RickTaff |
RickTaff Nitrous Nuisance
Rogerborg |
Rogerborg nimbA
Posted: 23:14 - 16 Apr 2017 Post subject: |
Leave the plug in the cap, and hold the plug against the engine using gloves or insulated pliers. Darken the area if possible, then crank. You should see a strong blue spark across the plug gap. ____________________ Biking is 1/20th as dangerous as horse riding.
Kickstart |
Kickstart The Oracle
Posted: 23:17 - 16 Apr 2017 Post subject: |
That is the normal way to do a quick test. Although you can just stuff a plug in it and hold the plug against the engine while you do it.
But that won't tell you how healthy it is. The manual will have a range of values for resistance of the coil, and it might work while outside those ranges. Hence you really need a multi meter. Even then things change with temperature.
Also some coils have an integrated cdi unit. In which case full tests might not be possible with a meter.
Katy ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
RickTaff |
RickTaff |
WD Forte |
WD Forte World Chat Champion
WD Forte |
Robby |
Robby Dirty Old Man
RickTaff |
WD Forte |
The last post was made 7 years, 2 days ago. Instead of replying here, would creating a new thread be more useful? |
