Stalk |
Stalk Brolly Dolly
Posted: 15:47 - 20 May 2017 Post subject: 84 yam xj650 alternative carburetors? |
Hi All!
We have this Yamaha xj650 with Hitachi 32 mm carbs that we can't get right. They have been cleaned, rebuilt with new jets and float needles, balanced with the YICS blanked off, and they just seem to work when they feel like it. Remade gaskets to the cyl head, set the floats, done it all, suspect the throttle spindle seals may be leaking. The reason that I say carbs rather than electrical is that when easy start is sprayed into the carb of the cylinder that is missing, it picks up, so I am getting to the bin the carbs and get some others stage. Problem is that they are now all so old that I may just be buying the same problem.
I need a set of carbs, side-draft, from a similar size 4 cylinder bike. We can make brackets if the carb spacing is not exactly correct, and if the jetting is slightly out, we can play with that later. We just want it to run consistently on all 4 cylinders.
Has anyone got any suggestions as to what bike I should be looking at for carbs?
Cheers All!
Should also have said, diagrams and inlet rubbers ok |
stevo as b4 |
Robby |
Robby Dirty Old Man
stevo as b4 |
temeluchus |
redeem ouzzer |
temeluchus |
Kickstart |
Kickstart The Oracle
The last post was made 6 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
