skyeblueman |
skyeblueman L Plate Warrior
Posted: 16:32 - 26 Apr 2017 Post subject: Clutch Problem ?? |
I have a Yamaha XJR 1300. Used the bike couple of days ago and all was well. Started it this morning, no problem, however, when I pulled in the clutch and put it into first it shot forward a few inches and stalled. I again pulled the clutch in, put it into neutral, started it, but again, as soon as I put the bike into first gear same thing happened.It feels like the clutch is ok for selecting gears and neutral but as soon as the engine is running, the clutch doesn't hold. There is plenty of clutch fluid in the reservoir and I am able to go into neutral and up and down the gears when the bike is off. Any ideas, is a new clutch needed ?. Desperately need help as need the bike for work. Many thanks. |
arry |
arry Super Spammer
Matt B |
Matt B World Chat Champion
arry |
arry Super Spammer
skyeblueman |
skyeblueman |
arry |
arry Super Spammer
Pete. |
Pete. Super Spammer
Posted: 13:44 - 27 Apr 2017 Post subject: |
Clutch fluid pulls moisture in from the atmosphere and contaminants from the rubber hose so it needs to be changed periodically (as do the rubber lines). Your rider handbook or maintenance manual should specify how often but certainly if it appears darker in colour then it needs changing.
A more likely cause of your trouble is the slave cylinder. It's position down near the front sprocket make it a prime candidate for collecting road dirt ad usually they are pretty badly gunged-up with old chain grease and road much over time, especially like now after a winter.
Look here for an example: https://www.bikers1.com/load4.php?id=411 ____________________ a.k.a 'Geri'
skyeblueman |
The last post was made 6 years, 363 days ago. Instead of replying here, would creating a new thread be more useful? |
