Corroded ally case
Paulf
PostPosted: 22:07 - 30 Apr 2017    Post subject: Corroded ally case Reply with quote
I have got a ally transmission case that is corroded, blisters and white dust. The problem is once I got the paint off, been recommended aircraft remover, the corroded surface is pitted. Which filler do members recommend. I know that to paint I need an etch primer. I would just like the finish to be reasonable.
Past bikes simsom mofa 1s, suzuki hustler 250 (£35 in 1973), suzuki ts125k, mz150, yamaha yb 100, honda pc50, honda vision 50, all 2 stroke - then cars - honda pcx 125 (sold) own honda fes 125 and Mrs 125 spares or repairs. Started 1972 all accidents walked away no insurAnce claims
Stephenniall
PostPosted: 22:20 - 30 Apr 2017    Post subject: Reply with quote
Clean the metal well.
1 light coat of etch is all that's needed on Ally, follow with 3-4 coats of good high build primer (2K Ideally).
Unless it's really severe pitting 2K Primer will usually fill any small pitting and allow you to flat back well for paint.
Paulf
PostPosted: 22:50 - 30 Apr 2017    Post subject: Reply with quote
Thanks will try it
PostPosted: 10:34 - 01 May 2017    Post subject: Reply with quote
I just do a plastikote BBQ paint directly onto engine casings. It's a bit soft once dry until it's been heated/cooled a few times so you either need to fit them and take care the first couple of rides or bake them in a low oven after.
Very forgiving satin black finish.
https://i48.photobucket.com/albums/f216/stinkwheel/cb500/DSCN0321.png
ZRX61
Victor Meldrew
PostPosted: 01:17 - 08 May 2017    Post subject: Re: Corroded ally case Reply with quote
Filler & etch primer is a no-no... Filler goes over 2 things: Bare metal or epoxy primer.
Although with that said, just how corroded is the case that it needs filler?? Got pics?
They're not one night stands, they're auditions.
The last post was made 6 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 17 - Page Size: 46.34 Kb
