Clacking and plinking engine noise CBR 125 (SOLVED)
Howaboutno
PostPosted: 16:14 - 25 Mar 2017    Post subject: Clacking and plinking engine noise CBR 125 (SOLVED) Reply with quote
Hey guys,
I own a CBR 125r 2004 and need some advice identifing an abnormal engine noise. See video:
https://youtu.be/o88h0Dn9eDY
Basically an intermitant clacking noise, I predict it's the valve timings but thought i might get a second opinion before i start work on it.
Heres a little history on the bike that might help with the diagnosis:
It's been happening for about 6 months and getting slowly more pronounced. Seems to happen hot or cold engine. Started a few weeks after I used it for a courier job so i rode it about 40 miles daily.
The bike's has had a loose choke cable for a while so maybe idling too rich for a period.
Also fill it up with premium unleaded usually 99 but from different petrol providers (haynes manual suggests minimum 91)
Had a service about 7 month ago i doubt they adjusted the valve timings though.
Oil has been changed recently and about every 6 months. Worth noting that the noise stopped for about a week after an oil change then started back up.
Any suggestions or Ideas of what could be causing the noise would be apreciated.
Cheers guys
PostPosted: 16:27 - 25 Mar 2017    Post subject: Reply with quote
Does it quieten down if you hold the clutch in?
Howaboutno
PostPosted: 16:33 - 25 Mar 2017    Post subject: Reply with quote
Theres no noticable change in the noice when the clutch is in
barrkel
PostPosted: 16:35 - 25 Mar 2017    Post subject: Reply with quote
Could be cam chain tensioner or clutch basket.
If it gets quieter with clutch held in per Rogerborg, likely clutch basket. If it makes a kind of rubbing noise when slowing down after a quick rev from idle, then could be CCT.
Howaboutno
PostPosted: 20:04 - 25 Mar 2017    Post subject: Reply with quote
Yeah it definitely is not effected by the clutch.
To my knowledge the cam chain is adjusted automatically by the tensioner. So what your saying is the tensioner might not be functioning correctly.
Thanks, I'll check it out
The noise doesn't change to a rubbing though, just the knocking noise. Sometimes effected by change in throttle, but I've yet to find a pattern.
Howaboutno
PostPosted: 15:21 - 26 Mar 2017    Post subject: Reply with quote
Just an update:
So I reset the CCT and took the bike out for about an hour. It seems to have stopped the noise, so the CCT arm must have been stuck and not tensioning the cam chain. Very simple fix.
Thanks for the advice guys, it was helpful.
The last post was made 7 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.85 - MySQL Queries: 17 - Page Size: 49.42 Kb
