Bandit exhaust manifold
bryera
PostPosted: 17:12 - 13 Apr 2017    Post subject: Bandit exhaust manifold Reply with quote
Hay guys I am currently doing a bit of work on the Bandit new chain sprocket respraying wheels and noticed the bolts on my exhaust manifold are coming lose but someone has tried to tighten them up and rounded off the heads and don't know how to get them out to replace with new ones any ideas would be much appreciated got some pics to hopefully get a better idea
https://i208.photobucket.com/albums/bb106/bryera89/20170413_163605_zpsevjfvfbq.jpg
https://i208.photobucket.com/albums/bb106/bryera89/20170413_163620_zpsq53yfavc.jpg
https://i208.photobucket.com/albums/bb106/bryera89/20170413_163636_zps8vgirzxt.jpg
Tankie
PostPosted: 17:17 - 13 Apr 2017    Post subject: Reply with quote
see if a slightly larger imperial allen driver 3/8 or 1/2 drive socket type can be hammered in.
If those bolts are m8 the size you will need is 1/4 inch
redeem ouzzer
This will be fun.
Do you have lots of drills on stock?
Be a REAL MAN!
RhynoCZ
PostPosted: 17:21 - 13 Apr 2017    Post subject: Reply with quote
Punch in slightly bigger alan socket. Warm it up before you try to take them off. Just ride it or use a torch. Penetrating oil should help.
IF punching in sligtley bigger socker won't help. THEN get a hacksaw and cut a straight line into each individual bolt, roughly through the center of the head of each stubborn bolt. Then you can give it a go with a screw driver socket. Make the grove deep enough, so you have good grip.
IF all the above fails, then I'd just cut the heads of the bolts off, remove the exhaust and then use 2 nuts to get the rest of the bolts out, just like when you remove engine head studs or use a stud extractor.
Oh, and before you even touch it, buy yourself new bolts and seals. You do not want to reuse the copper crushable seals, nor the fecked up bolts.
https://i.ebayimg.com/images/a/T2eC16Z,!)0E9s37HkTGBP6,9omYmg~~/s-l300.jpg
Pete.
PostPosted: 17:26 - 13 Apr 2017    Post subject: Reply with quote
If it's not blowing DON'T TOUCH THEM. I had all eight snap on me once.
a.k.a 'Geri'
bryera
PostPosted: 23:45 - 13 Apr 2017    Post subject: Reply with quote
Thanks guys I will have a go at that and yer Pete it is blowing a little bit and not going to enjoy doing it but may as well do it while I am doing rest thanks guys
The last post was made 7 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.68 - MySQL Queries: 17 - Page Size: 50.24 Kb
