ko5i |
ko5i Scooby Slapper
CaNsA |
CaNsA Super Spammer
Bloggsy |
Bloggsy Spanner Monkey
Posted: 17:45 - 12 May 2017 Post subject: |
Wot e said ____________________ If It Aint broke Don't Fix It |
ko5i |
ko5i Scooby Slapper
Posted: 17:54 - 12 May 2017 Post subject: |
ok thanks gonna go tomorrow get it fixed |
MCN |
MCN Super Spammer
Posted: 21:50 - 12 May 2017 Post subject: |
There should be no problem to fit a plug in it and forget all about it.
But some companies get all queasy when you ask them to fix a puncture.
And especially if it's a bike (because bikes are dangerous ).
They may quote guidelines bla bla bla...
https://www.btmauk.com/wp-content/uploads/2014/12/Minor-repairs-to-passenger-car-and-light-van-tyres.pdf
But that looks like a nice job for a plug. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
ADSrox0r |
ADSrox0r World Chat Champion
jaffa90 |
jaffa90 World Chat Champion
Wafer_Thin_Ham |
Wafer_Thin_Ham Super Spammer
Posted: 09:09 - 13 May 2017 Post subject: |
Looks like a job for a mushroom plug. No problem. ____________________ My Flickr |
Matt B |
Matt B World Chat Champion
kharlton |
kharlton Derestricted Danger
Keir |
Keir World Chat Champion
Posted: 22:08 - 02 Jul 2017 Post subject: |
kharlton wrote: | would recommend you go to a good tyre place that deals with bikes.
Car tyres they drill and plug but on a bike due to curve of tyre they don't work so well, the bike plug has a patch on inside to stop it popping out. quick solution though only meant as a temp fix you can buy some tyre weld that will seal it for a while. though they don't recommend it as a permanent fix it can last 2 or 3 years. easy to do . shake can connect to wheel and open valve, then ride at slow speed for 15 min choice is yours |
don't use tyre weld. just get it plugged. ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
sickpup |
sickpup Old Timer
chris-red |
Islander |
Islander World Chat Champion
Commuter_Tim |
Commuter_Tim World Chat Champion
wristjob |
wristjob World Chat Champion
Polarbear |
Polarbear Super Spammer
Matt B |
Posted: 09:39 - 03 Jul 2017 Post subject: |
Polarbear wrote: |
Do not use tyre weld. It's messy, crap and when you next get your tyre changed, the tyre fitter will be at minimum less than impressed but will probably charge you for cleaning the wheel/his equipment. |
My tyre guy said it's not that much of a problem because it tends to be up inside the tyre itself. If you tell him it's there, he knows to let the air out of the tyre before breaking down the bead (if you don't, that's when there is a certain amount of spatter as it explosively decompresses).
I still wouldn't use it unless as a last resort. Last tyre I put it in, the handling was well screwed, kept stepping out on me if I put power down out of a corner. I only needed it because of operator error, I fitted a stop and go bung but forgot to put magic blue goop on the inside part of the loop. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
skatefreak |
skatefreak World Chat Champion
Posted: 10:20 - 03 Jul 2017 Post subject: |
+1 for sticky snot strings.
I've had two in a single back tire of a track bike (and you're not going to be stressing a tire on the road anything like what that went through), front tire, 4 in car tires and even plugged a mates work van running much higher higher pressures and heavy equipment.
Never had any problems..
£8 posted with 25 strings |
Polarbear |
MCN |
MCN Super Spammer
Posted: 22:56 - 03 Jul 2017 Post subject: |
On the 'sealant' theme.
I use Puncturesafe/Ultraseal (same stuff but one licenced in UK or something) You put a measured amount in before the puncture (You can put in after too as it doesn't know when the puncture happened.) The measured amount ensures there is enough to coat the inside of the tyre and not so much that is causes any out of balance effect.
Generally tyre fitters hate sealant, most commonly they will say that they cannot repair a tyre after sealant has been in it. Sealant manufacturers say it is entirely possible to repair a tyre as per normal repair procedures after the tyre is cleaned out. The sealant is water soluble.
Tyre fitters say it leaves a film which the repair adhesive cannot bond to.
I know that there was a problem with repaired tyre tubes years ago. It apparently reacted with the adhesive and patches moved off the repair. Due to the system used to make a seal it is not so effective in tubes as the tube can flex inside the tyre.
But.. the compound has allegedly been modified so it doesn't react now.
Tyre companies maybe don't sell as many new tyres so the fitters don't get paid to fit new tyres.
I have not had a puncture since I have used sealant. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
sickpup |
sickpup Old Timer
The last post was made 6 years, 290 days ago. Instead of replying here, would creating a new thread be more useful? |
