Warped rotor. Turning them round to reverse the warp.
cyberglass This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
Wonko The Sane
PostPosted: 17:48 - 17 May 2017    Post subject: Reply with quote
I know my front brakes are marked with a rotation direction, is this not the case with your bike?
Nope.
PostPosted: 18:08 - 17 May 2017    Post subject: Reply with quote
I'm not quite sure what you mean, but whats the degree of run out? If it's not too horrendous and you've got a mate with a lathe you could always get them to true it up, but again it depends on the degree of run out and how much disc you'd have left at the end.
2011 XT660Z Ténéré - 2003 YZR-R1 5PW (In Build)
redeem ouzzer
PostPosted: 18:14 - 17 May 2017    Post subject: Reply with quote
Workshop motherfucker....
Be a REAL MAN!
PostPosted: 08:21 - 18 May 2017    Post subject: Reply with quote
The warp will still be there... I don't see what this would achieve?
Landy10
PostPosted: 09:21 - 18 May 2017    Post subject: Re: Warped rotor. Turning them round to reverse the warp. Reply with quote
cyberglass wrote:
Vstroms got a warped rotor its not causing any pulsing as its warped the full diameter of the disc but it is causing the lever to come near to the bar as the pads flex the disc when the brakes are applied. Before i shell out £200+ for a set of discs im Planing on removing them turning them over and putting them back on.
Has anyone tried this and will it solve the lever travel problem with the disc warped the oposite way to what they are now?
Thanks
Eh no.
If they are warped then they are warped no matter which way round they are. Rolling Eyes
Bikeless
PostPosted: 09:34 - 18 May 2017    Post subject: Reply with quote
How do you know they are warped?
DrDonnyBrago
PostPosted: 10:08 - 18 May 2017    Post subject: Reply with quote
Warped all the way round doesn't make much sxense, do you mean your disc is bowl shaped now? i.e. the outer rim isn't in line with the inner rim?
Johnnythefox
PostPosted: 10:13 - 18 May 2017    Post subject: Reply with quote
I guess that you don't feel that your life is worth a couple hundred quid?
chrisdubya
PostPosted: 11:08 - 18 May 2017    Post subject: Reply with quote
Put it on a table and smack it with a hammer to straighten it out. HTH.
Pete.
PostPosted: 12:44 - 18 May 2017    Post subject: Reply with quote
This is like asking if it's possible to un-paint a wall by using a clean brush.
a.k.a 'Geri'
PostPosted: 14:25 - 18 May 2017    Post subject: Reply with quote
That analogy is going to be used the next time wifie asks me a stupid question. It will be worth the sulks Thumbs Up Laughing
Triumph Trophy Launch Edition
nowhere.elysium
The Pork Lord
PostPosted: 16:38 - 18 May 2017    Post subject: Reply with quote
This is possibly one of the most retarded things I've ever read.
duhawkz
PostPosted: 16:49 - 18 May 2017    Post subject: Reply with quote
Because they weld to 4 thou and throat punched him
Fisty
PostPosted: 20:26 - 18 May 2017    Post subject: Re: Warped rotor. Turning them round to reverse the warp. Reply with quote
Thanks
This is ultra violet on the autistic spectrum.
Fatter and faster than Fret
Bozzy
PostPosted: 20:56 - 18 May 2017    Post subject: Reply with quote
Put a set of discs on it you bell Thumbs Up
2004 SV650S >>> 2009 Street Triple R
kgm
PostPosted: 22:16 - 18 May 2017    Post subject: Reply with quote
If the disks are warped then replace them.
How do you know they are warped - have you measured?
The excessive travel could be caused by a few other things. The primary ones to my mind being air in the system or crap behind the dust seals causing them to grip and pull the pistons back in too much. If you take the pads out and pump the pistons out the latter will become obvious.
DOS
PostPosted: 00:23 - 19 May 2017    Post subject: Re: Warped rotor. Turning them round to reverse the warp. Reply with quote
Thanks
How can someone be a member here for 12 years and be such an
idiot.?
UncleFester
PostPosted: 06:44 - 19 May 2017    Post subject: Reply with quote
Bodyguards parent?
Seriously though - just buy new stuff.
Module 1 and 2 passed - October 2014. Happy owner of a 2017 Z1000SX, ex owner of a YBR125 / CB500 / VFR800.
pompousporcup...
PostPosted: 08:23 - 19 May 2017    Post subject: Reply with quote
warped the full diameter of the disc... Confused
Doovy
PostPosted: 10:03 - 19 May 2017    Post subject: Reply with quote
Sorry, I haven't posted in a while Smile
natefz6
PostPosted: 10:51 - 19 May 2017    Post subject: Reply with quote
Warped all the way round like this?
https://sc02.alicdn.com/kf/HTB17XaNLXXXXXahXpXXq6xXFXXXv/motorcycle-brake-disc.jpg
"no I didn't steal it that's just the way I ride"
weasley
PostPosted: 12:58 - 19 May 2017    Post subject: Reply with quote
What I'm suspecting is that the disc has become conical, perhaps because of a stuck brake piston meaning it gets pushed from one side (hence the "pads flex the disc when the brakes are applied" comment). He's perhaps looking to use these asymmetric braking forces to flatten the disc back the way it came.
Pete.
PostPosted: 13:15 - 19 May 2017    Post subject: Reply with quote
If it's getting dished then it should spring back when the laid is off. If it doesn't then the deformation is permanent.
a.k.a 'Geri'
The last post was made 6 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.94 - MySQL Queries: 17 - Page Size: 130.7 Kb
