her Guzzi's a bit curious too.... A longitudinal V-Twin, the engine bolts to the gearbox car style, with a car style clutch in the middle, and a car type shaft drive to the back axle; heritage of it's design back in the mid 70's when motorbike e-starts were less common and unreliable, they used a small car starter motor and battery... seriously, the battery is the same size as they fitted to old Fiat 500's and stuff; the battery compartment is HUGE, and only about 2/3 filled by modern 'equivalent' of same Ah rating... which is still pretty big!
Given the reputation of Italian electrics, especially of late era 1990's 'plastic' Italian electrics, its bizarre, that the thing will just keep cranking and cranking and cranking... and f it doesn't start odds is it'll be down to something stuck in the Del-Awful carbs!
Given the rest of the electrics work on the weejah principle... they all work... but usually whenever they want to, rather than when you prod a button, the lethargic dependability of the self starter, is just one of the idiosyncrasies of the marque I suppose! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
mentalboy |
mentalboy World Chat Champion
Wafer_Thin_Ham |
Wafer_Thin_Ham Super Spammer
ADSrox0r |
ADSrox0r World Chat Champion
Teflon-Mike |
Teflon-Mike tl;dr
BTTD |
BTTD World Chat Champion
RhynoCZ |
RhynoCZ Super Spammer
Teflon-Mike |
Teflon-Mike tl;dr
Posted: 02:24 - 26 Mar 2017 Post subject: Re: starting bike with a hair dryer - rant |
RhynoCZ wrote: | Does the starter spin the crank? If so, then buy some ether/starter spray. Spray it into the intake (the airbox is fine). If that won't help starting your engine, then spray the ether on a rag and have some 1800's fun instead of riding. |
EZ-Start /Etha Dependency.... have you heard of it?
Active ingredient in easy-start type products is ethyl alcohol, I believe, it 'works' as a starting agent as it has a higher volatility / flammability than petrol, ie it catches fire easy....
Principle is that a squirt of ether, gives extra enrichment... like using the choke... so commonly advised you DON'T actually use choke.. which is difficult on a fuel injected engine that doesn't have one, it has a cold start circuit, which ups the fuel map to bung in extra fuel if temp sensor reckons it's cold.....
Stuff 'works'.... but.. it's not 'solving' the problem. Engine aught start as designed on the starter, with choke if necessary, not a can of squirty stuff. So it's not 'solving' the problem... it's just patching over it.
Meanwhile, if you don't fix the problem, stopping engine start as it should, then tendency is to use EZ start on ever more regular basis, and dependency creeps in, to point that they will often not start without it.
Cause is that the alcohol washes lube off the cylinder walls, when cylinder most needs all it can get, when cold, on start-up, so leads to accelerated bore and ring wear. Worse, 'thinning' oil, it makes what was there volatile, to help that get burned too, leading to bore glazing... compound result is engine starts to loose compression as well as wear faster, and as it does so becomes increasingly difficult to start, begging more EZ-Start, more regularly, even when its not so cold.
Horrible, horrible 'stuff'... must admit it DOES smell nice.... BUT it really isn't good for engines... may get you out the cacky for a week whilst waiting for bits to turn up to fix the problem properly, but, even that's not really ideal, and just having the stuff around, begs notion you can 'put off' the fix, and just keep using the squirty can to get it going.....
It is NOT something I 'recommend' any-one resort to, really.... stuff has tendency to do more harm than good, ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
NutsyUk |
NutsyUk Nearly there...
Posted: 13:53 - 26 Mar 2017 Post subject: |
Even my shitty lexmoto starts up in subzero temps :p
Bit stupid that a bike that costs as much as that one does cant manage to start up... Sure maybe bikes need to warm up after starting cold for a little.... but not actually start at all cold... Not good.
Oh and yeah. Yesterday i picked up my bike to take down where I was staying... And it started first time... Sat in the shed for nearly 2 months... and started WOOoooo... ____________________ Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Lexmoto XTR S 125 Sold! |
The last post was made 7 years, 31 days ago. Instead of replying here, would creating a new thread be more useful? |
