WD Forte |
WD Forte World Chat Champion
M.C |
M.C Super Spammer
RhynoCZ |
RhynoCZ Super Spammer
Posted: 10:09 - 16 May 2017 Post subject: |
M.C wrote: | Ben90 wrote: | Perhaps you should let a mechanic handle this? |
If I had a garage I might give it a go but it looks a bit too in-depth, the Haynes manual has it down as a 4 spanner job, I'm a 3 spanner mechanic tops. |
Poppycock, do it yourself. I changed the head gasket on a Vauxhall Vectra 3 times, right infront of my house, in a public car park. And since then I do all sorts of jobs my self.
The belt is feck easy to do. On the Vauxhall you just had to take the front right wheel off to get to the pulleys and then you release the tension on the belt tensioner (some cars use the alternator to put tension on the belt = read the manual).... and the belt is off. Then just put a new one on and reset the tensioner again (check if the belt is directional). If you do the AUX belt, then there is no timing to be done, you can't screw this up, and even if you do, there is no damage to happen really.
I was scared of doing such jobs as well, but one day I just said feck it and did it. Fixing something yourself will also make you feel good.
Read the manual, don't rush it, you'll do well.
*BTW: They do tell you the job is 4 spanners, 5 spanners... etc. = only experienced mechanic should do it, because the serpentine belt runs your power steering pump. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
Monkeywrenche... |
Monkeywrenche... Nearly there...
Posted: 10:40 - 16 May 2017 Post subject: |
[quote="RhynoCZ"] M.C wrote: |
*BTW: They do tell you the job is 4 spanners, 5 spanners... etc. = only experienced mechanic should do it, because the serpentine belt runs your power steering pump. |
read the thread, he wants to do the timing belt, and in any case you're still wrong about the aux belt procedure for this engine, it has no tensioner, it's a stretchy (very loose use of the word) belt on this engine that requires tools to remove and replace. ____________________ 2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900 |
RhynoCZ |
angryjonny |
angryjonny World Chat Champion
Monkeywrenche... |
Posted: 11:51 - 16 May 2017 Post subject: |
yes I am, that link is for a C30 T5 which is a 2.5 5 cylinder turbo, he has a 1.6 Duratec, not all engines are the same
the timing procedures are different for the ford compared to the vauxhall as the cam and crank pulleys aren't keyed to the shafts. ____________________ 2001 Aprilia RSV Mille R -dead, 2016 XSR 700-gone, 2018 Dorsoduro 900 |
RhynoCZ |
Posted: 11:54 - 16 May 2017 Post subject: |
angryjonny wrote: | RhynoCZ wrote: | I changed the head gasket on a Vauxhall Vectra 3 times, right infront of my house, in a public car park. |
The implication there, of course, is that you stuffed it up at least twice |
Seems like it, but it is not the case. The first time I did it, people heard about this, and then I did it on someone else's car (never heard any complaints). The third time was unfortunate, as after about 10,000km the timing belt tensioner of the first Vectra gave up and the valves met the pistons. Lucky enough, the only damage was bent valves, so I just bought a different head and replaced it, the car ran great every since.
The belt tensioner was alright the first time I did the job, I did everything by the book. That's why it is advisable to replace the tensioner/s when you change the belt/s, I guess. OR this was just a unlucky coincidence. Just like my father's 1.9TDi dropping the valve into the engine after 300,000km on the clock. They say things like this never happen, but they do time to time happen. ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
M.C |
M.C Super Spammer
Posted: 12:03 - 16 May 2017 Post subject: |
AFAIK the 1.6 engine's the Ford Duratec unit, the 1.8/2.0L are Mazda engines, and the 2.4L/T5 Volvo. I did want the 1.8 originally but this one came up and was too nice to pass on. A mate keeps ripping me about it (he drives a Micra ) and I tell him it's a racing engine (I believe they used it in Formula Ford) |
RhynoCZ |
Monkeywrenche... |
Hong Kong Phooey |
Posted: 21:19 - 20 May 2017 Post subject: |
You can splice the old belt in two, lengthways and remove half of it, then push the new one on and cut away the old belt if you're too tight to buy the locking tools.
Personally I'd hand it over to an indy as access is right tight and you'd need to support the engine. Is not a quick job, and it's not something to gamble with.
You should also make your own markings in case you skip a tooth.
Obligatory Scotty link showing you how much hassle is likely to entail on a transverse engine.
