Pitted metal...
Chris45
PostPosted: 16:44 - 16 Apr 2017    Post subject: Pitted metal... Reply with quote
While removing light rust from the frame I noticed some areas where it has pitted the metalwork. Is there a way of filling these in prior to respraying the frame? Maybe use a (car) body filler then flatten it down?
Ta.
Honda CG125>Suzuki GT185>Honda CB 250N>Suzuki GSX400>Honda CX500B>Kawasaki GPZ305> Kawasaki GPZ550>Kawasaki GPZ500S+BMW 650GS
PostPosted: 16:47 - 16 Apr 2017    Post subject: Reply with quote
I take it not pitted enough to be a structural worry?
Then fill it with something. weld, liquid metal, epoxy, filler and file/sand smooth.
Triumph Trophy Launch Edition
Chris45
PostPosted: 18:59 - 16 Apr 2017    Post subject: Reply with quote
No. I simply need the best finish possible when I've resprayed the frame, and at the moment it will look dimpled and too obvious. Have watched programes on TV where they apply a thin layer of body filler over slight dents and imperfections. Was wondering if this technique would work on small areas of a frame. Am trying to achieve a very high standard of finish.
Thanks.
Petemate
PostPosted: 20:23 - 16 Apr 2017    Post subject: Reply with quote
IMHO it is a good idea to fill such imperfections as those described. At the very least you will avoid the possibility of further intrusive corrosion whch will then definitely weaken the structure. However, take great care to completely kill existing corrosion with an appropriate treatment, many of whch are available. (Kurust is what I use)
In the case of my little LA250, when I stripped it down and treated the frame etc prior to priming and painting, even though the bike is 34 years old, there was only surface rust on it, and happily no deep pitting. Although some rust has appeared again, it is very light surface and I can see that this is from stone chipping (eg on the swinging arm directly in the path of the spinning rear wheel!) and the areas concerned will likely benefit with a clean and treatment with Kurust (my can I used initially has now dried out and I will need to get a fresh one).
Good luck Chris, and preparation is the key (pun intended)
82 not out....1983 Honda LA250 Custom
2008 Saab 9-3 1.9 Tid 150 Vector Sport estate
2005 Stirling Eccles Topaz 2-berth
Stephenniall
PostPosted: 22:51 - 16 Apr 2017    Post subject: Reply with quote
Use a light skim of Upol Dolphin Glaze. It's a self levelling filler designed for pin holes, and light damage. Skim it over the area as smooth as you can, then sand back with 180 grit till all smooth, then prime & paint as usual.
Chris45
PostPosted: 23:27 - 16 Apr 2017    Post subject: Reply with quote
Perfect response, Thanks Thumbs Up
Thanks to Petemate for elaborating on what my limited experience of these matter couldn't! Thumbs Up
Chris
The last post was made 7 years, 8 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.18 - MySQL Queries: 17 - Page Size: 50.67 Kb
