A100man |
A100man World Chat Champion
Posted: 13:50 - 19 Apr 2017 Post subject: Re: Valves Wearing? |
Falco wrote: | A100man wrote: |
Hang on, if they are that bad (tight) you wouldn't be able to get a feeler in there at all. Not mixing metric and imperial measurements by any chance are you? What measurements are you actually getting with the old shims? |
Why wouldn't I be able to get a feeler in? For the 1st exhaust valve with a clearance of 0.178mm, a shim size of 0.210 and a specified clearance of 0.260, gives a replacement shim size of 0.130. I can easily get a 0.15 feeler into that gap.
The measurements:
https://i63.tinypic.com/2jfysyx.jpg
Ok fair enough, tbh I've only dealt with shim over bucket before and those are big items by comparison. At .130 mm your talking about a 5 thou shim (sorry struggle to think metric in these things.)
Like Fizzer says though might be worth checking the valve profile to see if new will help or just do the best you can for now and keep a look out for a newer head. ____________________ Now: A100, GT250A, XJ598, FZ750
Falco |
Falco Traffic Copper
Posted: 23:23 - 23 Apr 2017 Post subject: |
Even thinking about putting new valves in seemed like a hugely scary job, but looking at the procedure, its not actually too bad. But at £230 just for the parts just putting a new engine in seems like it might be easier (which seems crazy but there you are).
A100man wrote: | Ok fair enough, tbh I've only dealt with shim over bucket before and those are big items by comparison. At .130 mm your talking about a 5 thou shim (sorry struggle to think metric in these things.)
Like Fizzer says though might be worth checking the valve profile to see if new will help or just do the best you can for now and keep a look out for a newer head. |
I found the problem, it wasn't the measuring of the clearances (which was correct), it was the calculations for replacement shims Consistently dropped the decimal point when subtracting clearances from the shim sizes Using the correct method, no shim needed was below 1.90mm, so though they have all closed up, it's not by much. Wasted the entire weekend before I figured it out but no one to blame but myself.
Cheers for the advice ____________________ I tell you what, mathematically, I'm having it |
Hong Kong Phooey |
Falco |
A100man |
Posted: 12:07 - 24 Apr 2017 Post subject: |
Falco wrote: | Using the correct method, no shim needed was below 1.90mm,..
Cheers for the advice |
Aha, that sound more like it! Well done for reporting back (you dunce) ____________________ Now: A100, GT250A, XJ598, FZ750
The last post was made 7 years, 4 days ago. Instead of replying here, would creating a new thread be more useful? |
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 17 - Page Size: 49.96 Kb
