| Deadonkey |
 Deadonkey Renault 5 Driver
| notbike |
 notbike World Chat Champion
 Posted: 18:25 - 09 May 2017 Post subject: |
Dunno what you're going to do about fixing up the scuffs, but these will prevent it happening again/will help if you slide it down the road:
https://www.rg-racing.com/browsetype/Engine_Case_Sliders/Yamaha/XJ6/
Rather slide on those and pay £50, than a cracked open case with engine oil going everywhere.
I'm getting the full engine casing kit that they make for the R6 because I recently dropped my bike too so I feel your pain. Unfortunately mine's costing me £700 in fairings ontop of new bar ends and swingarm spools, of which I've popped some R&G ones on a few weeks ago.
But thankfully, no damage to swingarm/engine or any metal parts at all.
Neutral, facing downhill, took hands off bars, leaned back up off the bike, it rolled forwards, clunk.
Shit happens. |
| ThatDippyTwat |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 19:18 - 09 May 2017 Post subject: |
https://www.youtube.com/watch?v=sHm_wizutuA ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| Tracer1234 |
 Tracer1234 World Chat Champion
 Posted: 19:43 - 09 May 2017 Post subject: |
My Street Trip, I think was lowered by the previous owner. I never knew this for sure, but the angle of lean when on the side stand small.
When on anything other than flat ground, it always felt precarious, so just be aware of that when thinking about lowering it.  ____________________ Riding: Yamaha MT-09 Tracer Occasionally Riding: 08 Suzuki SV650, Potato: 2011 Yamaha YBR Custom.
Used to ride: 2015 Yamaha MT-09 Tracer (smidsy) 09 Triumph Street Triple (P/X'd) 08 Yamaha YBR (Sold)
CBT 04/14. A: Mod 1 & 2 13/04/15 |
| Deadonkey |
| RhynoCZ |
 RhynoCZ Super Spammer
| Rogerborg |
 Rogerborg nimbA
 Posted: 20:29 - 09 May 2017 Post subject: |
Great to see the usual "you don't need to" advice from the stork-leg brigade.
40mm is a fair bit but it looks like the only kit available for your techno-suspension. You can drop the front forks through the yokes to match, but I would indeed be a-scared that it's going to cause issues with the stands. My lowered GS can't take the standard centre stand and I believe my side stand is shortened.
However, it's super easy to flat foot it both sides - it's my lowest bike, and sod riding when you're fretting about dropping it. Life's too short, pun intended. I reckon I'd give it a go and deal with the stands if necessary. ____________________ Biking is 1/20th as dangerous as horse riding.
| RhynoCZ |
| Marclev |
 Marclev Nova Slayer
 Posted: 00:39 - 10 May 2017 Post subject: Re: First drop - Lowering advise |
| Deadonkey wrote: | Well, after 700 miles in 3 weeks since having my first bike,
It went over.
I stopped on an off camber, put my foot out and it was a bit further than usual till my foot touched the ground.
At this point the bike was past the critical angle where I couldnt hold it.
Some nice cyclists helped me pick it up, Very minimal damage. Im also absolutely fine
Slight scratching to the engine casing and the bar end.
Bar ends simple enough to replace but what do people do with scratched engine casings? I guess they are a pain to change? can you get matching paint to spray them?
This is the second time Ive dropped an XJ6. The problem is for me to flat foot the bike it has to be at an angle, so if anything causes that angle to become slightly more the bike goes over.
Its not much either.
There is a lowering kit available for the XJ6 that lowers the back end by 40mm by modifying the position of the rear shock, after discussing this with a biker friend he suggests I just keep with the bike as it is, as using lowering kits causes further issues with the side stand/bike angle and the centre stand. But i feel it would help me confidently move the bike around.
I would be interested to hear some views.
Many Thanks
Richard |
The XJ-6 is a heavy machine with a high centre of gravity, great for stability on motorways, but I sometimes found mine awkward to keep balanced at very low speeds, compared to the CB600 I learnt on (and that was a tank too).
I now have a ZX6R and briefly had an MT-09 before that, both are a dream at slow speeds (the MT-09 a lot less so at high speeds though, hence the "briefly"), so rest assured it's not necessarily anything to do with your skill, that thing is just heavy.
All I can recommend is keep practising, your body does learn to cope with the weight. Bear in mind even if you lower it, it'll be just as heavy, and the weight is the petrol tank and engine, so the centre of gravity won't be much different. Flat footing or not, you'll basically still have the same "critical angle" (although it should be harder to lose your footing of course),
Also you've learnt a valuable lesson about being mindful of the camber when deciding where to park. I doubt you're the first to have learnt that lesson that way! |
| Matt B |
 Matt B World Chat Champion
| Hawkeye1250FA |
 Hawkeye1250FA World Chat Champion
| Deadonkey |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:50 - 10 May 2017 Post subject: |
How thick is the stock seat? If it were an older bike, I'd be looking at buying a spare seat and having a go with some camping/exercise mat closed-cell foam and a staple gun.
<TefAlert> Modern seats seem to be getting thinner though, there may not be a lot to be trimmed. </TefAlert> ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 9 years, 29 days ago. Instead of replying here, would creating a new thread be more useful? |
