Timing belt change
M.C
PostPosted: 15:35 - 15 May 2017    Post subject: Timing belt change Reply with quote
The timing belt's due on my Volvo (I knew this when I bought it), but it's due on age not mileage; 10 years or 150k (my cars only done 40k). How stupid's it to leave it? It's a Ford 1.6 Duratec lump so if it goes = engine damage, but I'm wondering having read various stuff if you need to replace the belt based on age, apparently Honda (for example) only recommenced changes based on mileage.
Kinda hard to get a good pic' of the belt but here are a couple:
https://i58.servimg.com/u/f58/15/13/82/47/img_2023.jpg
https://i58.servimg.com/u/f58/15/13/82/47/img_2024.jpg
Also how hard are they to change? Apparently this engine's meant to be one of the trickier ones.
lihp
PostPosted: 15:49 - 15 May 2017    Post subject: Reply with quote
Should have bought a mac.
c_dug
For me personally the worry would be enough reason for me to fork out - assuming it makes sense financially (i.e. the cost of the service doesn't come to more than the value of the car).
I say that because I thought a belt was due on my clio when I bought it and was driving it like a saint the entire time.
Turned out my clio has a cam chain engine, doh!
lihp
PostPosted: 15:51 - 15 May 2017    Post subject: Reply with quote
How much did you pay for the car?
Do you have to remove the engine?
Should have got a car with a camchain
M.C
PostPosted: 15:59 - 15 May 2017    Post subject: Reply with quote
If you were to take it to a dealer (I wouldn't but just for a laugh I checked) it would cost £900, nearly half the value of the car Laughing
Nope, front wheel + wheel arch off. Where I'm confusing myself a bit is when it comes to locking kits etc...
https://www.brit-car.co.uk/shopimages/products/seeley/normal/V/VSE/VSE5515.jpg
Far as I can tell you do need to take the rocker cover off.
M.C
PostPosted: 16:04 - 15 May 2017    Post subject: Reply with quote
The service manual says belts/pulleys and tensioners but the timing 'kit' seems to only come with one: https://www.ebay.co.uk/itm/Dayco-Timing-Belt-Kit-Cam-Belt-Timing-Chain-Kit-Ford-Focus-1-6-Ti-1-4-1-6-/331233303777?fits=Car+Make%3AVolvo%7CModel%3AC30&hash=item4d1f0b1ce1:g:57YAAOSwBvNTnBYM
Also read people recommending a new water pump with the second belt change.
arry
PostPosted: 16:18 - 15 May 2017    Post subject: Reply with quote
If you value the car, change it. If it's throwaway don't bother. My V70 is throwaway and needs a belt - if it goes bang tomorrow I won't care.
lihp
PostPosted: 16:19 - 15 May 2017    Post subject: Reply with quote
I'd change it then, usually quite straight forward. Access is the most difficult part. You only need to take the rocker cover off to lock the timing. Are your cams belt driven too?
arry
PostPosted: 16:21 - 15 May 2017    Post subject: Reply with quote
Yeah bulletproof, cough micra camchain stretch, cough 996 IMS failure, cough BMW 5/320d camchain snappers, cough SR20 camchain guide wear / jumping.
At least a belt is serviceable relatively easily and cheaply.
lihp
PostPosted: 16:25 - 15 May 2017    Post subject: Reply with quote
It wouldn't be a Volvo though Laughing
arry
PostPosted: 16:29 - 15 May 2017    Post subject: Reply with quote
True, but his Volvo isn't really a Volvo either Laughing
Monkeywrenche...
PostPosted: 16:36 - 15 May 2017    Post subject: Reply with quote
Right first things first, those pictures are of the auxiliary belt not the timing belt, and it looks like it's a "stretchy belt", so you'll need a set of tools to get the new ones on, and a new rocker gasket to prevent leaks.
as far as changing the timing belt it's pretty easy, but make sure you are 100% sure of the sequence before you start. however, the crank bolts on those engines are usually extremely tight and covered in loctite, you will need a good impact gun to get it off.
Just for reference I'd do that job for about £250-£300 all in.
