Falco |
Falco Traffic Copper
A100man |
A100man World Chat Champion
Posted: 08:22 - 14 Apr 2017 Post subject: Re: Valve Clearance Questions (CB500) |
Falco wrote: | It has come time to do the valve clearances (or at least take the measurements). As this is my first time doing shims under buckets, I have a couple of blindingly obvious questions:
1) Do you really have to take the camshafts and buckets out to check the shim size for ordering replacements?
2) The method for calculating shim replacements: (specified clearance - measured clearance) +/- original shim thickness (depending on if clearance is too large/small), is this correct? |
1) Measure first then remove c/shafts to check current sizes (if they're out of spec) - don't mix em up in the process
2) Yes ____________________ Now: A100, GT250A, XJ598, FZ750
Posted: 09:37 - 15 Apr 2017 Post subject: |
I confidently predict they will all be within tolerance.
But Yes and Yes.
Also do not believe the numbers stamped on the shims except as a very rough guide.
Toilerances aside, it's not unusual to grind down an oversize shim thinner if you need a thinner one. I've done it myself, I'm considerate and grind the numbered face, others might not think that far ahead.
If you don't already own a micrometer, now is the time.
You'll probably want some silver paint for the rocker cover too. Plastikote radiator satin chrome works well and is a close match to the original. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Petemate |
Petemate Trackday Trickster
Falco |
Posted: 00:22 - 16 Apr 2017 Post subject: |
stinkwheel wrote: | I confidently predict they will all be within tolerance.
But Yes and Yes.
You'll probably want some silver paint for the rocker cover too. Plastikote radiator satin chrome works well and is a close match to the original. |
I'd be very happy if they were within tolerances, but we shall see - at least a couple seemed out (though I can't be sure without a more comprehensive feeler gauge set) (its on 23K, so its due a check at the very least).
How did you know the valve cover would need a coat of paint? On an otherwise nice bike it was the first thing I noticed. Wire brush and Hammertite last weekend, it came out quite nicely, all things considered. ____________________ I tell you what, mathematically, I'm having it |
Falco |
Posted: 14:06 - 16 Apr 2017 Post subject: |
Sorry Stinkwheel, every. single. valve. out. of. spec.
Yaaaay public transport until the new ones are delivered. ____________________ I tell you what, mathematically, I'm having it |
Baggyman |
Baggyman Crazy Courier
Falco |
The last post was made 7 years, 10 days ago. Instead of replying here, would creating a new thread be more useful? |
