Stuck brake pistons
Yorkshire Geek
PostPosted: 19:48 - 25 Mar 2017    Post subject: Stuck brake pistons Reply with quote
As always, simple job on 21 year old bike turns out to be slightly harder than expected. I decided to give the brakes a going over before the MOT and they were not only very grubby but I can't get the damn pistons out. Grubby was sorted with some brake part cleaner, but the pistons are stubbornly not shifting.
Looking for alternatives to hooking it back up and trying the hydraulics but I've drained the fluid for replacement. Worst case i refill and try that but I'm looking for alternatives if there are any.
I don't have a compressor before anyone suggests that though, would be handy about now.
Itchy
PostPosted: 20:03 - 25 Mar 2017    Post subject: Reply with quote
Buy one of these:
https://www.ebay.co.uk/itm/Sealey-Motorcycle-Motorbike-Brake-Caliper-Piston-Removal-Remover-Pliers-VS1806-/371084615189?hash=item56665dde15:g:dTQAAOSws65ToELT
Or one of these:
https://www.ebay.co.uk/itm/Motorcycle-Motorbike-Scooter-Brake-Piston-Wind-Back-Removal-Garage-Tool-Set-8191-/222055742039?hash=item33b38dba57:g:zHgAAOSwP~tW6YKH
(I have one of these).
Or refill the system and bleed it and use the hydraulic pressure to push them out.
PostPosted: 20:24 - 25 Mar 2017    Post subject: Re: Stuck brake pistons Reply with quote
Just do it. It won't take as long as you think.
I've got an old master cylinder with a single brake hose on for just such eventualities. I just do it on the bench.
TUG
PostPosted: 20:29 - 25 Mar 2017    Post subject: Reply with quote
Hook it back up, pump the pistons out. Work smarter not harder.
Haz ER-5, innit!
kgm
PostPosted: 20:33 - 25 Mar 2017    Post subject: Reply with quote
I once used a foot pump and one of the little football type attachments. That piston had been in there without moving for 36 years.
Yorkshire Geek
PostPosted: 20:46 - 25 Mar 2017    Post subject: Reply with quote
Tried that but even the biggest adapter I have is (to borrow a sexual euphemism) like chucking a hotdog down a hallway. Looking like hook it back up is the likely answer.
Itchy: Tried pliers with a piece of inner tube as padding, are the real ones significantly better than that bodge option?
Tankie
PostPosted: 20:58 - 25 Mar 2017    Post subject: Reply with quote
leave them on he hose and pump them out
Itchy
PostPosted: 21:03 - 25 Mar 2017    Post subject: Reply with quote
The expensive kit works every time. Probably why every BCFer in the norf area has borrowed them.
But as said the other option is just to use the hydralic pressure from putting them back on the master cylinder. A bleed job takes 20 minutes at most.
Yorkshire Geek
PostPosted: 10:29 - 26 Mar 2017    Post subject: Reply with quote
Hooked it back up, went to take the reservoir cover off, screws were stuck and I forgot all about JIS temporarily so stripped them trying to loosen with a PH1 bit. Going to have to drill those out now, replacements should be here Tuesday and finally ordered a set of JIS drivers.
Petemate
PostPosted: 12:29 - 26 Mar 2017    Post subject: Reply with quote
Aint got any JIS driver bits but my original toolkit screwdriver is my friend. It even shifted the three screws on the oil pump which had been on there for 33 years.
Oh, and I had slight problems with the pistons in my caliper, but they came out OK and cleaned up nicely.
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
Yorkshire Geek
PostPosted: 19:55 - 26 Mar 2017    Post subject: Reply with quote
Sitrep: Reservoir screws out without damaging anything else. Rear brake caliper off, front back on and ready for bleeding but ran out of daylight.
Yorkshire Geek
PostPosted: 21:56 - 26 Mar 2017    Post subject: Reply with quote
Related question - neither front or rear brake pads had springs behind them. The support pads at the top are present, but not ones that push from behind. How important are they? Hadn't noticed any issues, and presumably the previous owner thought then optional, but should I replace them?
PostPosted: 22:33 - 26 Mar 2017    Post subject: Reply with quote
Which springs pushing from behind?
Katy
Yorkshire Geek
PostPosted: 22:44 - 26 Mar 2017    Post subject: Reply with quote
Part 9 on this page for the front - https://www.motorcyclespareparts.eu/yamaha-parts/motorcycles/xj600s-1999/front-brake-caliper-346656.aspx
Part 10 on this for the rear - https://www.motorcyclespareparts.eu/yamaha-parts/motorcycles/xj600s-1999/rear-brake-caliper-346680.aspx
PostPosted: 23:08 - 26 Mar 2017    Post subject: Reply with quote
They are a push fit onto the carrier, rather than being on the actual caliper
Katy
The last post was made 7 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 0.4 - MySQL Queries: 17 - Page Size: 91.45 Kb