2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900
Dr. DaveJPS
PostPosted: 16:41 - 15 May 2017    Post subject: Reply with quote
my V60 is currently at 94k (belt was due at 87k Embarassed ) main dealer wanted £450, booked it with my local (to work) independent and its going to be about 350 (inc VAT)
www.davejps.com
M.C
PostPosted: 16:51 - 15 May 2017    Post subject: Reply with quote
I know, you buy a Volvo and get a Ford Crying or Very sad
Hmm I thought the top one was Embarassed I'd check independent garages but I've no idea who are any good around here (North London).
P.
PostPosted: 17:40 - 15 May 2017    Post subject: Reply with quote
I could get a quote from workmate. Orpington area.
dodsi
Dirty Carny
PostPosted: 18:36 - 15 May 2017    Post subject: Reply with quote
And I drive a 'meh eurobox' Wink
See, if and when I need a service I just take mine to a local main dealer and ask the man (gender assumed) nicely to fix it at no additional cost to myself. I don't need to ask on here Wink
Lord Percy
PostPosted: 18:38 - 15 May 2017    Post subject: Reply with quote
Rubber perishes naturally with age which is why there's a time limit as well as a mileage limit. Probably not worth leaving it.
stevo as b4
PostPosted: 18:50 - 15 May 2017    Post subject: Reply with quote
As said that's the aux belt that your looking at, and yeah it's worth changing as if it let's go at motorway speeds you could fry your engine possibly.
All true duration/Mazdas use a chain drive dohc cam set up and unless neglected I didn't think they ever specified a cam chain change interval. It depends on the engine and access as to how hard it is to do, but to change most cam chain driven modern engine's chains, I'd want the engine out if doing it diy that is.
M.C
How cheap is he? Laughing
You're right I totally see now how that's worth spending 3.5k a year on. If I took mine to a main dealer (like the previous owner did all its life) I'd still only be £600 up including having bought the car Crying or Very sad
I knew you'd popup btw, don't worry that butthurt will get better with time Wink
M.C
PostPosted: 19:12 - 15 May 2017    Post subject: Reply with quote
Getting a bit confused with the terminology. In the service manual they say:
Additionally every ten years or 240.000 kms / 150.000 miles
1. Replace the engine auxiliaries belts
2. Replace the timing belt, tensioners and pulleys
I thought that meant the main drive belt and the A/C belt.
PostPosted: 19:31 - 15 May 2017    Post subject: Reply with quote
Hiya
On most modern cars the auxiliary belt drives most non directly critical components. Water pump, alternator, power steering pump, etc.
The timing belt / cam belt normally just drives the cams from the crank. It is a toothed belt and normally hidden under a cover
Katy
Robby
Dirty Old Man
PostPosted: 21:10 - 15 May 2017    Post subject: Reply with quote
Get the special tools. Expect the job to be a pain in the arse.
I often find myself with a breaker bar on the cam pulley, pushing it with my feet, while I'm holding onto the subframe and straining like a constipated weightlifter.
They can be quite tight.
Good axle stands are useful too - because when you're lying half under the car to undo the bastard tight bolt, you don't really want it coming down.
I would only do the job if you plan on keeping the car for more than a year. The belt is unlikely to fail in the next 12 months, 10 years was just a good arbitrary number for the service guide.
andyscooter
PostPosted: 21:41 - 15 May 2017    Post subject: Reply with quote
Had mine done a couple of weeks back on my fiesta with a duratec
Cost me 243_quid
That's with a new waterpump as well
Ben90
PostPosted: 23:25 - 15 May 2017    Post subject: Reply with quote
A half decent indy should cost you c. £350 all in at most. The belt and pulley kit alone is usually £100, plus £40 odd for a waterpump. In my opinion for a job you'd most likely do only once per car it's not worth the headache of learning how to do it for the sake of saving ~£200 every leap year.
I'm all for home maintenance but there's a line. I used to do five oil changes a year on car and bike which represented a ~£500 annual saving and took me just over an hour on a sunday each time, incuding a tea break.
Pretty sure what you've pictured is the auxillary belt. If the ribs run along the belt length it's auxillary, if they run perpendicular its a timing belt, and as said before it's also usually covered. Perhaps you should let a mechanic handle this?
Yamaha FZ6 S2
The last post was made 6 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.53 - MySQL Queries: 17 - Page Size: 135.02 Kb
