RhynoCZ |
RhynoCZ Super Spammer
Suntan Sid |
MarJay |
MarJay But it's British!
Petemate |
Petemate Trackday Trickster
Posted: 20:44 - 16 Apr 2017 Post subject: |
IMHO a lot depends on the material that the discs are made from, and how expensive they are. I would prefer to replace pads more often, providing they gice excellent performance, than to use hard pads and replace expensive discs. My own bike has the front disc set-up from the CB125 Superdream and the disc for these is fairly expensive. I have a pair of Kyoto pads which I got from the bay. Quite inexpensive, and despite bad reviews on some other forums, I am very pleased with mine. They are not rapidly wearing the disc (thank f**k), they are lasting well, and the perfomance is very good wet or dry. Progressive, and probably are working OK considering the light weight of the bike (which is virtually a bored and stroked CM125 Custom). I guess, though, that with a larger heavier bike, the situation may be different, and when/if I progress to something bigger I may research and think again. ____________________ 82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth |
Bozzy |
Bozzy Traffic Copper
Snod Blatter |
Snod Blatter Crazy Courier
Posted: 13:59 - 17 Apr 2017 Post subject: |
Petemate wrote: | I have a pair of Kyoto pads which I got from the bay. Quite inexpensive, and despite bad reviews on some other forums, I am very pleased with mine. They are not rapidly wearing the disc (thank f**k), they are lasting well, and the perfomance is very good wet or dry. Progressive, and probably are working OK considering the light weight of the bike (which is virtually a bored and stroked CM125 Custom). I guess, though, that with a larger heavier bike, the situation may be different, and when/if I progress to something bigger I may research and think again. |
I have Kyoto pads in the front of my TRX850, which has two 4 pot Brembo calipers up front and big(gish) discs. My experience with them is apparently very different from yours.
Pros:
Painted bright blue
Don't seem to be wearing down
Squishy so lots of feel, and not a lot of immediate bite (good for overbraked bikes, I suppose?)
Cons:
Not very bitey
Actual, real, wet weather lag. I mean I'm talking a good two seconds before the brakes start to work. Are you kidding me??
Can't really see that they're bright blue when in the calipers
Overall I'd rate the £6 Chinese pads well ahead of Kyoto pads. ____________________ 1994 CB250, 1984 CBX250RS-E, 1989 K100RS, 1995 TRX850, 2016 Z250SL |
Suntan Sid |
Posted: 20:00 - 17 Apr 2017 Post subject: |
Suntan Sid wrote: | There wasn't a problem with braking, I'd assumed, wrongly, they were due to be changed, turns out they didn't, I'll have to try braking a bit harder I guess! |
MarJay wrote: | Take the calipers off, take the pads out and clean up the calipers with a brush and loads of brake cleaner. Try to see if you can push all pistons back into the body of the caliper. If any are seized it'll be pretty obvious. Re-assemble the lot with a smear of copper grease on the pad pins and the backs of the pads and see if your braking improves. I often find a quick clean and re-grease works wonders. |
When I said I'll have to try braking a bit harder, I meant I should actually use the brakes a bit more!
I thought they might need changing because they've been on a while, I thought they might have worn down. You can't actually see the pads without taking the calipers off. I had both calipers off, pads were fine, nothing seized and no leaks, a quick clean and everything went back on. ____________________ "Everybody needs money, that's why they call it money!" |
The last post was made 7 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
