Oil not returning to sump?
MG#43
PostPosted: 18:36 - 18 May 2017    Post subject: Oil not returning to sump? Reply with quote
Hi, anyone any ideas? Sump is in the frame on a DRZ400. I opened the left engine case and pretty much all the oil dumped itself in the oil catch pan. Presume something's blocked but what and where? thanks! Smile Also, perhaps a dump question but could this in anyway effect a starter clutch (not working but grabbing when manually turned once removed and cleaned up, i.e. dry)?
PostPosted: 19:42 - 18 May 2017    Post subject: Reply with quote
Presume a dry sump engine. But I have zero specific knowledge of this engine.
It will take oil from the frame / tank for the main oil pump to supply the engine. There will be a scavenge pump of some kind (low pressure) so pump oil from the actual sump up to the frame / tank. There is likely also a one way valve in the system to stop oil draining from the tank back to the sump.
At a guess the one way / anti sumping valve is not doing its job.
Katy
Hong Kong Phooey
PostPosted: 20:53 - 20 May 2017    Post subject: Reply with quote
Did you see this thread?
https://www.suzukicentral.com/forums/17-maintenance-repairs-tuning/94831-oil-not-returning-sump-tank-clutch-dragging.html#/topics/94831?page=1
MG#43
PostPosted: 08:34 - 21 May 2017    Post subject: Reply with quote
Hong Kong Phooey wrote:
Yeah I had seen it thanks, not had the time to get the cover off on that side, checking this afternoon so fingers crossed it's the plastic oil pump gear.
Assume its plastic for a reason, perhaps due to needing to bump start it a number of times due to a starter clutch prob it's shagged itself. Surprised
The last post was made 6 years, 340 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.31 - MySQL Queries: 17 - Page Size: 42.1 Kb