Some of them bolts are likely to be tight as fook.
Even just getting the timing covers off is a pain in the arse.
https://m.youtube.com/watch?v=VAuqOAp72m0 ____________________
stevo as b4 |
Robby |
Robby Dirty Old Man
M.C |
M.C Super Spammer
Monkeywrenche... |
- Super Spammer
Posted: 09:54 - 22 May 2017 Post subject: |
M.C wrote: | Robby wrote: | Luckily chains are back in fashion, and some engines have ultra long life belts - like the little 1L ecotec engine from Ford, where the belt appears to run inside the engine and have a 100k+ mile life. |
Volvo reckon 150k for my belt, even though Ford say 100k with the Focus, and Haynes suggest not leaving it beyond 60k. It's all the conflicting info' that makes me wonder if it really needs doing. |
Many manufacturers list high intervals when the vehicle is launched to attract lease companies. Once the premature failures start coming in, the advisory is often shortened. This also applies to long service intervals of 20,000 miles. Even with the recommended oil, it may take the car to end of lease with less services, but will cause more wear for whoever owns it after the first 100K.
Rubber is rubber and a belt is a belt, no matter what the engine. It deteriorates over time and heat cycles. Personally, I go for 4 years or 60,000 miles, unless the car is disposable. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
Dr. DaveJPS |
Dr. DaveJPS World Chat Champion
M.C |
M.C Super Spammer
Posted: 16:26 - 22 May 2017 Post subject: |
mpd72 wrote: | Many manufacturers list high intervals when the vehicle is launched to attract lease companies. Once the premature failures start coming in, the advisory is often shortened. This also applies to long service intervals of 20,000 miles. Even with the recommended oil, it may take the car to end of lease with less services, but will cause more wear for whoever owns it after the first 100K. |
Volvo seem to have done the opposite, in the service book it says 100k/8 years, then on the VIDA software (I have the 2014 ver.) they've extended it to 150k/10 years. Ford AFAIK have stuck to the original intervals with the Focus.
By applying that formula shouldn't it be 12 years
Dr. DaveJPS wrote: | Is it the 1.6 Drive diesel, Mine was due at ~87k according the the volvo service manual? |
Petrol, 100bhp but 0 torque, I mean nothing. I looked at tuning as this engine's 150bhp in Fomula Ford and in the racing puma, although looks like it'll be a waste of time. |
- Super Spammer
Posted: 17:42 - 22 May 2017 Post subject: |
M.C wrote: | mpd72 wrote: | Many manufacturers list high intervals when the vehicle is launched to attract lease companies. Once the premature failures start coming in, the advisory is often shortened. This also applies to long service intervals of 20,000 miles. Even with the recommended oil, it may take the car to end of lease with less services, but will cause more wear for whoever owns it after the first 100K. |
Rather you than me. I stick to 4 years on my Transporter camper, even with minimal mileage. Age affects rubber as much as mileage. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
M.C |
M.C Super Spammer
- Super Spammer
M.C |
M.C Super Spammer
Posted: 21:52 - 22 May 2017 Post subject: |
Depends what nick they were in If they had cracks etc. then no. I read start/stop traffic puts more pressure on the belt(s), so that's another factor as I believe the car has lived in the city all its life. |
dodsi |
dodsi Dirty Carny
Posted: 12:07 - 23 May 2017 Post subject: |
So, we have now reached the point that this damn timing belt has still not been changed and no decision has been made to change the damn thing.
By now; in the same situation, I would have already have booked 'our'*(*VW Financial Services') car in, dropped it off, had use of a courtesy car and collected the newly serviced car back from the dealer. At no additional cost to myself - let alone anywhere in this process mithering about should I or shouldn't I change a belt.
As you have said, you have plenty of assets and savings so perhaps break into the M.C. Millions and get the job sorted. |
M.C |
M.C Super Spammer
Posted: 13:24 - 23 May 2017 Post subject: |
With the age of the vehicles you lease do they ever reach an expensive service, beyond an oil change? Do you remember how much I was up over your leasing costs? I remember it being thousands so a few hundred for a timing belt change won't break the bank, I'm just sifting through the conflicting info' trying to make an informed decision...
...which I have already. If I keep the car long term (probably won't) I'll change it, if I sell it I won't. Obviously you're still not over this so I look forward to your next 20 butthurt posts on the subject. |
The last post was made 6 years, 331 days ago. Instead of replying here, would creating a new thread be more useful? |
